Deck Engineering (...for a backyard observatory)
728 replies to this topic
#1 mmalik
mmalik
    DSLR camera modifications
  • Loc: USA
Posted 13 October 2019 - 05:49 AM
With either POD or NEX in mind (...fill in other similar dome solutions of your choice) I would like to engineer a deck in the backyard. While information to build decks abound on the internet, I have a unique backyard scenario that requires bit more (deck) engineering than usual.
Most observatory decks I have seen are ground level (with varying heights) where ground underneath is somewhat level. I have a situation in the backyards where ground is 'not' level and has somewhat of a steep grade to it.
That't not all; I would also like to cover pier engineering under similar circumstance and expand the discussion to include building a warming solution (e.g., a shed on the deck) for extreme winter conditions, and cover other scenarios that mitigate deck vibrations for any outside-the-observatory viewings. Note: This is in addition to the pier inside the observatory which is also detached from the deck.
In short, I need you help to build a deck that encompasses but not limited to the following:
1. POD or NEX or other similar dome on the deck
2. A warming shed on the deck, but detached from the obervatory
3. An observing area outside the dome (a second pier or tripod area of sort) that is NOT affected by deck vibrations
4. POD or NEX on the deck will be primarily dedicated to DSO imaging at medium or longer FLs
5. While I envision a separate warming shed on the deck, I am open to discussing novel and advanced ideas to adding/extending a warming chamber to POD or NEX that wouldn't affect observatory operations. Kind of a rat hole type solution that leads to a heated extension that doesn't affect observatory milieu.
6. All of this has to be compact enough so that such a deck project doesn't turn into a project that its NOT
7. While warming shed is going to be really compact, it potentially could be used to control observatory operations if needed
8. I am NOT looking for observatory automation or remote operation per se, just having a warm space to shelter-in while managing manual operations at the observatory
9. Observing area on the deck (...outside the observatory) is a very limited space that potentially could be used for small out reach programs of visual observing kind, be it one person at a time
10. As you can tell, whole deck area is going to be quite compact, all structures on the deck also quite compact but main idea is to design some real solutions along the way. and in a budget and scale most could manage
Thanks in advance for your participation; I am hoping we can get very creative with such a project and take backyard imaging/observing to a new level!
Note: More on the deck dimensions, deck design, and area geography next...
#2 thesungazer
thesungazer
    Sungazer
  • Loc: 1AU
Posted 13 October 2019 - 06:58 AM
A couple quick thoughts:
use pressure treated lumber
keep the deck a few inches above the ground
rent a cement mixer. your back will thank you
Edited by thesungazer, 13 October 2019 - 06:59 AM.
  • Starsareus, karateman, mmalik and 3 others like this
#3 mmalik
mmalik
  • Loc: USA
Posted 13 October 2019 - 07:56 AM
Here are the deck initial dimensions; I have shared these in another thread but here we'll get into the details of the deck. Suggestions welcome regarding rectangle size and what's planned for it to contain. Regards
#4 mmalik
mmalik
  • Loc: USA
Posted 13 October 2019 - 08:07 AM
Given the height of the deck (~5' on the high side) and my novelty to concrete, I am thinking of going with wood posts for the deck. I might go for concrete pier for the scope but that's pretty much what my initial thoughts are as far concrete use goes. Please know that I am NO expert when it comes to building any of this; suggestions welcome. I am thinking following for the posts:
Edited by mmalik, 13 October 2019 - 08:13 AM.
#5 lee14
lee14
  • Loc: CNY
Posted 13 October 2019 - 08:28 AM
Wood posts for support are fine. There are three grades of pressure treated lumber, make sure you use the type rated for in-ground. The deck itself can be the type rated for ground contact. Keeping it a few inches above ground is fine, it makes for a simpler installation and leveling. The support posts can be done with minimal concrete work. You should go down below the frost level, but two feet is certainly sufficient to prevent heaving. Keep the width of the holes as narrow as possible. Place a few bricks or flat concrete block at the bottom, tamp them down with the post, plumb the post in two dimensions with temporary supports, empty a single 80 pound bag of concrete mix into the hole and pour a gallon of water over the dry mix. Let it cure for a day and fill the remaining space with soil. This method is commonly used for decks, it's relatively quick, stable, and avoids having to mix and pour concrete.
