I received my new AP Stowaway in early October as part of the second run of the FCD100 based 92mm all spherical, air spaced triplet. Because of some previously scheduled international travel, I’ve not had a lot of time to use and test the OTA. I have had several quick look sessions mostly looking at the moon, and brighter clusters (M45, Double Cluster etc). Jupiter and Saturn are too low and have sunk behind a neighbor’s trees. I did view Neptune and Uranus. Both were unremarkable but did resolve to planetary disks. I did not do any critical star testing outside but have done so indoors. Overall, my impressions are that this is a terrific telescope.
Below are some photos of my Autocollimation test setup. My optical flat is 10” in diameter, 2” thick and made from Zerodur. It was sourced from Lawrence Livermore National Laboratory. In the center 6 inches or so, it approaches 1/30 wave. The great thing about testing in double pass autocollimation is a flat this precise is NOT a requirement. You can have a optical flat several waves from being flat and its still be good enough for testing in double pass. This is so as the errors in the flat only contribute fractionally to the error of the telescope under test. One of the benefits of an accurate flat is that I am able to use it with an interferometer. In interferometry all errors present in the test path are additive.
Edited by peleuba, 16 November 2019 - 04:04 PM.
