NexStar 6SE - M33 with a Weird Semi Circle Shadow along the Bottom when Imaging
astrophotography
5 replies to this topic
#1 lkannard
lkannard
Posted 21 October 2019 - 12:01 PM
I took the images with a Celestron NexStar 6SE, the 6.3 Focal Reducer, and a Nikon D7100.  This was my first time to use the Focal Reducer.
I stacked thirty two, 25 second subs of M33 in DeepSkyStacker and out popped this when I was processing in Gimp. I see a Weird Semi Circle Shadow along the Bottom.
I never got a shadow like like until I tried the Focal Reducer.  I have tried to use my Colombo like investigation skills to try and figure out want is causing the shadow, but I can't.
Could it be collimation and the semi circle line is the secondary mirror?  Any help would be much appreciated.
M33 with Weird Semi Circle Shadow along the Bottom
#2 cmooney91
cmooney91
  • Loc: Massachusetts
Posted 21 October 2019 - 12:33 PM
Only thing I can think of is a hair on the reducer lens causing a shadow
  • lkannard likes this
#3 Gary Z
Gary Z
  • Loc: New Mexico
Posted 21 October 2019 - 01:24 PM
Have you looked closely at the FR?  Which Focal reducer are you using, Celestron? Do any flats?  Were your camera settings the same as they are without the FR?
Gary
#4 junomike
junomike
  • Loc: Ontario
Posted 21 October 2019 - 02:46 PM
Second the "hair" theory.  Looks like it to me.
#5 lkannard
lkannard
Posted 21 October 2019 - 08:57 PM
I like the Hair Theory.  I will investigate.  Einstein might not have figured this one out.
#6 lkannard
lkannard
Posted 25 October 2019 - 02:41 PM
The verdict is in, and yes, it was a single strand of hair.
On Wednesday I was taking daytime images of the Moon.  I had my head under a towel for darkness.  When I turned on Live view on my Nikon D7100, what did I see?  That pesky semi circle shadow in the display.  So I knew the obstruction was on the DSLR and not in my 6SE or on the Focal Reducer.
So after removing the T-Adapter and T-Ring and looking on the sensor with the mirror being up, I could make out the hair laying across the sensor.  Using a squeeze bulb, I was able to get the hair removed.
All is well with the world again.
  • saguaro likes this
Also tagged with one or more of these keywords: astrophotography
