older rubber coated C-90
4 replies to this topic
#1 grif 678
grif 678
  • Loc: NC
Posted 31 October 2019 - 05:28 PM
Kicking around the idea of getting one of the older rubber coated Celestron C-90 spotters, have several I have seen, but would like some reviews from owners of these supposedly good scopes. They come with the 45 degree diagonal, which is OK with me. I just want something that I can take about anywhere out in the field, pretty rugged, and gives god planetary views etc.
#2 RyanSem
RyanSem
  • Loc: Lancaster, PA
Posted 31 October 2019 - 05:37 PM
I have one of the orange versions of this scope and my only complaint is that it's a little bit annoying to get into focus, but perhaps mine just needs to be oiled. Otherwise it's a very solid scope for its size, I get really great views of the planets out of it, which is sort of its niche. It's ridiculously portable because of its size.
I'm not sure if the black C90s use a smaller size EP, but I got a 0.975" to 1.25" converting diagonal so I could use my regular EP set with it, and I haven't come across any problems.
#3 jaraxx
jaraxx
Posted 31 October 2019 - 06:05 PM
I use an Orion Apex 127mm Mak that fits this bill. I've travelled across the western US, forest road and jeep trail, and had no problems with mine. (It's a little heavier, eight pounds, but not bad at all.)
#4 petert913
petert913
  • Loc: Silverton, OR
Posted 31 October 2019 - 07:45 PM
The newer C90 (black) uses standard 1.25" eyepieces.  And focusing is more typical Celestron style.  I like mine a lot.
  • Binojunky likes this
#5 harbinjer
harbinjer
  • Loc: Southeastern Minnesota
Posted 01 November 2019 - 10:54 AM
The rubber armor will add weight that isn't necessary. You could use a padded backpack, or wrap it in a blanket, and then the added weight isn't mounted on the tripod, which can thus be lighter.  I have a non-rubber black C-90 and am satisfied with the views. It is very compact, especially if you take off the dew shield.  I really should critically compare it to a few others near its size, but haven't yet.
  • Moonlight in Vermont likes this
