For informations on old designs : glasses have notably changed from 1880 to 1930 and more again now.
From what I found.
Some words :
F2 glass is a german Schott optimisation of "Dense Flint", it may differ from time to time.
Chance Hard Crown was also known as "english telescope crown", a very good glass close to german K7 but better.
The classic doublet was Chance Hard Crown + Dense Flint, dispersion matching is better than BK7-F2 or K7-F2
BAK1-F2 is the favorite combination of RF.Royce.
1880
1907 Source A.König, these are Schott/Zeiss ordinary's telescope glass just before Schott tuned the BK7 (known when it starts as the "white" borosilicate crown).
BK7 needed some years to be stabilized (bubble free) so I believed it was ok some time after WW1 and really used industrially by Zeiss around 1920.
In 1907 the Zeiss E objective was not F2-BK7, it was the littrow balk2/balk3 based doublet designed at Bamberg located Berlin-Friedenau by Czapski
1929 Source A.E.Conrady
1957 Source Corning Glass
by BGRE
Posted 06 August 2022 - 02:03 AM
The Cooke triplet used in astronomical refractors is not the same design as the Cooke triplet used in slide projectors or cameras.
The relative spacing between the lens elements is much smaller in the "Cooke" triplet telescope objective.
All elements usually have the same diameter in the "Cooke" refractor triplet.
At least one element of some photovisual variants of this triplet used a glass that became "cloudy" over time (typically decades) due to atmospheric attack.
And to complete BGRE statement and to conclude : The Cooke Astro's Triplet was made with not durable glass, and reworked later in Zeiss B triplet by A.König later.
something like BALF4/KZF2/air/K7. looks like a reverse of the Taylor triplet.
Need some work I never conducted to reengineer the glass parameter for OSLO.
It should be a nice PNP triplet with low petzval sum (phi/n sum) : near flat so suitable for astrophotography, this was the goal of this work around exotic glass.
Only info I have is that one glass (front) may be a classic silicate crown without borate. (O.543 glass was stated in a "silicate" θ chart), and the second is a short flint O.658 that was not durable and soon replaced by O-164.
Remember that at this time, photographic films had grains around 50um so concentrating light inside Airy disk was not the ultimate purpose against reliably detecting a moving object between two shots.
An early glass catalog is welcome or Calcul des Combinaisons Optiques by Henri Chretien 1958 pp. 261-(262)-267 as quoted by Ceraglioli.
How Taylor calculated is astro triplet : glass choice after normalize to match a) achromatization FC, b) null G' C delta for apochromatisation => spherical and spherochromatism (tertiary spectrum) remains to be handled with curvature and spacing. If ponderated mean of Abbe of the positive lens (here N=54.6 vs 50.2) is far from the negative lens : curvature are less strong => this is what we call the Maximilian Herzberger's triangle to minimize spherochromatism.
So apochromat designing (color part of the old concept) was known well before 1907, it was still hard to compute aplanetism and handle other high order aberration like the tertiary spectrum (spherochromatism)
ϕ is lens power (reverse of focal length in diopter), ν is Abbe number, θ as explained under.
Please note that theta value is like a PG'F chart not the glass index : θ = (nG'-nC/nF-nC) = 1 + (nG' - nF)/(nF -nC) # 1 + PG'F
G' is Hγ=434nm, not g ray that is Hg 435,8 nm, things changes ...
An early way to match the modern PgF chart to choose glass to reduce secondary spectrum and do apochromat.
Retro-engineering is much difficult without the glass index : you need to explore all the PG'F value for glass and their vD (and table with G' are no longer a standard today).
Edited by lylver, 11 August 2022 - 10:53 PM.