Lee
#6 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 13 October 2019 - 09:20 AM
So... It's 16x10 and 5 feet high, on the high side? So, is your ground slope actually 5/16 = 17o ? If so, yeah... that's getting quite steep! The 8"x8"x8' PT posts will certainly work... even 6"x6" would be fine. Reinforced concrete/steel all the way up on the scope pier is also prudent.
Your combination of dome + warm-up/control room + deck/outreach functions gets rather grandiose for a small footprint. Might consider going even larger, if you can. The one thing to not skimp on is the depth and population of support posts. More than four is prudent, will never regret ~overbuilding~ for stability and permanence. The space under helps cool-down and seeing a lot! Other than that, think through the details and decide to become semi-expert on construction. A local friend or contractor willing to help on the project would be a prudent plus. That, or contract out the entire build...
My situation is similar, the high side is about six feet above the ground. Here are a couple pictures of that. It has weathered the test of time - going on thirty years... The design and build were entirely my own, with a lot of erection assistance from friends!   Tom
  • mmalik and Stevegeo like this
#7 TOMDEY
TOMDEY
Posted 13 October 2019 - 09:21 AM
nother pic >>>    Tom
  • Jim Davenport, mmalik, Stevegeo and 1 other like this
#8 mmalik
mmalik
  • Loc: USA
Posted 31 October 2019 - 07:12 AM
It appears I went too big with 8x8; way too big and heavy lumber. I had to scale back to 6x6; I am thinking I an increase the number of posts from 3 to 4 along the long side to get the same kind of stability? Regards
#9 Ladyhawke
Ladyhawke
Posted 31 October 2019 - 07:31 AM
My backyard is not leveled. I documented the build of my deck for a Skyshed POD a few years ago. See the thread below:
https://www.cloudyni...pod/?hl=new pod
  • mmalik likes this
#10 mmalik
mmalik
  • Loc: USA
Posted 24 October 2020 - 10:09 PM
Question: What is the best pier plate/bolt solution for concrete pour-in piers. I am looking for something universal and good quality. Basically the metal work that goes on top of the concrete pier? Where can I get it? What are good vendors? Details will be appreciated. Regards
Note: I am waiting on Mach2 which I am hoping should materialize early 2021
On a side note, some useful info I want to preserve...
The pier is an aluminum tube, whipped up by a friend in his Machine Shop. ($250.00 I think). I pulled a few boards off my deck, and dropped a 14" Sonatube into the ground with 3 - ⅝"x8' threaded rods thru the centre of it. The concrete is finished below the deck boards so the only thing coming thru the boards are the rods... double nutted to isolate it from deck movement.
Picture shows it bolted to the deck originally. Deck movement made me do the concrete thing.
#11 Ladyhawke
Ladyhawke
Posted 26 October 2020 - 07:51 AM
For concrete piers, the best solution for a plate (and maybe the only one that I can remember when I was doing my research) is Dan's Pier Plates, I have one and it is as good as it can be and works well for my Mach1 so I'm sure it would work well for your Mach2.
  • mmalik likes this
#12 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 26 October 2020 - 08:16 AM
Dan's pier plates are probably still the gold standard. There are a few examples of mount specific pier plates around (and a bunch of DIY versions) but Dan's products stick around because of support (documentation), quality and flexibility.
