Using a 2" L'eNhance with EF lens
7 replies to this topic
#1 ParagPA
ParagPA
Posted 15 November 2019 - 05:10 PM
Hello,
Just bought a 2" L'enhance tri-band filter. I'll typically use is attached to my field flattener. However, I also use wider field EF lenses. Is there any way to use this filter with those?
#2 kel123
kel123
Posted 16 November 2019 - 06:27 AM
2" L'enhance is a dual band filter, not a 2" tri-band filter .I hope there is no deception from the seller?
The only theoretical way to use that size on a DSLR is to get a step down converter and convert from the size of your lens to 2".
However, depending on the size of your lens objective, there may be some vignetting
#3 ParagPA
ParagPA
Posted 16 November 2019 - 07:25 AM
Thanks! Since it isolates Ha, Hb, and O-III, isn’t it a tri-band?
#4 8472
8472
Posted 16 November 2019 - 09:37 AM
Nope.
Hb and O-III are grouped into a single band.
#5 kel123
kel123
Posted 16 November 2019 - 09:50 AM
Unfortunately, practically, it is a dual band filter. When you look at the graph, you will know why the manufacturer and everyone else calls it a dual band filter despite the literature noting "isolation of Hb" when it is included in O-III band .
Unless, of course it makes you feel good to say you own a tri-band filter smile.gif  when you do not.  If you really need one, it will set you back by almost $800 not just about the $200 you paid for the L'enhance.
After reading your post, I thought for a moment that the brand is out with a tri-band filter. Had to figure out you rechristened it all by yourself.
Clear Skies
#6 ParagPA
ParagPA
Posted 16 November 2019 - 11:51 AM
Clear Skies
Lol yep! Definitely my mistake. And I just looked at the curves and see what you and others mean.
I couldn't find an APS-C clip in version of this filter - I assume that doesn't exist?
#7 DubbelDerp
DubbelDerp
  • Loc: Upper Peninsula of Michigan
Posted 16 November 2019 - 12:35 PM
I wouldn’t worry too much about making that mistake... after all, this one is called a tri-band filter.
https://optcorp.com/...1c4d66c79eb455c
I don’t think optolong makes a clip-in version, but STC has a similar dual band clip-in filter.
#8 kel123
kel123
Posted 16 November 2019 - 12:54 PM
Sure. STC makes both the clip-in version and the camera lens version. I own the 2" version from STC but I almost regretted buying it for $330 USD because as soon as it was delivered, L'Enhance was released for much cheaper. Great filter though but I think I should have saved that $100
