Can it work, yes. Will it be optimal, perhaps no.
I started out with a Skyris 236C, partly "knowing" that it could work as a guider, but not really understanding what that meant. After upgrading to a DSLR for imaging and adding a guide scope, I moved the Skyris to that role. It did work, but it was not optimal. Eventually I replaced the Skyris with a purpose-built guide camera, the ZWO ASI174MM Mini, and am much happier with its performance.
Since you already have the camera, my advice is to go ahead and use it, then figure out if its performance is adequate for your needs. If not, its deficiencies should become evident, suggesting what sort of camera specs would perhaps work better. No point replacing it until you know what you need to replace it with. My issues were sensitivity and field of view, as my guide scope is relatively long and dim (80mm f/7.5), and a mono camera is usually a better match for guiding than color. Your situation could certainly be different, as an OAG setup has different constraints and requirements.