  • mmalik and DSOGabe like this
#13 mmalik
mmalik
  • Loc: USA
Posted 26 November 2020 - 03:25 AM
I keep thinking about sinking a portable pier deep into the ground instead of pouring a concrete pier. Would like to hear what folks have to say? Regards
Note: Mount in scope is Mach2
#14 Ladyhawke
Ladyhawke
Posted 26 November 2020 - 06:44 AM
I don't see why would anyone do this. If you don't want a concrete pier, you can make just the concrete base, deep enough to go below the frost layer and high enough to just under your deck or level with the ground then you can buy a metal pier like the ones SkyShed sells and bolt it to the concrete, this way you can remove your pier and cover the concrete base with dirt and grass when you move, if that's your concern. I am linking the post I made with detailed progress of my deck/pier built, it may give you some ideas.
https://www.cloudyni...ry-skyshed-pod/
Edited by Ladyhawke, 26 November 2020 - 06:47 AM.
  • Starsareus and mmalik like this
#15 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 26 November 2020 - 07:43 AM
What is the pier made of?  It is probably steel, which means that, in five or ten years, it will be rusted out.  You don't want to do that to a nice portable pier.
The only way to bury it is to dig a hole, drop it in and back-fill it.  Which means that it will be in disturbed soil, and won't be as rigid as you would like..  A concrete footing can be poured in undisturbed soil and made very rigid.
  • Starsareus, lee14 and Stevegeo like this
#16 mmalik
mmalik
  • Loc: USA
Posted 26 November 2020 - 06:56 PM
I guess I keep beating around the bush (i.e., mount) in terms of NOT having to pour in a concrete pier which I think I'll have to do in the end. Metal pier on top of concrete pier base is a good option to consider.
All of your feedback is greatly appreciated. I have been procrastinating and main reason is that Mach2 hasn't transpired yet. I am hoping I should be a able to secure one in the first half of 2021, may be just in time for the next year's imaging season. Regards
#17 speedster
speedster
  • Loc: Abilene, Texas
Posted 29 November 2020 - 04:21 PM
As Kathy and others have pointed out, burying a tri pier is bad.  You'll ruin an expensive bit of kit and you'll have far more deflection than just putting the pier on the ground.
If you put the POD door on the edge of the deck, so you step up 6"-8" to get in, it's a lot easier to get in and out of that short door.  You don't have to bend over as far.
Let me question your motives for just a moment.  Sometimes (often), we do things because we've seen someone else do it.  That's not wrong, we just accept what we know and don't question the premise.  For a moment, forget you ever saw a warm room.  They have a history but technology has changed and are they still relevant?  We don't accept inferior equipment but don't question putting ourselves in a cramped, poorly finished box with clumsy lighting that is still cold in winter and hot in summer.  If we are doing visual, we are at the scope so no need for warm room.  If we are imaging, a warm room can be considered a torture device from the middle ages.  If we saw one for the first time we might think it a time-out space for naughty astronomers.  Again, they are certainly not wrong but are they the best solution today?  What if you went out,opened the POD, powered up, used a laptop to start CPWI, PHD2, NINA, and VNC viewer, then went back inside to the comfort and space of your home where you set up your sequence, plate solve and slew to target, start your sequence, have dinner, watch Netflix, or maybe enjoy live stacking on the 70" flat screen with guests, and go to sleep whenever you want with NINA completing the sequence, homing the mount, disconnecting everything, turning off power, and shutting down the laptop?  When you wake up, you go out and close the dome.  Other software will do the same thing.  This is just an example of what free stuff will do.  If you have teenagers or your spouse is a dripping faucet and your warm room is your escape, then that is a different story.
#18 MikiSJ
MikiSJ
  • Loc: San Jose, CA
Posted 29 November 2020 - 09:55 PM
Pressure Treat Lumber for ground contact use is UC4(A-C). If you decide to go this route (I would suggest concrete piers instead) then make sure you use a full-mask respirator (such as 3M™ Mold Remediation Respirator Kit 69097) and heavy gauge work cloves for the UC4(A-C) series of pressure treated wood. This is NOT OVERKILL.
