Meade 390 Questions
5 replies to this topic
#1 makscopes
makscopes
  • Loc: South Florida
Posted 05 November 2019 - 08:37 AM
Hi everyone.
I just got a Meade 390 refractor for $35 off of OfferUp. The scope looks to be in great shape given its age.
I do have a few questions however.
1. Can the supplied tube rings be adapted to accept a Vixen dovetail?
2. Will a Unistar Light be able to handle the weight of this scope?  I have the Unistar Light on a very sturdy wood tripod.
Any insight will be appreciated!
Milton
Edited by makscopes, 05 November 2019 - 08:39 AM.
  • rolo likes this
#2 beanerds
beanerds
  • Loc: Darwin Australia
Posted 07 November 2019 - 06:18 AM
I grabbed one of these way back in the mid/late ? 90's for my middle Son to test his growing interest in astronomy and optically it was pretty good , terrible diagonal and eyepiece but when supe'd up with a quality Mizar prism diagonal and Zeiss eyepieces it performed really well .
My advice is for this price  ,   grab it and definately  try the Unistar as the supplied Meade ( early Chinese ) mount ? tripod are rubbish , sorry to say .
My Son's passion for astronomy lasted for about 12 month's then he discovered girls . A different kind of passion ,,,,
I can't remember what happened to it now , I think it was gifted to a nephew or something ?
Beanerds.
#3 grif 678
grif 678
  • Loc: NC
Posted 07 November 2019 - 01:35 PM
I think the vixen altaz rings are designed like the c-80 rings. Both rings have a place about 1 inch long that has been raised up about 1/2 inch from the rest of the ring. I believe one ring has this place on the top, while the other has it on the bottom. All you have to do is drill a hole in each of those places. Then put a bolt through that will fit the threaded holes in the vixen dovetail. Then put the rings back on with those two places on the bottom. That extra 1/2 inch recessed place in the ring will allow for a bolt head room, and it will not tough the OTA.
#4 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 07 November 2019 - 03:09 PM
"Can the supplied tube rings be adapted to accept a Vixen dovetail?"
Yes, I believe that they can.
Here's my 395, with what I think are the brackets that  you have on your 390.
Where the bottom of the bracket goes thru the Edmund flange, there's a tapped hole in the bracket that has metric threads.  The top of the bracket is also tapped but they are for 1/4 -20.
I just ran a long enough bolt thru bottom of the bracket and thru the flange.
I'm sure you can come up with something that will work.
Also, I just purchased these brackets for my 395.  These brackets slide onto the tube.  I had to unscrew the lens cell. But what I found out was that they do not fit tight!  I solved the problem by  separating the felt under the top of the bracket where a 1/4-20 bolt would go.  I inserted a small piece of flexible thin plastic between the felt and the bracket, and screwed in a 1/4-20 bolt into the top of the bracket.  Now, I can tighten the bolt down against the small piece of plastic, and it tightens down onto the tube without marring the tube.  I did that to both brackets, and it hold the OTA very good.
One more thing.  I found that the bottom of these brackets were not flat or square to the rings.  A little filing took care of that.
Edited by Garyth64, 07 November 2019 - 03:18 PM.
  • makscopes and bbqediguana like this
#5 makscopes
makscopes
Posted 08 November 2019 - 08:37 AM
Thanks for the replies! What I am finding is when I take the scope off of the mount or loosen the set screws, the rings become loose on the scope. Is this normal? I am going to try fastening them to a dovetail to see if I can get them to stay snug to the scope.
#6 makscopes
makscopes
Posted 08 November 2019 - 08:43 AM
This answers my question perfectly. Thank you.
  • Garyth64 likes this
