Nebulosity 4 not running on macOS Catalina
13 replies to this topic
#1 Cliff99
Cliff99
  • Loc: Sydney Australia
Posted 09 October 2019 - 04:42 PM
Well I upgraded my MacBook Pro to macOS Catalina  and Nebulosity 4 no longer works , even tried the pre-release 64bit version.
Anyone here running Nebulosity 4 on a Mac ?
Can't seem to find the yahoo group or Wiki links from Stark seem dead.
Appreciate any help,
Cliff
#2 Delta608
Delta608
  • Loc: Tampa Bay Florida
Posted 09 October 2019 - 06:01 PM
Apple says 64bit only with Catalina....I never got Nebulosity to work properly...Its been a few years waiting for Mac driver updates...I moved on..
#3 Cliff99
Cliff99
Posted 09 October 2019 - 08:31 PM
Seems like I did my doe , I can still use it under bootcamp I suppose.
Yes 64bit only now their is a Nebulosity 64bit but not running either.
What do you use now?
thanks Cliff
#4 Joe Bergeron
Joe Bergeron
    Vendor - Space Art
  • Loc: Upstate NY
Posted 10 October 2019 - 02:30 AM
Nebulosity 4.2 works perfectly on my 2012 MacBook Pro running El Capitan or something, and my 2018 MacBook Air running Mojave. I'll have to give the pre-release 64-bit version a try.
#5 Delta608
Delta608
Posted 10 October 2019 - 05:40 AM
thanks Cliff
 I'm still experimenting...(Not much of an answer, I know.) Leaning towards SPG and Pixinsight...Lots of threads of those using MACS for acquisition and processing on CN...Check them out..I threw in the towel and bought a cheap Dell, then an Eagle3...
#6 Joe Bergeron
Joe Bergeron
    Vendor - Space Art
  • Loc: Upstate NY
Posted 10 October 2019 - 10:52 AM
The 64-bit Nebulosity starts up with no issues for me. It will be a while before I actually try using it.
#7 Cliff99
Cliff99
Posted 12 October 2019 - 05:08 PM
Thanks for all the replies,
This is part of the 'crash report'
I ended up fixing it, hopefully haven't broken any other Apps.
Crashed Thread:        3
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    DYLD, [0x4] Symbol missing
Application Specific Information:
/Applications/Nebulosity4-64.app/Contents/MacOS/../Resources/libatikcameras.dylib
Dyld Error Message:
  Symbol not found: _libusb_hotplug_register_callback
  Referenced from: /Applications/Nebulosity4-64.app/Contents/MacOS/../Resources/libatikcameras.dylib
  Expected in: /usr/local/lib/libusb-1.0.0.dylib
This is what I did,
I copied libusb-1.0.0.dylib from inside the Nebulosity 4-64.dmg to /usr/local/lib/
I noticed the one there was only 73K while the one in Nebulosity was 113K so I replaced it. I did rename the other so I can return it.
Now happily running on Catalina,
Another App may have corrupted that file as Craig Stark said his ran fine and he sent the screen shot to prove it.
May be this will help the FEW Mac guys running Nebulosity but at least now I can use it .
Cheers
Cliff
#8 Robin H
Robin H
Posted 13 October 2019 - 12:36 PM
Crashed Thread: 3
Dyld Error Message:
This is what I did,
Cheers
Cliff
#9 Robin H
Robin H
Posted 13 October 2019 - 12:38 PM
Hi Cliff
I am having the same problem also, and I only paid for Nebulocity in August so well chuffed.
You seem to be a bit more familiar with computers than me. Would it be possible for step by step instructions as to how you action the workaround above?
Robin
#10 Cliff99
Cliff99
Posted 13 October 2019 - 07:06 PM
Hi Cliff
Robin
Hi Robin,
I'll do my best , I'm no programmer.
If you are running MacOS Catalina make sure you have the Pre-release Beta release of Nebulosity 4 -64 installed the earlier ones are 32 bit and won't work anymore on Catalina.
If you double click on the Nebulosity4-64_resign.dmg file you downloaded and go to the image on the desktop and open it,
Then right click on the Nebulosity4-64.app inside and select show package contents.
Under contents you will find Resources and the file you want is libusb-1.0.0.dylib Right click and copy then paste it to say the desktop .
You need to copy the file to /usr/local/lib/
Easiest way is to use a file utility I use Forklift but you can use finder but you need to access the hidden files.
If you are comfortable with Terminal you can use that.
From the prompt $
cp /usr/local/lib/libusb-1.0.0.dylib /usr/local/lib/old-libusb-1.0.0.dylib
This keeps a backup of the original
Then you need to copy the file from the desktop
cp /Users/cliffs/Desktop/libusb-1.0.0.dylib /usr/local/lib
'cliffs' needs to be replaced with your User Account Name.
Sounds difficult but actually easier to do then explain. Maybe I should have pictures or video ?
Hope that helps if you attempt it, hopefully this will be fixed once Nebulosity 4-64 goes to stable version.
I did tell Craig Stark if he reads my email.
Cliff
#11 Ron359
Ron359
  • Loc: -105 +39
Posted 18 October 2019 - 10:24 AM
Cliff
Don't know why you can't find them but both the yahoogroup and Stark-Lab website are alive and well - Since yahoogroups is going away very soon there is discussion on the group on migrating elsewhere probably to groups.IO as many others have.   Apparently as one of the "few" Mac-Neb users I am not an 'early adopter' and always wait awhile before upgrading to Apple's latest and greatest OS-X to avoid the  upgrade issues while developers 'catch-up.
 I thank Steve Jobs every day that I have a choice when or if to install upgrades unlike those constantly howling about constant upgrades and updates auto-installed on Win. 10 and previous.
#12 Robin H
Robin H
Posted 19 October 2019 - 02:16 AM
#13 Robin H
Robin H
Posted 19 October 2019 - 02:17 AM
Hiya.
I had the same problem. Have now downloaded the pre release 64bit version of Neb and it is working perfectly on the Mac Catalina.
The pre release version can be found on the stark labs website
#14 Tom3
Tom3
  • Loc: Scottsdale, AZ
Posted 09 January 2020 - 07:17 PM
Hiya.
I recently purchased Nebulosity 4-64 and it runs fine on Mac Catalina, and I have noticed some operating differences from the tutorials on V3.  For example have not seen a way to make masterworks and masterflots--you just load your flats and darks into the preprocessing window.  Have not tried for capture, I use Astroimager for that.
