Masuyama or Ploessl
8 replies to this topic
#1 ThomasM
ThomasM
Posted 10 November 2019 - 05:01 AM
The  new masuyama eyepieces (32,  26, 16  mm)   offer with 85 degree a  very large field of view in a rather compact housing for the price of poor edge sharpness.
But how do the sharpness compare with  the inner 50 degreee to that of a ploessl eyepiece with the same focal length?
#2 havasman
havasman
  • Loc: Dallas, Texas
Posted 10 November 2019 - 05:36 AM
At what focal ratio?
#3 ThomasM
ThomasM
Posted 10 November 2019 - 05:42 AM
Very good point, I am most interested at f/5.5 to f/7. But, couldn't it be that the answer is almost independent of the focal ratio, because the sharpness degrades in both eyepieces with fast f ratio?
Thomas
#4 havasman
havasman
Posted 10 November 2019 - 05:50 AM
Maybe so. But neither is generally recommended at those ratios. Both are going to be pretty well compromised. I have not used a Masuyama and have not used a Plossl since trying a couple years ago at f4.7.
My scopes' focal ratios are f4.49, f4.7, f5.4 and f7. Two are Newts and 2 refractors.
#5 jaraxx
jaraxx
Posted 10 November 2019 - 07:27 AM
I have no experience with the Masuyama. I do have experience with Plossls, and if you're willing to constrain yourself to 50° and stick your eye right down to the glass the sharpness of a good Plossl is hard to beat.
#6 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 10 November 2019 - 07:37 AM
Thomas
I *suspect* that the experience will be rather similar to erfles vs. plössls, IE the inner 50° are fine at f/6, but outside of that it starts to become progressively worse and at the edge, it's seagull heaven in newtonians and out of focus and blurred in short-ish refractors.
Clear skies!
Thomas, Denmark
#7 ThomasM
ThomasM
Posted 10 November 2019 - 10:52 AM
Clear skies!
Thomas, Denmark
So you suspect that the Masuyamas are Erfle Eyepieces? I would also expect that the correction also depends on the glass type.
#8 Astrojensen
Astrojensen
Posted 10 November 2019 - 11:42 AM
No, just that the *experience* might be similar, not identical. I do know for a fact, that they are five-element eyepieces. The 50° Masuyamas were a redesign of the Zeiss Astroplan eyepiece (as were the Takahashi LEs, but they're apparently not identical), which in turn were a mix between an Erfle and a Plössl.
Glass types play a critical role, obviously, but there's only so much you can do with five elements, if you also want an 85° AFOV.
Clear skies!
Thomas, Denmark
  • mikeDnight and j.gardavsky like this
#9 rowdy388
rowdy388
  • Loc: Saratoga County, NY
Posted 10 November 2019 - 04:29 PM
Again, I only own one of the eyepieces being asked about: the 32mm Masuyama 85.
I haven't owned a plossl in over a decade. The glass, polish, and coatings of the Masuyama
are premium. Only the best of the plossls probably match it in 50 degrees and then I'm still
thinking it's 5 lens against 4. The Masuyama should have the advantage. I use the 32 Masu
with a nebula filter (the best eyepiece for that purpose I've ever had) and don't require the
outer field to be great. For that I use the 31 Nagler.
  • starcam likes this
