Rule of 500 with DSLR on SV80 Access telescope
1 reply to this topic
#1 perezbenitoa
perezbenitoa
Posted 21 October 2019 - 06:44 PM
hi all: I am interested in getting started with basic imaging using my canon DSLR (crop sensor), my 80mm refractor telescope (Stellarvue SV80 Access), and AVX mount.  I have been going through lots of tutorials/videos on astrophotography with DSLR and have learned about the rule of 500. Every instance of this rule, has been used with DSLR camera lenses. When I use this rule of thumb with my telescope, the numbers don't make sense to me and not sure what I am missing or how to adapt for use of eq mount.   I plan to use my telescope with 0.8 focal reducer, which results in 448mm foca length.  then accounting for crop factor of Canon DSLR (1.6), I get 716, which results in shutter speed of <1seconds.  I know that using an eq mount, I can have much longer shutter speeds. Is there an alternate rule of thumb to use when using an eq mount or am I using the formula incorrectly?
#2 bobzeq25
bobzeq25
Posted 21 October 2019 - 07:15 PM
The rule is for a camera/lens on a tripod.  You're using a mount with electric motor tracking, it simply does not apply.
If you haven't gotten the mount yet, I urge you to spend a few hundred more on a Sirius/HEQ5, or an iOptron 30PRO.  You'll be amply repaid in less frustration and better performance.  The mount is the most important part of the setup.  It's quite unintuitive how good a mount is needed, and what it costs to make a mount that good.
There's no similar rule of thumb with an electric mount.  You'll be shooting many subexposures, and determining the proper length of each is a site specific process, to be learned.  Part of the fun, but complicated, hobby.  This book will be quite helpful.
https://www.amazon.c...d/dp/0999470906
Edited by bobzeq25, 21 October 2019 - 07:18 PM.
