Kstars for Android 9 Pie?
9 replies to this topic
#1 Traveler
Traveler
  • Loc: The Netherlands
Posted 11 October 2019 - 01:30 AM
I like KStars a lot on my Windows computers. This morning i tried to installed Kstars on my new Phone.Somehow when i try to install Kstars on my Motorola G7 (Android 9 Pie) there comes a message that the app is not compatible with my Phone.
Question: is there a version of KStars which is compatible with my Phone?
#2 freiform
freiform
Posted 11 October 2019 - 09:00 AM
I am using KStars on a Xiaomi Mi 9 Se which is running Android 9. Pie doesn't seem to be the problem.
Sven
#3 Jon Isaacs
Posted 11 October 2019 - 11:10 PM
I downloaded KStars Lite to my Pixel XL which is running Android 10.  It downloaded and started to run but got kicked out after the IC-NGC Catalogs were loaded.
#4 Traveler
Traveler
Posted 11 October 2019 - 11:32 PM
To me it seems there is something not correct with the Kstars lite app by the Google Play distribution... I don't see  a reason why my Phone is not capable running the app when reading the  compatibility list ...
#5 Jon Isaacs
Posted 13 October 2019 - 05:59 AM
I think you're right. I tried to download it on three tablets, a Nexus 10 running Android 5, a Nexus 7 running Android 6 and a Samsung Tab A 8 running Android 7.1.1. All came up as incompatible.
It did download on my Pixel XL but crashed before it waa finished booting.
  • Traveler and freiform like this
#6 freiform
freiform
Posted 13 October 2019 - 01:12 PM
I had kstars crash on startup because of missing permissions. This won't help if it cannot be installed in the first place, of course..
Sven
Edited by freiform, 13 October 2019 - 01:12 PM.
  • Sean Wood likes this
#7 Jon Isaacs
Posted 13 October 2019 - 07:36 PM
Sven
Was that Android? If so how did you fix it?
#8 freiform
freiform
Posted 14 October 2019 - 02:31 AM
Hi Jon,
Yes, Android 9. How to set permissions is a bit up to the UI your device is using. Normally something like a long-press on the app should bring up a menu with "App-Info". There you will find permissions which you can en- or disable. Alternatively you can go through system settings - manage apps.
Kstars needs storage access and location services.
Sven
#9 Sean Wood
Sean Wood
  • Loc: North Carolina
Posted 14 October 2019 - 01:57 PM
I can confirm that changing the permissions for the app will let the app start. I was having issues similar to Jon on a Pixel XL, android 10. I would close mid startup. I went in and enable storage and location in the app permissions and it loaded fine after that. The easiest way I know how to get to the app info page to change the permissions is to find the app in your app drawer and long press on it. Android 8 and above, it should bring up a pop up menu to be able to see the apps info. you'll find the permissions there.
#10 Jon Isaacs
Posted 15 October 2019 - 08:24 PM
:waytogo:
It worked..
Still. it seems to be incompatible with most devices.
What did you think of it?
