And yet another (weird) Tasco 60mm
accessories
23 replies to this topic
#1 NVDW
NVDW
Posted 20 October 2019 - 04:59 AM
I really don't find a lot about this one at first glance.
Is it a spotter scope or can it be considered as a telescope?
2573bb93eb301f7e6679e925862f4eeb.jpg733c227e51db8ea2f7ddf1748ee0c32b.jpg4505837eee5a45d33e02356572bd38df.jpg
Verstuurd vanaf mijn MI 8 met Tapatalk
  • Bomber Bob and retroman2 like this
#2 walter a
walter a
  • Loc: Prawda Manitoba Canada
Posted 20 October 2019 - 05:13 AM
Nice find. #88TEZ came with 4x15 finder.
#3 Kiriakos_GR
Kiriakos_GR
  • Loc: Central, Greece
Posted 20 October 2019 - 05:21 AM
I do not see anything weird, I am personally related to 60D diameter for more than 90 days.
60X and spotting scope description this is defined due the limited in potentials mount and the missing focuser.
  • retroman2 likes this
#4 NVDW
NVDW
Aha some more info. Thanks!
So what can it be considered as?
Optics seems kinda hazy. I noticed it was wet since the guy I got it from, kept it outside.
I hope it just needs some time to settle.
Edit:posted at the same time :) Never seen a spotting scope with a finder.
Edited by NVDW, 20 October 2019 - 05:23 AM.
#5 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 20 October 2019 - 09:30 AM
Is there a maker's mark on that ring with the description?  Some of these had a simple Sight Tube with ring brackets, rather than a peep sight.  Over the years, I've seen 2 of these with the Eikow mark, and both had real 10mm finder scopes.
#6 Richard O'Neill
Richard O'Neill
Posted 20 October 2019 - 09:51 AM
 What's in a name? It all depends on how it's used. From my point of view it's a telescope, mounted for terrestrial use.
#7 NVDW
NVDW
Posted 20 October 2019 - 09:55 AM
It's a Tasco but I will check for other markings.
I hope I can find a suitable finder scope too but a quick search on eBay only gives me riflescopes :)
As soon as I can, I point this thing up to the sky!
Edited by NVDW, 21 October 2019 - 02:24 AM.
#8 Kasmos
Kasmos
  • Loc: So Cal
Posted 21 October 2019 - 03:01 AM
Since it's made for straight through viewing it's a (terrestrial), spotting scope. Spotting scopes typically have a range of about 15x-60x. Also, it's not designed for astronomy since it won't accept a star diagonal. BTW, Variations of it are fairly common and turn up quite often on ebay and Craigslist.
#9 sdedalus83
sdedalus83
Posted 21 October 2019 - 05:25 AM
https://www.cloudyni...60mm/?p=6730738
Here's a similar one converted for astro use.
#10 NVDW
NVDW
Posted 21 October 2019 - 06:15 AM
Any idea where I can find a correct finder?
#11 Chuck Hards
Chuck Hards
Posted 21 October 2019 - 08:10 AM
Let me look in my parts bin when I get home tonight.  As has been mentioned, the finder may be a non-magnifying peep sight.  Just a hollow tube.  If I find one, I'll post here later.
Are you in Europe?
#12 NVDW
NVDW
Posted 21 October 2019 - 08:16 AM
Yup, I'm in Europe. I like things original but sometimes you need to adapt :)
#13 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 21 October 2019 - 08:30 AM
What is the ID of the finder brackets, and how far are they apart?
#14 NVDW
NVDW
Posted 21 October 2019 - 08:32 AM
Will check tonight when I'm home from work.
#15 Chuck Hards
Chuck Hards
Posted 21 October 2019 - 09:07 AM
They are very small and not much room to adjust, that's why I'm leaning toward non-magnifying sight tube.  I've pulled a few of them off of older Tascos.
#16 NVDW
NVDW
Posted 21 October 2019 - 12:11 PM
The only mark I find is a circle T
#17 Bomber Bob
Bomber Bob
Posted 21 October 2019 - 12:54 PM
Okay, so it's a TOWA version.  Lens quality varies widely with (T) fracs.
#18 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 21 October 2019 - 12:58 PM
It looks similar to this:
https://www.cloudyni...6560_116745.jpg
Edited by Garyth64, 21 October 2019 - 01:58 PM.
  • Chuck Hards, Bomber Bob and Kasmos like this
#19 NVDW
NVDW
Posted 21 October 2019 - 01:12 PM
The weather is bad now here so the view isn't good either but the image seems a bit foggy compared to my other 60mm Tasco refractor
#20 Chuck Hards
Chuck Hards
Posted 21 October 2019 - 07:02 PM
Well I'll be darned.  It's a real telescope.  Non-achromatic objective lens explains the length.  Very narrow field, dim.  I doubt you could find anything but the moon and Venus in it, maybe first-magnitude stars and planets.  Labeled 4X.  The brackets fit a 60mm OTA.
I found this example in my box of small finders.  There is provision for wire cross-hairs but they are missing on this one.  This could be vastly improved with a surplus achromat objective and replacing one of the eyepiece lenses with an achromat.
  • Bomber Bob, Garyth64 and Kasmos like this
#21 NVDW
NVDW
Posted 21 October 2019 - 10:52 PM
Now that is the thing I need it seems :) Would you part with it?
Altering this scope is way beyond my skills though.
Edited by NVDW, 22 October 2019 - 02:14 AM.
#22 Joe Cepleur
Joe Cepleur
  • Loc: Dark North Woods
Posted 22 October 2019 - 02:10 AM
You can handle this! Just screw the finder into place. A different, but better, finder would screw in place just as easily.
  • Chuck Hards likes this
#23 NVDW
NVDW
Posted 23 October 2019 - 01:56 AM
Would you sell this :)?
#24 Chuck Hards
Chuck Hards
Posted 23 October 2019 - 09:12 AM
Would you sell this smile.gif?
Check your PM's
  • Bomber Bob likes this
Also tagged with one or more of these keywords: accessories
