Asi183mc pro - confirming I need a UV/IR cut filter
9 replies to this topic
#1 reddog1972
reddog1972
  • Loc: Northern NJ
Posted 13 November 2019 - 01:24 PM
The title says it all... I know I need to use a UV/IR cut with my asi071mc pro, and just wanted to confirm I need one with my new asi183mc pro as well.
Thanks in advance and clear skies!!!
#2 Dynan
Dynan
  • Loc: NOLA
Posted 13 November 2019 - 01:29 PM
An Astronomik L-3 filter made a huge difference in my images with the 183MC-Pro.
https://www.cloudyni...-quintet-redux/
  • reddog1972 likes this
#3 StrStrck
StrStrck
  • Loc: Denmark
Posted 13 November 2019 - 02:13 PM
Yes, the specs state Anti Reflective window only https://astronomy-im...183mc-pro-color
#4 lakeorion
lakeorion
  • Loc: Lake Orion MI
Posted 14 November 2019 - 11:35 AM
My QHY183M is very happily sensitive to IR.  This was taken with a Baader 685 IR pass filter.
Yes its from a different manufacturer and mono vs. OSC but the chip is certainly capable of IR.
Filter before failure, it's cheap insurance against weird halos.
  • reddog1972 and Dynan like this
#5 reddog1972
reddog1972
  • Loc: Northern NJ
Posted 15 November 2019 - 02:32 PM
Thank you for the responses to confirm what I'd thought - greatly appreciated, and clear skies!
#6 IC1101
IC1101
  • Loc: Canada
Posted 15 November 2019 - 08:29 PM
No you do not need a uv-ir block filter. The specs on the zwo site says that the asi294mc pro and asi183mc pro has a D32-2-AR protective window.
That window Is also described with it's bandpass here.
https://astronomy-im...dow-asi-cameras
One less item to worry about.
#7 Dynan
Dynan
  • Loc: NOLA
Posted 15 November 2019 - 11:38 PM
Then how can you explain the recovery of color in my ASI183MC-Pro colors with an Astronomic L-3 filter?
#8 ZL4PLM
ZL4PLM
    Vendor - ZWO Product Dev Team Member
  • Loc: Darfield, New Zealand
Posted 16 November 2019 - 01:46 AM
that is incorrect - The 294/071 and 183 all need UVIR cut filters
I use an astronomiks L2 to good effect
cheers
simon
  • Dynan likes this
#9 StrStrck
StrStrck
  • Loc: Denmark
Posted 16 November 2019 - 07:42 AM
Seems like misunderstanding, bandpass means it lets wave lengths pass through, and the curve is high across almost the whole width of the scale.
So, a high percentage of a lot of wavelengths go through the window.
#10 IC1101
IC1101
  • Loc: Canada
Posted 16 November 2019 - 09:34 AM
I stand corrected. The graph i was looking at was for the D21 which is the uv-ir filter.
  • ZL4PLM likes this
