Is it a galaxy or is it a planetary nebula
13 replies to this topic
#1 Keith Rivich
Keith Rivich
  • Loc: Cypress, Tx
Posted 08 November 2019 - 12:40 PM
A friend is working on an online astronomy course and asked me this question based on a part of the lesson:
Is there a way to visually confirm a DSO is either a planetary nebula or a galaxy? What test can you perform using the commonly available tools in your visual toolbox?
The example given is Hoag's Object (a galaxy) https://apod.nasa.go...d/ap040815.html vs. a similar ringed planetary. Example: http://annesastronomynews.com/photo-gallery-ii/nebulae-clouds/the-fine-ring-nebula/
I know one can definitively test for one type but the other is not definitive as it is a process of elimination which cannot lead to a definitive answer.
I'm curious to read your thoughts...
#2 John Miele
John Miele
  • Loc: North Alabama
Posted 08 November 2019 - 12:43 PM
Apply OIII filter. Usually PN's stay bright whereas a galaxy would go dim.
  • Carol L, bmurphy495, bobito and 1 other like this
#3 Keith Rivich
Keith Rivich
  • Loc: Cypress, Tx
Posted 08 November 2019 - 12:53 PM
But not all PN respond to the OIII. Another gotcha is some SNR's will also respond to the OIII.
I think the only definitive answer is: It responded to an OIII, so it is not a galaxy. But I may be wrong...
#4 John Miele
John Miele
Posted 08 November 2019 - 01:01 PM
True. That's why I said "usually". I sort of missed you are looking for a "definitive" visual test. That will be tough...
You are right on the SNR's too. I was amazed how well the veil nebula responds to an OIII. But the shape of the veil will tell you it's not a galaxy.
Maybe the shape can play a role?
Edited by John Miele, 08 November 2019 - 01:04 PM.
#5 Keith Rivich
Keith Rivich
  • Loc: Cypress, Tx
Posted 08 November 2019 - 01:09 PM
That's what I was thinking. I haven't seen any ring PN that have a central condensation that Hoag's has.
#6 Jon Isaacs
Posted 08 November 2019 - 01:24 PM
Kevin:
I think one can guess.  But even a faint wispy globular cluster and seem galactic.  There are characteristics that experience suggests an object is probably a galaxy.  Until Astronomers had telescopes capable of resolving a star in Andromeda, it was not really known..
  • BFaucett likes this
#7 junomike
junomike
  • Loc: Ontario
Posted 08 November 2019 - 01:46 PM
  • Jon Isaacs, clearwaterdave and MikeMiller like this
#8 Keith Rivich
Keith Rivich
  • Loc: Cypress, Tx
Posted 08 November 2019 - 02:37 PM
Kevin:
Agreed. I think the point of the exercise was to think about how each DSO behaves visually then create a hypothesis and design an observational test. As I noted above the only *difinitive* proof comes when the DSO responds to a narrow band filter. If it responds it is not a galaxy. I do not believe there are any OIII bright galaxies. Parts of galaxies, yes, but not as a whole.
Edited by Keith Rivich, 08 November 2019 - 03:01 PM.
  • Jon Isaacs likes this
#9 Dwight J
Dwight J
  • Loc: Lethbridge, Alberta, Canada
Posted 08 November 2019 - 07:46 PM
The prism test should work.  A direct vision prism will disperse the stars into streaks while the planetary nebula will stay starlike.  A galaxy would do as the stars do.
  • payner and j.gardavsky like this
#10 j.gardavsky
j.gardavsky
  • Loc: Germany
Posted 09 November 2019 - 05:06 AM
The Amici straight view spectral prisms are often difficult to find on budget.
I have this one,
https://www.ebay.de/...kYAAOSwduxbJ7~F
Best,
JG
#11 Keith Rivich
Keith Rivich
  • Loc: Cypress, Tx
Posted 09 November 2019 - 09:18 AM
If I am not mistaken doesn't that only work on stellar PN's?
#12 Achernar
Achernar
  • Loc: Mobile, Alabama, USA
Posted 09 November 2019 - 10:42 AM
In general, this is good advice even though I have personally seen planetary nebulae that disappear through an O-II, but don't through a narrowband or H-beta filter. Probably if one uses both a H-beta and O-III on an object, and it's not enhanced by either of them, it's a good bet that it's not a nebula. A diffraction grating would be definitive since planetary nebulae emit only a few wavelengths of visible light, but galaxies emit across the whole visible spectrum.
Taras
Edited by Achernar, 09 November 2019 - 10:43 AM.
#13 j.gardavsky
j.gardavsky
  • Loc: Germany
Posted 09 November 2019 - 01:37 PM
Not only,
here is the spectrum of the Ring Nebula, which is truly not stellar,
http://www.astrosurf...spe6/planet.htm
Best,
JG
  • Keith Rivich likes this
#14 AstroVPK
AstroVPK
  • Loc: Sunnyvale, CA
Posted 12 November 2019 - 07:35 PM
Its a deep question all right. Here's a good write-up on the Great Debate between Harlow Shapeley & Herber Curtis about the true nature of galaxies - https://apod.nasa.go...e/debate20.html
Edited by AstroVPK, 12 November 2019 - 07:39 PM.
  • jpcampbell likes this