A fellow general contractor with many more years experience then I lost two fingers to splinters from contact rated pressure treated lumber (LP4 [an older grade]) that went untreated for a week.
If you decide to use any type of pressure treated wood - DO NOT BURN! The fumes are very toxic.
(I am a licensed General Contractor [1978] and have bought many millions board feet of lumber)
  • lee14 and mmalik like this
#19 mmalik
mmalik
  • Loc: USA
Posted 25 December 2020 - 02:18 AM
Thanks;  burying the tri pier idea is 'out' after listening to you all. Concrete seems to be the answer but I'll elaborate in coming posts what my thoughts are on combining concrete with metal pier.
And off course, very intelligent suggestion indeed about elevated entrance to the POD; much appreciated. These are the kind of nuggets you sometime can overlook quite easily. Regards
#20 Stevegeo
Stevegeo
  • Loc: Otisco lake. Marietta NY 13110
Posted 25 December 2020 - 08:14 AM
I have one for a small mak outside , a brake rotor from a truck with a pipe welded to the center , the mount sits neatly in the other end . And a setscrew secures that . Nice that it's still movable around the yard surrounding my observatory  .
Great for get togethers  , and no tripping over tripods..  if I need further stability , a 1/2 cinderblock does nicely .
#21 aleigh
aleigh
  • Loc: Scottsdale, AZ
Posted 11 January 2021 - 10:46 PM
At the risk of asking the obvious, why do you want the pier at all? Vibration dampening? Isolation? Repeatability on the alignment? If your telescope is of a modest mass you could consider floating another floor for isolation (if that is even a concern) and just using a quality tripod. Bolt it to the floor if you think it will get bumped. I scratch my head as to why people sink these huge blocks of concrete into the ground for telescopes of a man-portable weight.
#22 KLWalsh
KLWalsh
  • Loc: North Georgia, USA
Posted 15 January 2021 - 09:02 AM
I have moved since I build an obs in ‘07 (to a much darker site), but my obs was built on the side of a hill.
First I built a level deck, then I built the ROR obs on the deck. I dug the hole for the pier at the same time as I set in the posts for the deck.
I designed it as a ‘saltbox’ roof obs to give the scope a better view to the southern horizon.
Edited by KLWalsh, 15 January 2021 - 09:07 AM.
#23 mmalik
mmalik
  • Loc: USA
Posted 19 January 2021 - 02:01 AM
I do want to build a backyard observatory (...most likely a ShyShed Pod kind) hence the insistence on a pier. Plus pier provides some level of permanence and consistency so you are not setting things up night after night.
Asking the obvious would be why do I hesitate or resent, for the lack of a better word, pouring in a concrete pier? Answer again is the permeance and eventual non-destructibility of it when needed.
So after much contemplation I have reached the middle ground... pour in concrete below ground and then a metal pier above ground. Details upcoming. Regards
...burying the tri pier idea is 'out' after listening to you all. Concrete seems to be the answer but I'll elaborate in coming posts what my thoughts are on combining concrete with metal pier.
Edited by mmalik, 19 January 2021 - 02:33 AM.
#24 mmalik
mmalik
  • Loc: USA
Posted 19 January 2021 - 02:17 AM
Question: I picked 34" for the above ground metal pier. Is that right height for Mach2 and SkyShed Pod kind of setup? I am not that tall myself, so didn't want too tall of a pier. Plus I don't have visual observing needs; I'll be primarily imaging so bending down or climbing up are not a concern. Thanks in advance on your input. Regards
Edited by mmalik, 19 January 2021 - 02:25 AM.
#25 mmalik
mmalik
  • Loc: USA
Posted 19 January 2021 - 03:19 AM
Here is somewhat wholistic perspective where things are headed. Comments/suggestions welcome. Regards
Note: All dimensions are inches
Edited by mmalik, 19 January 2021 - 06:46 PM.
