Looking for a more solid DSLR attachment
5 replies to this topic
#1 archer1960
archer1960
  • Loc: Southern New England
Posted 08 November 2019 - 11:04 PM
I have a Feathertouch 3015 focuser and a 2" extension nosepiece for my Canon DSLR. I am finding that the camera sags just a bit when aiming at a low altitude. So I'm looking for a threaded adapter that will allow me to connect the camera to the focuser completely with threaded connections, rather than a nosepiece that I tighten down set screws to hold in place, to eliminate that source of mis-collimation.
Has anybody seen such a beast (or combination of) that will give me a rigid connection?
D
#2 petert913
petert913
  • Loc: Portland, OR
Posted 09 November 2019 - 12:21 AM
Is this for the 4" Meade you have in your signature?  There should be direct-screw in adapters that don't rely on compression rings.  Not sure about the feather touch, but that's how my Astro-Tech refractor focuser works.
#3 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 09 November 2019 - 12:28 AM
I am sitting around bored and I looked at Feathertouch's website. It seems they don't have a 42mm T thread adapter for a 3" focuser. But that hardly seems possible.
#4 Chuckwagon
Chuckwagon
  • Loc: Orem, Utah, USA
Posted 09 November 2019 - 01:57 AM
Perhaps the Stellarvue SFA-M75M48F48-004 adapter would work.  That, in conjunction with a Canon M48 T-Ring (William Optics make one) would give a threaded connection to your camera.  (Assuming your focuser has the M75 threads into which the 2" compression ring is threaded, and you remove the compression ring.)
#5 the Elf
the Elf
  • Loc: Germany
Posted 09 November 2019 - 06:25 AM
On the camera side I can recommend the Baader protective T-ring. Almost zero play, 48 and 42mm female thread and you can place a filter in the ring. It is 12mm long.
According to this link:
http://starlightinst...5&product_id=54
is has a M75X1 Female Thread at the draw tube. Can you confirm? If so, this brings you to M68x1
https://www.teleskop...0-Auszuege.html
This one brings you to M48 male that fits the T-Ring
https://www.teleskop...ussadapter.html
Note: you need a rotator unless there is one between scope and focuser. Here is one:
https://www.teleskop...8x1-thread.html
If you are on a budget and don't mind the small screws the camera can also be roated by the Baader T-ring, loosening 6 tiny hex screws and saving some back focus.
#6 archer1960
archer1960
Posted 09 November 2019 - 01:42 PM
No, it's for my AT-10RC
