Correcting a 16" flat to correct a 16" paraboloid
82 replies to this topic
#76 ccaissie
ccaissie
  • Loc: Whitefield, Maine
Posted 09 November 2019 - 05:59 AM
 Figuring a 16 inch flat to where it's not going to affect the DPAC is no easy task.  IMHO it would be easier to find a location where you could test vertically and use the immersion null although that over 12 feet high.
Great video and setup.  I have just the stairway needed.  Thermals might be an issue....
I was at the Stewart Mirror Lab back in the 90's and saw a couple of 6 meter mirrors being tested...they were set up vertical also...didn't see any water in them...8^)
Edited by ccaissie, 09 November 2019 - 06:01 AM.
#77 BGRE
BGRE
  • Loc: New Zealand
Posted 09 November 2019 - 06:12 AM
Thermals aren't an issue with an interferometer if the air is well stirred, short exposure interferograms are taken and the computed wavefronts/surfaces averaged.
#78 Pinbout
Pinbout
Posted 09 November 2019 - 06:28 AM
Nope...see picture of ugly ronchigram...that's the unit in question...one of Meade's finest.
It’s not that ugly, and easy enough to fix better than 1/2~ before thinking about dpac, by just using ronchi at RoC for testing.
#79 ccaissie
ccaissie
Posted 09 November 2019 - 08:10 AM
I could improve it by just taking the kink out with a 6" lap in 10 minutes, like you say, without testing...just winging it.  Since I got mirror #1 real good, I don't doubt I can correct it without the elaborate setups, but heck...there's more to ATM than just making usable mirrors....
Re: thermals...BGRE doesn't understand my use of a woodstove downstairs pouring heat through the aperture of my spiral staircase....I think it's a show-stopper, but intriguing to implement the Holloran water test, no?  Again it's a test that requires accurate setup, like the Waineo, the Offner, and others.
I'm looking for dead-on simple and error-proof visual null testing.  Sphere-then-flat-then DPAC.  Like Foucault-on-a-sphere-simple.
#80 Pinbout
Pinbout
Posted 09 November 2019 - 09:32 AM
I said before you think about using dpac, not instead of
a pcx lens as a Ross null is very simple.
Edited by Pinbout, 09 November 2019 - 09:33 AM.
#81 BGRE
BGRE
  • Loc: New Zealand
Posted 09 November 2019 - 05:14 PM
It shouldn't be a show stopper for interferometry if the air is sufficiently well stirred within the air column encountered by the test and reference beams and sub millisecond exposures are used. A simple plastic shrouded vertical test tunnel will not suffice. Lots of suitably disposed fans and a muslin screened vertical tunnel could be made to work. However its probably simpler easier and cheaper to use a horizontal test path with a smaller number of fans. In the presence of turbulent air a simple visual test isn't feasible. Some averaging is required. With a horizontal test path vertical stratification of the air will be problematic with any optical test.
#82 Ed Jones
Ed Jones
  • Loc: Sin-sin-atti
Posted 10 November 2019 - 10:15 AM
I'd bet a plastic shroud would work given some time to stabilize.
#83 BGRE
BGRE
  • Loc: New Zealand
Posted 10 November 2019 - 04:47 PM
Plastic tunnels by themselves, at least the horizontal variety, tend to be significantly worse than just stirring the air well coupled with averaging.
