Interesting
Can anyone (perhaps denis0007dl) explain if this can reach focus in a Dobson, like an Orion XT8i? Will it have the same problems of requiring a barlow because of focuser travel?
Posted 23 October 2019 - 05:39 PM
Interesting
Posted 23 October 2019 - 07:29 PM
It has a longer light path, so even more so.
Posted 23 October 2019 - 10:58 PM
Interesting
No way it would reach focus, and you will need some GPC, or barlow etc to reach focus.
First you have to measure how much free backfocus you have on your dobsonian.
Posted 05 December 2019 - 07:03 AM
Have there been any early adopter that can report on this binoviewer?
Emil
Posted 05 December 2019 - 12:36 PM
The TS version looks a bit different to the one the OP introduced.
One would assume changes have been made from the proto-type ?
Its now black bodied (to cure the extraneous light issue Denis mentioned ?)
And has gold eyepiece holders. I preferred the black ones, personally. Gold looks a bit blingy.
I must say, i'm sorely tempted. The price has also been reduced further : now around £290 UK / $380 USD
https://www.teleskop...-Teleskope.html
Posted 05 December 2019 - 03:14 PM
The ad mentions that it is T2, so that is a good thing. Yes, at this price, it is a pretty good deal. No one in the US is selling them, and for now, we don't know the exact light path because Dennis said longer than stated, but the ads all say 118.5mm
At 118mm, it might be a tiny bit to long for me to reach focus in native focal lenght mode in my Apo (which is the only place it matters).
Also, it appears that the Baader will come standard with one T2 dovetail and a T2 Quick Connector, and those component on their own sell for over $100. Even with only 25mm, it is likely that any vignetting will be hard to see.
Santa is bringing me a T2 Prism, so once I have that, I can make an accurate measurement of how much light path I would have free. The only scope I would likely use it in for any kind of deep sky observing would be my 106mm triplet (f/6.5) and for planets in the refractor and dob, I would want to use the Televue 2x, so having the dovetail and a Quick Connector would mean only having to buy one more quick connector (one for the T2 diagonal, one for the Televue 2x BV amplifier).
At this point I am leaning to the Baader but keeping an eye open for reviews on this new BV.
Posted 05 December 2019 - 04:56 PM
Posted 05 December 2019 - 05:01 PM
..and good thing: fingernails are djusted well!
Middle plate for adjusting IPD, plate is very thin, not good....and IPD, not working as should.
T2 ring have too much space to make shifts at sides, and its impossible to make strict center.
Also, T2 ring is too fat for lets say small prisms, and then make problems with other side 2" or 1.25" scope side adapter....
But as said, well for price offered, so compromises are here.
Posted 06 December 2019 - 11:15 AM
I just precisely measure light path of TS model, its 12.82 cm, which is very good actually!
Body is, you know, you get what you pay for, and eyepiece holders, if forced with rotation a bit, rotate whole, and can be unscrewed....
Thank you for being able to give a definitive answer. I dislike that the ads are mis-leading, but at least we know the actual figure now.
Well, that is good for a big prism unit, but even with a T2 diagonal, I do not think I would be able to reach focus with my Apo. I think the Baader will, but until I have my T2 diagonal and measure, I won't know for sure, but even with the Baader, I think it would be very close (I still need some space for the Quick Change ring as well, because I want to be able to go back and forth between the Televue 2x Binoviewer amplifier for solar and dob, but T2 diagonal for wide field in the Apo.
I even have my doubt that the Max II will work and if not, I will just stick with the Celestron BVs. I actually don't think I would use the Apo all that much even if it could reach focus with BVs, but it would be nice to have the ability for when I can get under really dark skies.
Again, thank you for getting this info. Hard to trust ads when it comes to stuff like light path.
Posted 06 December 2019 - 02:46 PM
Posted 11 December 2019 - 06:49 PM
About new TS bino: I see I can make apecial adaptation to T2, remove original eyepiece holders, and then add that adapter
https://www.teleskop...--T2-Clamp.html
With that setup, its possible to save some 1-1.5cm more light path, and, whats most important, to prevent unwanted rotation/unscrewing of eyepiece holders from binohead.
How would the resulting light path would compare to the one of the MKV, with the similar T2adapter - T2_clamps!
Posted 06 March 2023 - 05:10 PM
Edited by froeng, 06 March 2023 - 05:11 PM.
Posted 06 March 2023 - 06:08 PM
Posted 07 March 2023 - 04:32 PM
Posted 14 March 2023 - 02:42 AM
AltairAstro sell this, I was wondering if using some heavy duty black vinyl wrap over the white plastic would help with the light ingress, the BV's are £200 cheaper than MBII's, my wife wants to know what I want for my birthday next month.
I have a Bresser AR127L 1200/9.8 that's new (its still boxed!) and never gets used, I was thinking about cutting the OTA, AA quote 'Total optical path distance (without barrel) 118.5mm.' does this mean I need to shorten my tube by this amount as I've noticed using my 2" prism leaves only around 15mm of focus travel left in normal cyclops mode.
Help would be appreciated here.
Cheers
Guy
Posted 14 March 2023 - 02:55 AM
Cheers
Guy
The trick is to measure the distance between the focal plane and the location of the flange when the focuser is fully retracted. This is sometimes called the "back focus" or "in focus". You can get a reasonable estimate by removing eyepieces & diagonals then projecting the moon onto your hand.
If you have 225-230 mm, 1:1 observing should be fine if you select an optically short diagonal - like the Baader T2 Zeiss prism or maybe a Baader BBHS mirror.
If you want to use a 2" diagonal, you will need about 250-260 mm depending on the diagonal you are employing.
You can gain about 25mm if you install the Baader 1.25x glass path corrector.
Posted 02 April 2023 - 04:51 AM
Posted 29 April 2023 - 05:36 AM
Posted 04 May 2023 - 11:59 PM
interesting.. chinese binoviewer but still not available on aliexpress. TS/Altair/Tecnosky shipping to my place is expensive. Have to wait until these arrive on aliexpress. :-)
Posted 26 May 2023 - 03:19 AM
Posted 01 June 2023 - 11:00 AM
Posted 04 June 2023 - 02:14 AM
Posted 15 June 2023 - 09:28 AM
I'd like to see this succeed, and it would be great for amateur astronomy if it did. My personal experience working with manufacturers of RF devices here in California who were sourcing RF components from China is that ~50% of all components tested in China clearly fail to meet the specification in California.
Based on my personal experience, I'm inclined to buy items from China that I can easily tell are performing as expected, but I can't see taking a risk on something like a binoviewer.
I've never been disappointed with any Baader product.
Posted 26 June 2023 - 12:12 PM
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
