Filter dilemma - need advice
4 replies to this topic
#1 lakeorion
lakeorion
  • Loc: Lake Orion MI
Posted 10 October 2019 - 08:08 PM
I wanted to stuff the filter wheel with the highest quality glass.  But...
  • I'm limited to 1.25" filters.
  • Chroma 1.25" filters don't fit. https://www.cloudyni...ma#entry9693265
  • Astrodon filters have a blue cut on lower wavelength than I'm currently using (Baader UV-IR @ 426 nm) and I'm worried about bloated blue stars. https://www.cloudyni...ma#entry9410246
  • If I poke around at specifications, the Astronomik Deep Sky RGB appear to fit the bill, but they are 1mm thick substrate.
So the heart of the question is, if I go ahead and get the Astronomik Deep Sky RGB, and I use an OAG, am I now limited to 1mm thick filters for narrowband also?  The Astronomiks are 6 nm bandpass - am I excluding myself from the Astrodon 3 nm bandpass (3 mm substrate) because the filter thickness will change my focus enough to throw off my OAG?
Kit currently consists of WO Star 71, QHY OAG-s, QHY CFW3S 7x1.25, QHY 183M.  Usually imaging from an Orange / Yellow light pollution zone north of Detroit.
Does 'parfocal' REALLY matter?  I can refocus on filter swap but the OAG is stuck at it's focus and that's it.
On the plus side, the cost difference between Chroma/Astrodon and Astronomik for a full RGB IR Ha OIII SII set is almost my next telescope.   lol.gif
Thanks in advance for your experience and opinions.
#2 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 10 October 2019 - 10:33 PM
And this is why I don't use an OAG with my refractor...;)
But seriously, if you're using PHD for guiding, it may not matter -- it's really good at still finding centroids on slightly out-of-focus stars.  My 60mm guide scope changes focus a bit as the night cools, but I don't refocus it -- and distinctly fuzzy stars guide just as well (according to the guide logs) as the sharply focused ones earlier in the evening.
I know how you can test before you invest in the filters, of course -- focus as normal, then move your focuser intentionally 2mm out of focus.  Guide through the now out-of-focus OAG stars, and see how it goes.  If the results are good (and I suspect they will be), fire away with the filters of your choice!
#3 lakeorion
lakeorion
Posted 11 October 2019 - 11:33 AM
Understood, but the OAG was a significant weight savings over the 60mm guide scope.  When you have a 71mm refractor and a $1300 mount, extra scope weight matters, along with the power savings of an additional dew heater.  Returning to a separate guide scope is an option I hadn't thought of.
That is an excellent idea.  Thanks.  Of course it's Friday night so the clouds come rolling in to prevent testing.
#4 lakeorion
lakeorion
Posted 01 November 2019 - 08:30 AM
In the end, money won out.  I went with all Astronomik filters.
#5 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 01 November 2019 - 11:16 PM
I just ordered Chroma Oiii 3nm which is coming next week i hope, it is 1.25", i do have Astrodon Ha 5nm 1.25" before, and later i may buy Astrodon or Chroma LRGB filters and end up with SII 3nm, this way i know i have the best, any issues i am trying to solve them eventually, and i know budget or money is always suffering.
Congratulations and good luck!
