Another mirror cell thread
9 replies to this topic
#1 Piero DP
Piero DP
  • Loc: Cambridge, UK
Posted 09 October 2019 - 03:26 PM
I looked at the images of a few 9-point mirror cells on the Internet and noticed that the triangles are only attached with a bolt. Does this mean that they can also rotate, apart from the normal vertical movement? If this is the case, isn't there a chance that the rotation of the primary mirror can cause an unwanted rotation of one or more triangles, determining unequal mirror support?
Secondly, at page 186 Sidgwick says that "insufficient central support, allowing the axial region of the mirror to sag, will cause spherical over-correction" (pg 186, section 10, Amateur Astronomer's Handbook).
Can unwanted rotation of triangles cause spherical over-correction?
Thanks for your help
#2 havasman
havasman
  • Loc: Dallas, Texas
Posted 09 October 2019 - 04:15 PM
Many modern mirror cells have attachments from a support triangle to its neighbors. My Starmaster uses thin braided cable, New Moon uses springs. They keep the system in place and prevent rotation of the triangles.
  • Augustus likes this
#3 brebisson
brebisson
Posted 10 October 2019 - 12:16 AM
Hello,
Normally the triangles are held one way or another to avoid turning...
However, I would discourage you from going 9 points...
If you run the number through plop, you should discover that the 9 point cell give little to no improvements over the 6 point cell, while being much harder to make and much more prone to slight variations compared with the optimal...
Cyrille
#4 Pinbout
Pinbout
Posted 10 October 2019 - 05:53 AM
If 6 was 9 - hendrix
guess he never made a telescope cell.
if 9 was 6 you’ll be happier
or go 18 if 6 isn’t enough.
https://youtu.be/ifSMbmCxf1I
Edited by Pinbout, 10 October 2019 - 05:54 AM.
#5 Pinbout
Pinbout
Posted 10 October 2019 - 05:58 AM
Most use a kydex ring to keep triangles in place
https://youtu.be/wBk66Mm0eC4
#6 Piero DP
Piero DP
Posted 10 October 2019 - 11:18 AM
Thanks for your replies.
#7 Arjan
Arjan
  • Loc: Netherlands
Posted 10 October 2019 - 02:50 PM
"Now if 6 turned out to be 9
I don't mind, I don't mind
Alright, if all the hippies cut off all their hair
I don't care, I don't care
Dig, 'cos I got my own world to live through
And I ain't gonna copy you"
Makes for a better text though.
Where's the time?
  • Pinbout likes this
#8 Arjan
Arjan
  • Loc: Netherlands
Posted 10 October 2019 - 02:51 PM
Why kydex?
#9 Pinbout
Pinbout
Posted 10 October 2019 - 05:48 PM
  • dan_h likes this
#10 GroupJ
GroupJ
Posted 10 April 2020 - 11:10 PM
For 6 point cells (three rocker arm) and for 9+  point cells (triangles), each rocker arm or triangle should be mounted on a spherical bearing so that the arm/triangle can rotate in any plane about the pivot point. Some method of preventing rotation about an axis parallel to the optical is needed.  A pin attached to the arm/triangle, parallel to the optical axis and passing through a hole in the cell frame has been used.  Gets tricky for 18+ point cells.
