unknown 4mm eyepiece
11 replies to this topic
#1 droid
droid
    rocketman
  • Loc: Conneaut, Ohio
Posted 08 November 2019 - 01:58 PM
I was gifted this eyepiece by a fiend for my birthday. He doesn't know  what brand it is, or any info , other than what's on the side of it.
Im kinda orta thinking itll get used once or twice a year, tops with our atmosphere here.
Any know anything abut this eyepiece???
  • Sky Muse likes this
#2 Sky Muse
Sky Muse
  • Loc: Mid-South, U.S.
Posted 08 November 2019 - 02:10 PM
For one, the "UWA" stands for ultra-wide angle, but a 58° AFOV doesn't translate into what it accepted as an ultra-wide TFOV.  That would be at least an 82° AFOV, and greater.
Here's a BST 1.25" 4mm "UWA" 58°, and practically identical...
https://agenaastro.c...epiece-4mm.html
It's probably safe to say that it's an overseas knock-off.
Incidentally, I don't really consider BST to be a brand; more like a generic.
The one you have seems to have nice coatings, and perhaps even fully multi-coated like the BST.
Edited by Sky Muse, 08 November 2019 - 02:13 PM.
  • MikeMiller likes this
#3 jeremiah2229
jeremiah2229
  • Loc: Illinois, USA N 37° W 89°
Posted 08 November 2019 - 02:26 PM
If the upper part/half can be rotated to adjust for the eye it's a Sky-Watcher, if not adjustable then it's a BST.
Peace...
#4 Tank
Tank
  • Loc: Stoney Creek, Ontario, CANADA
BST
#5 GalaxyPiper
GalaxyPiper
  • Loc: Sacramento, Ca.
Posted 08 November 2019 - 02:27 PM
Closest Analog to that eyepiece is called a "Skywatcher", this is what I found:
https://www.telescop...g-eyepiece.html
Otherwise, it's maybe just another Chinese made eyepiece.
Also, here at Worthpoint:
https://www.worthpoi...lossl-516188291
skywatcher-uwa-4mm-planetary-plossl_360_
and also here:
https://www.worthpoi...ry-58-519806279
skywatcher-25-4mm-uwa-planetary-58_360_a
If you sign up with them, you might get a monetary value for it. Probably not more than say $50.00 U.S.
Enjoy the "Gift".
Edited by GalaxyPiper, 08 November 2019 - 03:09 PM.
#6 MikeMiller
MikeMiller
  • Loc: Pittsburgh, PA, USA
Posted 08 November 2019 - 02:55 PM
I wonder what this is "wide" in comparison to. :)
#7 sg6
sg6
  • Loc: Norfolk, UK.
Posted 08 November 2019 - 02:56 PM
From shape and 4mm and UWA 58o I would say it is a reproduction of the old TMB Planetary's. Just without the usual printing around it. No idea who doesn't bother with the usual printing. However there are a number of sources of the general design.
Unfortunately therefore nothing overly special but a potentially usable 4mm eyepiece.
#8 CharlieB
CharlieB
  • Loc: Southern NH
Posted 08 November 2019 - 03:15 PM
These were the first knock-offs of the Burgess/TMB Planetary eyepieces.  I have the 3.2mm and 5mm versions.  They work fine, but the build is not as good as the Burgess/TMBs.
#9 droid
droid
    rocketman
Posted 08 November 2019 - 03:28 PM
It does have a twist up eye cup, though I never realized it till now.
And yes its a an exact copy of the skywatcher eyepiece in the link
Thoughts on whether its good enough for a once or twice a rear usage.
My opinion, would be,  it beats the you know what out of looking through a 4mm plossl. Which it will replace.
  • Joe1950 and GalaxyPiper like this
#10 GalaxyPiper
GalaxyPiper
Posted 08 November 2019 - 04:17 PM
Should do just fine. Internally I think it is a plossl. It just has a wider field of view.
You should get some use out of it, maybe more than you think.
#11 Jon Isaacs
Posted 08 November 2019 - 04:52 PM
It's actually a "negative-positive" eyepiece. If you look at the third photo you'll see a tiny lens. That's a Barlow-like telenegative lens and it functions like a Barlow. The rear section contains the positive magnifying section. Naglers are negative-positive eyepieces but somewhat more sophisticated.
The rear magnifying section has a focal length much longer than 4 mm, probably 20 mm so. This way the eye piece can have the eye relief of a 20 mm eyepiece, 12-15 mm.
I have the 4 mm TMB. They're good eyepieces, I suspect this one is too.
  • BFaucett and GalaxyPiper like this
#12 droid
droid
    rocketman
Posted 08 November 2019 - 07:27 PM
Thanks Jon.... I don't think its a skywatcher, but it sure looks identical.
I also picked up a 3mm Zhumel LER ep.
