80/102mm triplet vs 127mm triplet
astrophotography
8 replies to this topic
#1 BlueHawk08
BlueHawk08
Posted 09 October 2019 - 11:40 AM
I have been visually observing for years using 8 and 10 inch SCTs. Some "astrophotography" by simply mounting DSLRs on the OTA, nothing through the eyepiece.
I was considering purchase of an ED 127mm triplet for astrophotography.
I have seen some comments in these forums to the effect that experienced Astrophotographers recommend an 80mm or 102mm Triplet refractor scope over a larger version, say 127mm. I infer from those comments that the distinction is somehow related to the sophistication of the 127mm making it not a good fit for beginning or intermediate astrophotographers. Can anyone explain?
Thanks.
#2 wrvond
wrvond
  • Loc: West Virginia
Posted 09 October 2019 - 11:52 AM
More important than the telescope is the mount. The bigger the scope, the bigger the mount has to be. A 127mm triplet will require a massive mount that makes transport and set up a real challenge.
#3 Ishtim
Ishtim
  • Loc: N. Alabama, USA
Posted 09 October 2019 - 12:09 PM
Aside from portability and mounting challenges with larger scopes, as focal length increases, the demands on the "system" increase
e.g. Polar alignment, tracking/guiding, pointing (go-to), effects of periodic error, etc.
The astrophotography learning curve can be steep and recommendations of short(er) focal length refractors for those new to it is sage advice.
Edited by Ishtim, 09 October 2019 - 12:09 PM.
#4 Hesiod
Hesiod
Posted 09 October 2019 - 12:30 PM
The main reason is that 80mm triplets are usually f/6 at 480mm, while 127mm ones are in the f/7-f/8 range at 1000 or so.
The greater focal length brings a tighter sampling, which in turn leads to the need for greater accuracy (is the same as for daytime photography: greater the focal, harder to avoid blur); also, because bigger refractors tend to be slower, you would need more time to collect the same amount of signal; to be honest, this can be mitigated by the use of focal reducers, but these can lead to further issues as well.
Then there is the matter of the mount, which of course has to be larger, and therefore heavier and more expensive
#5 SilverLitz
SilverLitz
  • Loc: Louisville, KY
Posted 09 October 2019 - 12:51 PM
My 1st scope was a ES ED102CF, and I came to the opinion that it is a "tweaker" FL and in the long run one that I would NOT use for AP.  The 714mm is too long for a lot of nebulae and too short for most galaxies.  My issue was not of the mount, as I have a G11.  (The ED102CF's focuser is also NOT good enough for AP.)
I replaced the ED102CF with a SW Esprit 100 and Esprit's FL (550mm native & 413 with FR) is more usable, especially the 413mm.  This year I am also using an ASI183mm-Pro.  Esprit 100 at 413mm with  ASI183 has the same scale (1.2 pix/arcsec) as the ED102CF with my Canon 7Dmk2, and at 550mm it has higher resolution 0.9 pix/arcsec for galaxies.  A normal f/6 80mm scope would be between my Esprit's 2 FLs at 480mm, before FR.
A typical 127mm, or broader 120-140mm, scope would be much better for most galaxies, assuming an appropriate mount.
#6 BlueHawk08
BlueHawk08
Posted 09 October 2019 - 04:56 PM
Interesting. It all makes sense. Many thanks.
#7 SteveInNZ
SteveInNZ
  • Loc: Auckland, New Zealand
Posted 09 October 2019 - 09:28 PM
I have an ED127 scope and there are a couple of consequences of the longer tube length that are worth mentioning.
1) It's long enough to collide with a tripod leg on some mounts.
2) If you are using a DSLR without a laptop, you spend a lot of time crawling around on the ground in uncomfortable positions, especially if you don't have a flip-out screen.
Things like focal ratio, arc-sec/pixel, etc are all valid and correct points but it's things like those above that make me choose a different OTA to use tonight or might make your experience one step more frustrating than it need be.
Steve.
#8 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 09 October 2019 - 10:08 PM
65mm OTA, old dSLR
  • hiMike and richorn like this
#9 View2
View2
  • Loc: Vancouver, WA USA
Posted 09 October 2019 - 10:11 PM
With a wide field faster refractor F5 to F6 everything is much more forgiving stars are tighter guiding is more tolerant. Everything is easier. That being said I have the 127 mm F/7.5. I have a 0.7 x field flattener focal reducer I use and I would not want to image galaxies with it on ( except M31).
Also tagged with one or more of these keywords: astrophotography
