Did you try NINA software for polar alignment?
7 replies to this topic
#1 jgmouton
jgmouton
  • Loc: Europe
Posted 08 November 2019 - 12:53 PM
I see there's an assistant in NINA for polar alignment but I wonder if it's really convenient compared to Sharcap for instance.  I have no mount right now so I cannot try it and cannot find much information about it.  Did you try that assistant?
Cheers
#2 richorn
richorn
  • Loc: Rancho Palos Verdes. CA
Posted 08 November 2019 - 01:33 PM
I'm looking forward to others jumping in here...
I tried it when NINA first came out, and had no luck with it.  Which led me to SharpCap, and I am still using it.  I would love to hear that it is working great now but as well as SharpCap works, I'm not too worried about it.
That said, NINA still rocks!
  • jgmouton likes this
#3 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 08 November 2019 - 01:53 PM
I have tried it.  It works well, but takes quite a bit longer than Sharpcap.
That's OK with me, since I was using it to fine-tune my alignment on a permanently-mounted setup -- the drift alignment used took 10-15 minutes, but resulted in PHD2 reporting 0.3" of polar misalignment consistently, run after run.  So it's accurate, if slow.
If you're looking for a quick alignment for a portable setup, probably not the best.  For permanent setups, it's very accurate.
#4 tkottary
tkottary
  • Loc: SunnyVale ,CA
Posted 08 November 2019 - 02:21 PM
I use Nina's polar alignment  followed by  PHd2  drift  when I image from home from balcony.  Like Paul  I have always had 0.3 to 0.5" degree of error between PHd2 and NINA
  • jgmouton and OldManSky like this
#5 jerahian
jerahian
  • Loc: Maine
Posted 08 November 2019 - 02:25 PM
Love NINA, but haven't bothered with its PA functionality.  SharpCap just rocks that function for me to look anywhere else, honestly.
#6 jgmouton
jgmouton
  • Loc: Europe
Posted 09 November 2019 - 04:21 AM
Thank you for the comments.  Is there a video/explanation somewhere about NINA PA Assistant procedure?
#7 OldManSky
OldManSky
Posted 09 November 2019 - 09:36 PM
https://nighttime-im...n/tabs/imaging/
Scroll down to the "Panel: Polar Alignment" section.
#8 MHamburg
MHamburg
  • Loc: Brooklyn, NY/Berkshires, MA
Posted 10 November 2019 - 02:12 PM
How does NINA compare with BackyardEOS?
Michael
