Brass Compression rings eat your heart out
16 replies to this topic
#1 MartinPond
MartinPond
Posted 08 November 2019 - 02:49 PM
I often need a 1.25" extension, what with the stubby EPs I get
  and the indoor testing.  This scheme works great:
That is a piece of "lavatory" (bathroom sink) hardware in HDPE plastic
 with a compression ring of LPDE that presses in evenly around the whole
 circumference.  Less pesky than the brass rings, and holds well.
Fits just right in 1.25", since the OD of plumbing needs to have tight tolerance.
For suppressing  stray light, winding in a bit of black drywall
  sanding screen works awesome...best low-angle blackness ever!.
  You put it in tight then push it out, It locks against itself and stays put.
  Note the tapers....this keeps the stuff from 'springing in' at the ends.
Edited by MartinPond, 08 November 2019 - 02:51 PM.
  • Astrojensen and Joe1950 like this
#2 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 08 November 2019 - 03:41 PM
Best apply for a patent ASAP else the Premium eyep. manufacturers catch wind of this!    Tom
  • Thomas Marshall and Joe1950 like this
#3 MartinPond
MartinPond
Posted 08 November 2019 - 03:48 PM
Heh...
I think I just filed an "anti-patent"..
Tada...it's "prior art" now.
  • stargazer193857 and Joe1950 like this
#4 Dynan
Dynan
  • Loc: NOLA
Posted 08 November 2019 - 04:28 PM
  • Joe1950 likes this
#5 MartinPond
MartinPond
Posted 08 November 2019 - 04:35 PM
That's it.
It did take many years prowling  and a little risk taking
  ($6 worth) to see the obvious, though.
  Well, experiments too...that taper is key.
    Strange how the answers  hide in the great mass of stuff.
#6 Joe1950
Joe1950
Posted 08 November 2019 - 04:47 PM
Said it before... The plumbing industry will never know of the prodigious contributions it has made to amateur astronomy.
  • ATM57, kevint1, airbleeder and 2 others like this
#7 MartinPond
MartinPond
Posted 08 November 2019 - 04:52 PM
Indeed! And other things too..
I was a microwave engineer way back,
and the 'waveguides' for radar/comms  and
 thus the frequency bands were all driven by common
  hollow rail dimensions.
  The first rule of inventing is:
     try to use already mass manufactured things first.
   (unless you're going to do something really 'out there'.)
#8 stargazer193857
stargazer193857
  • Loc: Southern Idaho
Posted 08 November 2019 - 06:22 PM
Heh...
That won't stop the big boys from patenting it anyway. I've seen it happen. USPTO only looks in the PTO. Courts will look more places if you submit it then. You then have to wait to be sued to challenge the patent, not knowing if your anti-patent will disappear off the web. When they sue, they can go 6 years retroactive for damages. You can challenge preemptively, but it costs $3000.
#9 Stargazer
Stargazer
  • Loc: NewBrunswick, Canada
Posted 08 November 2019 - 09:51 PM
seems to me I posted years ago about my Ronchi eyepiece tester I used on my 10", now I see folks selling them. Who Knew...  lol.
#10 MartinPond
MartinPond
Posted 08 November 2019 - 10:09 PM
In some cases (like mine), the real competition
for the big guys is people just making their own
 (takes a mitre saw and xacto).
If someone made a use patent for a fancier eyepiece holder that
used the LDPE ring in it, that would be nice.
The copper ring as a split in it, go it doesn't work
   (so you have to rotate the ring manually.)
 when the gap is centered on the pin, and it can bend
in if the screw goes too deep right next to the gap.
Thus the complaints about "I can't get the eyepiece in anymore".
#11 Ken Watts
Ken Watts
  • Loc: Sun City, Az
Posted 09 November 2019 - 03:49 PM
The sanding screen is genius!  I sprayed the inside of my PVC "extender."
Clear and steady skies,
Ken W
#12 Joe1950
Joe1950
Posted 09 November 2019 - 04:03 PM
One of the big problems for inexpensive binoviewers is the relative alignment of the two eyepieces causing problems merging images. The even grab of the LPDE compression ring as opposed to the brass ring, may be a solution. Just thinking out loud.
  • stargazer193857 likes this
#13 MartinPond
MartinPond
Posted 09 November 2019 - 08:17 PM
If there is a small looseness, it's true: the way the brass ring acts
   can be quite assymetric.  You could shim up the EP, but
  then it snags on the ring.   Seems like the LDPE ring could
  lock a misalignment in place, though...but not if the EP
   is 'shelved' where the diameter goes up.
   Now....using an LDPE squeeze with a bit larger (like 1.253 ID)
     tube would allow you to steer the EP a bit..
#14 don clement
don clement
    Vendor (Clement Focuser)
  • Loc: Running Springs, California
Posted 09 November 2019 - 09:31 PM
A collet would fix looseness issue and keep eypieces centered.
Don
  • brave_ulysses and Joe1950 like this
#15 BGRE
BGRE
  • Loc: New Zealand
Posted 09 November 2019 - 11:02 PM
An ER style collet (flexes at both ends) would accommodate small variations in eyepiece diameter better than the alternative (flexes at one end only).
  • brave_ulysses, don clement and Joe1950 like this
#16 don clement
don clement
Posted 10 November 2019 - 12:35 AM
I agree. I have both ER collets and 5C single ended  collets.  One thing about single ended collet is that the fixed length of the chucked part (eyepiece) varies with the diameter of the part (eyepiece).
Don
#17 don clement
don clement
Posted 12 November 2019 - 11:12 AM
I think that printing the double ended part for a collet that  firmly holds an eyepiece or camera  and keeps them centered  would best be done by 3D printing in plastic. https://www.youtube....h?v=eMtLdE5Zq-8  The rest of the "collet" could be made from easily machined aluminum on a manual lathe.
Don
