QHY5-III 178 Guiding Camera setting with PHD2
1 reply to this topic
#1 carlosgib
carlosgib
  • Loc: Southern Spain
Posted 21 October 2019 - 06:05 AM
I have a miniguidingscope attached with a QHY5-III 178, I wanted to know if its necessary to include a 'Gain & Off-set setting to improve the image view to bring up the most faintest stars, as well as should I bin at 2x2, will this give me any sort of advantage over 1x1 bin,Also, I am setting up PHD2 and wanted to know how to calculate the Calibration steps and distances in the distance calibration parameters under advance setup.
F/Length :130mm
F4.3
QHY5:Pixel Size 2.4um
Resolution: 3.81/pix
Any suggestion will be appreciated.
Charles
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 21 October 2019 - 06:31 AM
https://openphdguidi...htm#Guiding_Tab
Use the Advanced button.
Or if you have used new-profile-wizard then you should already have done all the necessary steps.
  • lbim and PatrickVt like this
