40 Eridani
13 replies to this topic
#1 tchandler
tchandler
Posted 24 October 2019 - 09:15 PM
Last year I observed this, the most fascinating triple star of them all. The two brighter components were easy but I’m not sure I glimpsed the faintest member.
40 Eri consists of three dwarf stars.
1. 40 Eri A: mag 4.42 dwarf solar type star. One of the few in the sky that are naked eye.
2. 40 Eri B: mag 9.72 white dwarf. One of the easiest white dwarfs visible in the sky.
3. 40 Eri C: mag 11.2 red dwarf.
The A-B and B-C distances are 83” and 9”, and incidentally the latter is near its maximum separation.
Going to use as much magnification as possible. Using 11” Teeter dob f/4.5.
Sky conditions fairly dark - bortle 3-4. Will have to wait until after midnight tho, and so close to Halloween. Spooky.
  • payner, R Botero, eros312 and 3 others like this
#2 chrysalis
chrysalis
  • Loc: North Central NC
Posted 25 October 2019 - 09:37 AM
Will look for this one next time!
#3 ssmith
ssmith
  • Loc: Colorado
Posted 25 October 2019 - 01:44 PM
This system is the home of Star Treks' Mr Spock and quickly becomes a favorite of anyone who views it.
Here is a link to a previous thread.
Edited by ssmith, 25 October 2019 - 01:52 PM.
  • tchandler, flt158, Far Star and 1 other like this
#4 tchandler
tchandler
Posted 27 October 2019 - 07:54 AM
Jim Kaler has an entertaining and informative write up as well about Keid, Omicron 2, or 40 Eridani.
  • c2m2t likes this
#5 Waddensky
Waddensky
  • Loc: The Netherlands
Posted 27 October 2019 - 08:09 AM
Thanks, I really need to revisit this enigmatic triplet soon. B is much dimmer than Sirius B but evidently a lot easier to observe. Indeed a nice opportunity for those who wish to see a white dwarf with modest equipment!
  • tchandler and Tyson M like this
#6 gfeulner
gfeulner
  • Loc: Bergen county, New Jersey
Posted 12 January 2020 - 11:10 PM
I observed this beautiful triplet tonight with my 140mm refractor. The sky was hazy but the C companion was visible.
Gerry
  • tchandler and flt158 like this
#7 c2m2t
c2m2t
  • Loc: Pembroke, Ont.
Posted 13 January 2020 - 05:45 PM
Hi All!
I was surprised to discover that this system has actually 5 components. D & E were added in 1850 as part of a proper motion study. I did check my own image archive and with a bit of stretching, I think both D & E at mags 12.62 and 12.99 are resolved. I have not added the image here, suspecting that the reduced file size would render D & E a washout. But for the heck of it and prior to the  knowledge of the high proper motion of D & E, I consulted Aladin to locate this pair using the distance tool. Needless to say the most recent positional data 1998 provided positions that did not coincide with what I figured were D & E. Two stars having what appears to be the correct magnitudes were close so I figured something was up.
At this point I have to admit my lack of knowledge in manipulating the proper motion tools within VizieR so I went about it the old fashioned way...plotted D & E positions for 1850 and 1998 based on the first and last separation and PA data, available in the WDS/Stelle Doppie. This I have plotted on the image and drawn a line indicating the proper motion/direction for both D & E. WOW!! Right away one could be very easily persuaded that D & E are physically bound. Trajectories through space look identical. For the "halibut", I used the distance tool in Aladin to calculate the angle and distance for the two trajectories. They are oh so close. Angle and distance are as follows:
line D-D  34 degrees, 9.994 minutes
line E-E  33 degrees, 9.988 minutes
This pretty much tells the story...but given that no-one has identified this pair after all the detail searches of the new GAIA data, this pair may have significantly different trajectories perpendicular to our field of view. In any case...an interesting possibility.
Cheers, Chris.
  • Inkswitch and eros312 like this
#8 ssmith
ssmith
  • Loc: Colorado
Posted 13 January 2020 - 07:05 PM
Hi Chris -
The GAIA data shows that D & E certainly have no physical relationship to 40 Eridani and also that they have no relationship to one another.
Their proper motions are radically different and they are separated by over 1,000 Ly.
Edited by ssmith, 13 January 2020 - 08:04 PM.
#9 c2m2t
c2m2t
Posted 13 January 2020 - 08:13 PM
Hi Steve!
Happy New Year by the way! Thanks for that? I suspected as much but it was still an interesting study?
Cheers, Chris.
#10 dmdouglass
dmdouglass
  • Loc: Tempe, AZ
Posted 13 January 2020 - 09:00 PM
This target "Keid", or STF 0518 is another of the targets in the AL Multiple Star Program. I imaged this target on Dec 15....
  • eros312 likes this
#11 Far Star
Far Star
  • Loc: Germany
Posted 15 January 2020 - 04:33 AM
40 Eridani
Photo taken on 12/30/2019 with Canon EOS 800D, Takahashi FC-100DL (100/900 mm) and 1.6x Barlow, ISO 6400, 1 second exposure time
In 2018, a planet was discovered orbiting 40 Eridani A with a minimum mass of 8.47±0.47 Earth masses. Contrary to what many media said, this planet could not be Mr. Spock's fictional home planet "Vulcan" because it orbits its host star outside the habitable zone. The planet has an orbital period of 42 days and is considerably interior to the habitable zone - that is, too close to 40 Eridani A for habitability. It receives 9 to 10 times more sunlight than Earth, about five times that of Venus and more than Mercury.
https://www.geekwire...er-earth-spock/  (See "Update for 5:25 p.m. PT Sept. 26")
https://en.wikipedia...wiki/40_Eridani
Greetings from Upper Bavaria,
Ulrich
Edited by Far Star, 15 January 2020 - 04:55 AM.
  • payner, gfeulner, dmdouglass and 3 others like this
#12 fred1871
fred1871
  • Loc: Australia
Posted 15 January 2020 - 08:05 AM
Nicely imaged, Ulrich. Good scale, and enough exposure for both the lesser stars.
I've seen both companions easily with an 18cm refractor, and there are reports of seeing them both with 10cm. The separation is quite wide, as the photo shows - it's mainly a matter of light-gathering to reach the mag 11.5 dimmer C star.
  • Far Star likes this
#13 Uwe Pilz
Uwe Pilz
  • Loc: Leipzig, Germany
Posted 20 January 2020 - 02:58 PM
Thank you for pointing at this interesting multiple. This night the air was clear and more ore less steady. I tried what I could detect with my 4 inch refractor. A and B were easy, I could see them at 144x. At 288x I could get a glimpse of C. This required A being outside of the filed of view.
My sketch is mirror reversed.
  • gfeulner, tchandler and flt158 like this
#14 tchandler
tchandler
Posted Yesterday, 06:28 PM
Very nice photo - and thanks for the links too Ulrich. The so-called super Earth sounds more like a super Mercury.
According to Jim Kaler, the  mass of the white dwarf when it was hydrogen-fusing is thought to have been around one solar. 40 Eridani B is not what the Sun will not be.
Thanks for sharing your sketch Uwe. I’m looking forward to seeing the trio again soon.
