DSS vs PixInsight for stacking
7 replies to this topic
#1 Waterobert
Waterobert
  • Loc: Laguna Niguel, California , USA
Posted 10 October 2019 - 02:38 PM
I did stacking in DSS , however yesterday I downloaded PixInsight and I am wondering if I should redo stacking in the new software. DSS is much simpler to use 😂😂😂
#2 ZL4PLM
ZL4PLM
    Vendor - ZWO Product Dev Team Member
  • Loc: Darfield, New Zealand
Posted 10 October 2019 - 02:46 PM
What makes you say that?
you can integrate in two ways in Pix
1. manually - calibrating / align and integrate the frames using the stand alone processes or...
2. Use Batch Preprocessing script
I have tested both and in my data unless I have done something daft BPP produces as good as result as manually doing it
Use BPP script - load lights - darks and my calibrated dark flats - choose master dark - master flat - uncheck CFA - hit go
it will run its processing script and deliver you a final image without further intervention (normally)
not much different from DSS
I have tried it manually and I find it really hard to see much difference - my old PC would run it overnight as well as its was pretty slow - my new server processes what took 4 hrs or so in under 2 mins - so its not so much an issue but I still prefer to load everything in and hit go!
Once you get your head around Pix (and I do recommend buying Warren Keller's book and doing it manually a few times so you understand whats going on during BPP) then I find it as easy to do
I might come across odd sets of data that I have to do manual but I found BPP does a pretty good job - give it a whirl smile.gif
cheers
Simon
Edited by ZL4PLM, 10 October 2019 - 02:47 PM.
  • timmbottoni, Jim Waters and johrich like this
#3 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 10 October 2019 - 04:12 PM
You can tell BPP just to 'calibrate' you images and run StarAlignment manually which is what I do.
IMHO - PixInsight is much better than DSS as far as calibration and alignment.  PixInsight is significantly better than DSS post processing...
  • tcchittyjr likes this
#4 Jim Waters
Jim Waters
Posted 10 October 2019 - 04:21 PM
Yes - redo using Lights, Darks, BIAS and Flats.  Use Batch Preprocessing - BatchPreprocessing.
PixInsight isn't that complicated.  There are many YouTube video's that walk through the entire process.  A through Z.
#5 ZL4PLM
ZL4PLM
Posted 10 October 2019 - 04:29 PM
So that's three modes Jim :)
Of course cal only too ;) my bad
  • Jim Waters likes this
#6 scadvice
scadvice
  • Loc: Lodi, California
Posted 10 October 2019 - 04:33 PM
Here is one of the A through Z video sets Jim was talking about. I started PI using Astro Dude's "Pixinsight for absolute beginners" 12 video series.
https://www.youtube....h?v=HIXJJqew6rQ
  • Jim Waters and johrich like this
#7 Jim Waters
Jim Waters
Posted 10 October 2019 - 04:53 PM
This is one of the better video's.  Walk through the entire series.
  • guyroch and scadvice like this
#8 Waterobert
Waterobert
Posted 10 October 2019 - 07:37 PM
This is how I got my first image processed:
I had videos running on one laptop while I was working on my data on the other lol.gif lol.gif lol.gif lol.gif lol.gif
I did skip few steps and did stacking in DSS since I played with it once before.
