Moon tests - C14 x0.5 and x1.5
6 replies to this topic
#1 Rouzbeh
Rouzbeh
Posted 11 October 2019 - 12:46 PM
Got a 0.5x Optec reducer and its better than I expected.
Used the mid sized 183 camera @ f/5.9.
6 panel Mosaic about 80Mpix.
https://www.dropbox....c info.jpg?dl=0
  • hendric, eros312, Tyson M and 1 other like this
#2 Rouzbeh
Rouzbeh
Posted 11 October 2019 - 12:47 PM
Also got a shot with the 1.5 Siebert for Copernicus.
https://www.dropbox.... WV tu.jpg?dl=0
  • eros312, Tyson M, Foc and 1 other like this
#3 Tom Glenn
Tom Glenn
  • Loc: San Diego, CA
Posted 11 October 2019 - 11:27 PM
Rouz, the image of Copernicus turned out well, and the mosaic shows promise, but something has happened during processing to cause significant quantization error and banding.  This is especially evident along the terminator, but is also present in regions far from the terminator, such as the floor of the Sea of Serenity and elsewhere.  Large regions have been clipped to exactly one pixel value without variation, leading to a series of patches.  How was this image created, because your other lunar images show no signs of these quantization banding errors.
#4 Rouzbeh
Rouzbeh
Posted 12 October 2019 - 02:05 AM
Thanks Glenn,
I had a few problems. First of all not sure why there was a matrix banding pattern with the QHY183. Don't know why there is a Wred, Wgreen and Wblue gain on a mono camera and then the actual gain as well.
The gain was also very low, I suspect that could be why also?
It was still light out so that could be another reason?
I had to do some aggressive noise reduction, that could have caused that quantization error, and some curve stretching made it worse.
The image with the reducer doesn't geometrically match on both side of each panel, that wasn't fun to line up.
Edited by Rouzbeh, 12 October 2019 - 02:06 AM.
#5 Rouzbeh
Rouzbeh
Posted 12 October 2019 - 02:06 AM
FireCapture v2.6  Settings
Camera=QHY183M
Filter=IR685
Profile=Moon
Filename=2019-10-08-1346_5-IR685-Moon.ser
Date=081019
Start=134530.472
Mid=134630.484
End=134730.497
Start(UT)=134530.472
Mid(UT)=134630.484
End(UT)=134730.497
Duration=120.025s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT +4h
Frames captured=1071
File type=SER
ROI=5544x3684
ROI(Offset)=0x0
FPS (avg.)=8
Shutter=3.867ms
Gain=10 (18%)
Brightness=0 (off)
BlackLevel=0 (off)
HighSpeed=off
FPS=100 (off)
Gamma=1 (off)
WGreen=64 (off)
WBlue=64 (off)
USBTraffic=3 (off)
SoftwareGain=10 (off)
TargetTemp=-3
AutoHisto=75 (off)
WRed=64 (off)
Histogramm(min)=0
Histogramm(max)=255
Histogramm=100%
Noise(avg.deviation)=n/a
Limit=120 Seconds
#6 Rouzbeh
Rouzbeh
Posted 12 October 2019 - 02:07 AM
The Qhy with firecapture is slower than sharpcap, you cant lower the USB traffic to = 0 (fastest).
#7 Rouzbeh
Rouzbeh
Posted 12 October 2019 - 04:12 AM
At f/16
