Deck Engineering (...for a backyard observatory)
649 replies to this topic
#626 mmalik
mmalik
    DSLR camera modifications
  • Loc: USA
Posted 03 October 2021 - 09:34 AM
The secondary dome (POD)...
Secondary dome sections don't align quite equally on both sides (...with the primary dome). I had to add some washers to off set one side. Otherwise, the dome rubber lining can get pinched/cut in some cases, and as even the manufacturer's install video shows. Regards
#627 archer1960
archer1960
  • Loc: Southern New England
Posted 03 October 2021 - 06:54 PM
I think he means "stagger"
#628 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 08:13 AM
Rubber washer (POD)...
Note: This was an add-on, as recommended, to make the dome bolt waterproof. Make round into square hole in the washer to fit the bolt form.
Edited by mmalik, 09 October 2021 - 04:43 PM.
#629 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 08:18 AM
Waterproofing (POD)...
Edited by mmalik, 09 October 2021 - 08:19 AM.
#630 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 08:24 AM
Before/After rubber sealing (POD)...
Note: Folded pattern 'is' how seals interact when dome is opened
#631 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 08:27 AM
Bolting to the deck (POD)...
Note: Do the bolting 'before' sealing the dome walls to the floor. Otherwise dome can slide on the smooth surfaces like vinyl planks in my case. But don't tighten just yet. 4" 3/4" bolt shown.
Edited by mmalik, 09 October 2021 - 06:37 PM.
#632 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 08:31 AM
Jacking up (POD)...
Note: Once (loosely) bolted down, you'll need to jack up the entire POD to apply the sealant underneath. Bolting is necessary to hold the precise (POD) position on the waterproof flooring.
Edited by mmalik, 09 October 2021 - 08:32 AM.
#633 skullpin
skullpin
  • Loc: Edmonton, Alberta, Canada
Posted 09 October 2021 - 03:52 PM
Really enjoy all the detailed photos... thanks!
  • mmalik likes this
#634 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 05:56 PM
Sealing the (outside) perimeter (POD)...
Note: Class 50 silicone recommended; apply sealant to the entire circumference in one shot and quickly, by lifting the entire structure at each join (as shown above) and then lowering entire structure on top of the two beads of silicone, one on the inside and one on the outside. Bolt down and wipe off the excess silicone to finish.
Edited by mmalik, 09 October 2021 - 05:58 PM.
#635 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 05:57 PM
Sealing the (inside) perimeter (POD)...
Note: Class 50 silicone recommended; apply sealant to the entire circumference in one shot and quickly, by lifting the entire structure at each join (as shown above) and then lowering entire structure on top of the two beads of silicone, one on the inside and one on the outside. Bolt down and wipe off the excess silicone to finish. Two different (inside) joins shown.
#636 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 06:17 PM
Waterproofing the wall base sum-up (POD)...
Vinyl planks with proper sealing as shown above should result in pretty decent waterproofing as far the wall circumference is concerned!
Edited by mmalik, 09 October 2021 - 06:19 PM.
#637 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 06:22 PM
Lock knob (POD)...
Knob holes sometimes don't align quite well; you'll need to widen the open to properly insert knob/s in some cases. Just a bigger drill bit will do the job.
Edited by mmalik, 09 October 2021 - 06:36 PM.
#638 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 06:28 PM
3-Washer solution (POD)...
One side of the secondary dome will require 2-3 washers for properly separating the rubber lining between the two dome sections (as shown) and to operate properly. Rubber lining may get pinched (by design) on one side of the dome without such an intervention!
Edited by mmalik, 09 October 2021 - 06:29 PM.
#639 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 06:34 PM
Insulating (Warming Shed)...
Before and after; work in progress...
Note: Moisture block and inner wall panels to be added later
#640 mmalik
mmalik
  • Loc: USA
Posted 09 October 2021 - 06:35 PM
Insulating cont'd (Warming Shed)...
Edited by mmalik, 09 October 2021 - 06:40 PM.
#641 mmalik
mmalik
  • Loc: USA
Posted 13 October 2021 - 08:38 AM
POD & Secondary Pier wiring...
Note: Stagger down the conduits as you branch out
Edited by mmalik, 13 October 2021 - 02:50 PM.
#642 mmalik
mmalik
  • Loc: USA
Posted 14 October 2021 - 07:03 AM
Vapor barrier...
#643 mmalik
mmalik
  • Loc: USA
Posted 14 October 2021 - 07:09 AM
Inner panel (work in progress...)
#644 mmalik
mmalik
  • Loc: USA
Posted 15 October 2021 - 08:35 AM
Progress on the inside (warming shed)...
#645 mmalik
mmalik
  • Loc: USA
The perspective...
Edited by mmalik, 15 October 2021 - 08:41 AM.
#646 dhkaiser
dhkaiser
Posted 15 October 2021 - 11:16 AM
Your secondary pier next to a drop off seems like an accident waiting to happen.
  • John Fitzgerald likes this
#647 mmalik
mmalik
  • Loc: USA
Posted 15 October 2021 - 04:54 PM
Secondary pier has only Southern view; no one will be going toward the drop off. Plus short side will have stairs/ladder of sort for getting on to the deck, on one side of the secondary pier. All per design. Regards
Note: Metal (secondary) pier to be installed soon!
Edited by mmalik, 15 October 2021 - 05:44 PM.
#648 mmalik
mmalik
  • Loc: USA
Posted 16 October 2021 - 08:09 AM
Door prep (Warming Shed)...
Note: Door came in two sections that could be opened separately; I joined them into one (with metal plates). Of course it didn't have a locking mechanism so I added one (key pad codable).
#649 mmalik
mmalik
  • Loc: USA
Posted 17 October 2021 - 09:02 AM
Door installed (Warming Shed)...
Note: After joining door sections together, sealing seams with rubber spray, insulating, adding lock, and adding inside panel (one unit), it turned out to be a pretty solid door. Should do the job in the dead of the winter!
Edited by mmalik, 17 October 2021 - 06:00 PM.
#650 mmalik
mmalik
  • Loc: USA
Posted 17 October 2021 - 09:08 AM
The morning...
  • niteskystargazer likes this
