Tracking Scope mount question
7 replies to this topic
#1 ParagPA
ParagPA
Posted 17 October 2019 - 10:08 AM
Hello,
I normally use an ED80T w/ a Canon EOS80D.
However, I want to image the NA nebula with a new AP-modified T3i I just received, with a 50-120mm lens (I think - don't have lens in front of me) instead of using the ED80T, so I can get a larger field of view.
What are my options for mounting a guide scope? I still want to do long, guided exposures.
Parag
#2 SilverLitz
SilverLitz
  • Loc: Louisville, KY
Posted 17 October 2019 - 10:12 AM
Mount lens and guidescope side by side:
  • OldManSky and ParagPA like this
#3 Hesiod
Hesiod
Posted 17 October 2019 - 11:28 AM
If the astro mod is just an improved IR cut filter, at 50mm f/5.6 or less it is very doubtful you will ever need the guide, as the most basic devices can get you 5-6' subs (at these exposures risk already to burn brighter areas of the target, and definitely stars, at least those visible by naked eye) .
Even at 100mm can avoid the guide rather easily (I usually takes 2 or 3' subs at 200mm with a simple low end tracker. I do not try longer ones because would "burn" the picture!).
Otherwise I suggest too the side-by-side arrangement: take a dovetail bar and place a quick release clamp at either end (can use Vixen type clamps, or even ARCA ones, which are smaller and lighter)
#4 ParagPA
ParagPA
Posted 18 October 2019 - 07:00 AM
Thanks! It never occurred to me that the tracking mount itself would be good enough. I’m using a CEM40 mount, which tracks well. I’ll try that and keep it to 2-3 minute subs.
#5 NuclearRoy
NuclearRoy
  • Loc: Pittsburgh, PA
Posted 18 October 2019 - 12:53 PM
If you do need to guide, I second SilverLitz's answer.
#6 ParagPA
ParagPA
Posted 18 October 2019 - 02:03 PM
Looks like I'd need to rotate the saddle plate 90 degrees to make this work - but I assume that's possible on the CEM40
#7 View2
View2
  • Loc: Vancouver, WA USA
Posted 18 October 2019 - 02:45 PM
Btw.. I love your counterweights. I've been there.
#8 SilverLitz
SilverLitz
Posted 19 October 2019 - 09:32 AM
Absolutely NO PROBLEM rotating any saddle 90deg.
I setup my G11 (using its integrated bubble levels) getting its home position by leveling both the RA and Dec bubble levels, with saddle in the normal position.  I set the Dec setting circle to 0deg, and then rotate the saddle 90deg, lining up with the Dec setting circle at 90.
