Lens Cap For 9 x 50mm Celestron finderscope
7 replies to this topic
#1 TedH
TedH
Posted 11 October 2019 - 07:40 AM
To fashion a solar filter for my Nextstar finder scope, I need a second lens cap.  I have the correct solar filter mylar from a supplier.  Anyone know where I might get one?  Inside dimension is 59mm.  Thanks, Ted
#2 havasman
havasman
  • Loc: Dallas, Texas
Posted 11 October 2019 - 08:27 AM
Agena Astro sells many sizes and several varieties of caps.
  • wrvond likes this
#3 junomike
junomike
  • Loc: Ontario
Posted 11 October 2019 - 12:24 PM
Strange as they list that Finder with a 57.2mm cap.dew Shield  which  Agena carries a 57mm cap.
Here's a 59mm Cap If you decide to go the "inside" way-
Either way, Make SURE it fits properly with no chance of accidentally falling off!
#4 Michael_Swanson
Michael_Swanson
    Author of The NexStar Users Guide
Posted 12 October 2019 - 01:20 AM
Or just make the filter cell from poster board:
https://www.nexstars...roSolarFilm.htm
https://www.nexstars...-build_2017.pdf
I've made 5 or 6 of them and they are still going strong after nearly 20 years of use.
Best regards,
Mike Swanson
Author of "The NexStar User's Guide II"
Author of "The NexStar User's Guide"
Author of "NexStar Observer List"
https://www.NexStarSite.com
  • havasman likes this
#5 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 12 October 2019 - 06:22 PM
I made three the same way about 15 years ago. I added an "adapter" (foam insulation strip) to one and now they fit 4 of my scopes ... well actually 3 scopes and a finder. Simple, cheap, and so far have been very robust, and no front caps have been harmed.
#6 TedH
TedH
Posted 13 October 2019 - 06:38 AM
Thanks for all of the replies.  Hope to find one that works from the sources provided.  Yeah, I'm aware it has to fit exactly right so there is no chance of it coming off.  Made one for my previous Nexstar 8 and it worked fine for many years.  Best to all from the Midwest.
#7 Jim4321
Jim4321
  • Loc: Asheville
Posted 15 October 2019 - 08:04 AM
Summer of 2017, I made a solar finder cap from two cut-down spray can caps.  I found a pair in my junk box that fit snugly one inside the other, with the smaller one fitting snugly onto the 9x50 finder.  After I cut the ends out of both (Dremel tool with saw; leave a small lip on the larger one), I lightly taped a square of solar film over the smaller one, and glued it inside the larger one.  The edges of the film are captured between the caps, and are held quite securely by the glue and lip.  I strongly suspect that it's more durable than the slightly junky store-bought ones with the cardboard ring.
Yeah, I spend a silly amount of time avoiding spending ~$20.  But I enjoy small shop projects, and I'm retired... grin.gif
Jim H.
  • mclewis1 and Ssayer like this
#8 skaiser
skaiser
  • Loc: dallas Texas
Posted 01 November 2019 - 08:49 AM
As another retired person who has time to fiddle....
after reading this track, I designed my own solar filter lens cap for my RACI and 3D printed it at our local library
they are seeing a lot of me since they installed the printers.( they have 4 of them)
amazing what extra parts you can think of to make life easier on the scope when you have the printers available and you don’t have to worry about cost.
(they charge 10 cents per ounce)
so much fun..
