Converting from DeepSky to Planetary
5 replies to this topic
#1 jsowens
jsowens
Posted 16 October 2019 - 09:02 PM
I have many years of successful experience doing deep sky AP.  These days I shoot mostly with the Hyperstar and an Atik 460ex on my edge14.
But having shot most of the targets I like, I thought it might be fun to dabble in planetary AP.....the conversion over has been bumpy.
Here's what I've done and where I'm at:
1. Removed the Hyperstar/FW/Atik and dropped-in the secondary.
2. Off the back I built the following train: Starlight crayford > 2.5 barlow > filterwheel > ASI174MM..there are 'rings and things' in-between but the back-focus is correct.
3. Then I moved the primary into rough focus and locked it.
4. Then I drew-back the crayford to 1/2 way, set the micro-touch controller to 1/2 way (30k) and moved the mirco-touch motor off the native focuser and over to the crayford.
5. Rebalanced
6. At this point I'm just trying to to focus so I can perform a collimation.....here’s where I'm stuck.
I'm not used to CMOS imagers and these settings are foreign.  The ASCOM driver for the ASI in SkyX gives me the following options:
- RAW: 8 or 16.  I assume this is bit-depth so I've been using 16
- Gain: 0-240.  I've been keeping it in the middle.
- Offset: 0-240.  Again in the middle
- USB Limit: 40-100.  I have it on 51
With these settings, I can ONLY get an image of Vega (or other suitable bright star) if the exposure if 4 seconds or greater.  Anything less than 4 and no data.  Bin 1x1 and 2x2 both require the 4 sec minimum.
This makes it very hard to autofocus as the @focus3 routine controls exposure time to get to the ADU it decides is best BEFORE moving the focuser.
In the included pic (img1) you can see it starts at 16sec, 8 sec 4 (which, so far so good) but as soon as it goes less no image returns.  Both seeing and trans were average the night I tried.
So I put two questions to the group:
1. Any ideas on why the 4 sec limitation?  I'd really like to be able to focus before trying to collimate.
2. Even when focusing manually I can't get a good result.  Best I can do are these jellyfish stars.  See img 2.  Is this due to the mis-collimation?
Thanks!!!
#2 Dynan
Dynan
  • Loc: NOLA
Posted 16 October 2019 - 09:12 PM
You are correct. Collimation is way off.
#3 thundherr
thundherr
Posted 16 October 2019 - 10:24 PM
you guys send me to school every time i log in.  lol
todays photography lesson..............collimation.
thank you both.
by the time i get my first AP camera i will have a better understanding hopefully.  lol
i have never heard of collimation.   my guess is that it has some thing to do with focus.  lol
i will search for more information about "collimation"  now.
thanks !
#4 jhayes_tucson
jhayes_tucson
  • Loc: Bend, OR
Posted 17 October 2019 - 12:16 AM
Collimation actually does have something to do with focus, which isn't your problem and why it's more precise to describe your problem in terms of secondary misalignment.  In optical terms it's your secondary alignment (in tilt) that is WAY off!
John
  • Glass Eye and thundherr like this
#5 dswtan
dswtan
  • Loc: Morgan Hill, CA
Posted 17 October 2019 - 12:24 AM
BTW, for focus and collimation, you can bump the gain up to the max.
You only need to reduce gain when imaging - and then much less reduced than you would for deep sky (assuming you are lucky imaging, where lots of frames per second is desirable).
It’s good you are having to address collimation up-front, since it’s critical for the high resolutions demanded by planetary - at least it’s somewhat in your control, compared to the other big challenge: seeing! I personally find SCT collimation to be a royal pain still.
  • thundherr likes this
#6 jsowens
jsowens
Posted 19 October 2019 - 07:46 AM
So it sounds like the two issues are both related to collimation
Ill work on that tonight (hopefully)
Thanks all
