Photo of Mu Cygni
10 replies to this topic
#1 Far Star
Far Star
  • Loc: Germany
Posted 26 October 2019 - 06:09 AM
Last night I took the following photo of Mu Cygni (m = 4.75 / 6.18, sep. (2020.0) = 1,46"), single frame with Canon 800D, APM 140/980 mm SD-Doublet @ f/23 (3.3 x Barlow), ISO 6400, shutter speed 1/250 second:
Clear Skies,
Ulrich
  • The Ardent, R Botero, Sky Muse and 9 others like this
#2 flt158
flt158
  • Loc: Dublin, Republic of Ireland
Posted 26 October 2019 - 07:42 AM
That's an astounding image, Ulrich.
There are 3 stars here.
A and B are seriously tight almost in a north - south direction.
C is not visible of course. It's too faint.
But D is! Its magnitude is 6.9 at a PA of 44 degrees.
Mu Cygni is one of your best yet, Ulrich.
Thank you very much.
Clear skies,
Aubrey.
#3 Far Star
Far Star
  • Loc: Germany
Posted 26 October 2019 - 04:20 PM
Thank you for your kind words, Aubrey.
  • flt158 likes this
#4 ssmith
ssmith
  • Loc: Colorado
Posted 28 October 2019 - 07:06 PM
Hi Ulrich -
I am having some trouble interpreting your photo. Like Aubrey, I can see three star-like images but their location and scale makes me wonder what exactly you captured.
Are you saying that you captured A,B & D as Aubrey alluded to or only A & B?
The problem arises when you compare the separation of the purported AB pair with the fainter 3rd star which would have to have a separation 123 times the A-B separation if it were D (1.7” vs 197”).
My thought is that one of the images on your photo may be a phantom or ghost image created due to the vibration of the shutter or wind or just unsteady seeing. I have seen this on some of my photos of close pairs.
What is your image scale?
Below is a photo of Mu Cygni that I took which shows just how extreme the separation is between the AB pair and the D component, which barely registers on my photo. I calculated the image scale on my photo to be ~0.16” per pixel after resampling.
It is hard to reconcile my image with yours.
Edited by ssmith, 28 October 2019 - 07:08 PM.
  • gfeulner, dmdouglass and flt158 like this
#5 Far Star
Far Star
  • Loc: Germany
Posted 29 October 2019 - 05:05 AM
I cannot see a third star in my photo. If you see a third dot, it's probably an artifact that occasionally occurs at such high ISO (6400).
I took the photo with a Canon 800D, a 140 mm refractor with a focal length of 980 mm (f/7) and a Baader Hyperion Barlow. The native magnification factor of the Barlow is 2.25x. Between the camera and the Barlow I inserted a 40 mm T2 extension (see the following photo). As a result, the magnification factor of the Barlow lens was increased from 2.25x to about 3.3x (I have tested this). Therefore, the focal length was about 3,200 -3,250 mm.
Hence the focal ratio was about f/23. Since the pixel size of the Canon 800D's sensor is 3.7 microns, the focal ratio of f/23 equals about 6 times the pixel size in microns. So I followed the rule of thumb recommended by Jerry Lodriguss in this article:
https://www.skyandte...ooting-doubles/
Edited by Far Star, 29 October 2019 - 05:20 AM.
#6 ssmith
ssmith
  • Loc: Colorado
Posted 29 October 2019 - 08:15 AM
Here is what we were seeing and interpreting as 3 stars:
There is clearly a bit of image bounce and that is why some of us were unsure of what exactly you were showing us.
That is a fine split of the AB pair.  If you have the ability to stack multiple images you could clean up the image even more.
#7 Far Star
Far Star
  • Loc: Germany
Posted 29 October 2019 - 08:42 AM
Oh, I see! I think my mount (Vixen SX2 on Berlebach UNI 18) is not stable enough for the 140 mm refractor. Perhaps I need the SXD2.
Which camera do you use? Which software do you use for stacking?
#8 ssmith
ssmith
  • Loc: Colorado
Posted 29 October 2019 - 09:17 AM
Ulrich -
There are several free stacking packages available such as AutoStakkert:  http://www.autostakkert.com/
I have also done manual stacking of a few frames using PhotoShop or Photoshop Elements where each photo is made into a separate layer and then the layers are blended.
My go-to photo processing software is PixInsight.
The camera I use is an Olympus E-PL5.
#9 Far Star
Far Star
  • Loc: Germany
Posted 29 October 2019 - 10:04 AM
Thanks Steve!
#10 flt158
flt158
Posted 01 January 2020 - 02:12 PM
Hi Steve and Ulrich.
I have just come in from observing Mu Cygni.
I had not studied it since August 2016.
My William Optics 158 mm F/7 apochromatic refractor was splitting it at 167X and 225X.
At 140X the 2 stars were overlapping one another.
But I kept going "wow, wow, wow" as I sussed its colours.
A is yellow - white. B is pure yellow.
The spectral classes are F6v and G2v.
The C star is invisible.
But the D star is good and gives me assurance I have the correct star.
It's the 1st January 2020 and I already have a real winner here over in Ireland.
Happy New Year all round to you all from Aubrey.
  • Far Star and bsae06 like this
#11 dmdouglass
dmdouglass
  • Loc: Tempe, AZ
Posted 01 January 2020 - 06:39 PM
This target (Mu Cgy) is indeed an interesting one.
Also known as STF-2822, and more specifically, the entire "complex" is known as WDS 21441+2845
And also, Herschel H-3-015.  Thus, as a Herschel object, on my target list.  I imaged it back in Aug 2018.
I gave up trying to catch AB. But there are 6 pairs in the group:  AB AC AD AF AG and BD
I wanted to capture as much of that as i could.
My image was with an Edge 8", using an SBig 8300m, binned 1x1, with a resolution of .23 ArcSec/Pixel.
The shown FOV is 13x10 ArcMin. I was using a 2..4x Barlow.
To catch the dimer ones... i decided to use a 60 sec image, and stacked 8 of them.
Here is what i caught and measured:
Edited by dmdouglass, 01 January 2020 - 06:40 PM.
  • ssmith, flt158 and Far Star like this
