Silicon dicarbide in carbon stars: Merrill-Sanford absorption bands with SA-100
beginner dslr
4 replies to this topic
#1 mwr
mwr
  • Loc: Germany
Posted 17 November 2019 - 06:18 AM
Merill-Sanford (MS) absorption bands are molecular absorption bands of SiC2 in the blue-green spectra of carbon stars. I have tried to detect these rather weak but famous bands using the SA-100 (R=100 in my setup) and VX And as object (red curve; 38 spectra at 180 sec. each were stacked). As reference object I used a spectrum of RY Dra from the BAA-database (R=430; blue curve) (https://britastro.or...ment=&plot=Plot).
The most intense MS-band at 4985 A is already visible in the original SA-100 spectrum. Two more MS-bands could be detected:
VX And is classified as C-J4.5 J 5 MS 5
RY Dra is classified as C-N3 III: C2 6.5 J 3.5 MS 4.5
(MK classification: https://iopscience.i...1086/133252/pdf)
The structure of SiC2 is quite interesting showing a T-shaped form (see Fig. 1 as inset; taken from http://theop11.chem....7_1195_SiC2.pdf) with a C2v-symmetry (vetrical symmetry plane with a 180 degrees rotational symmetry axis). The broad shape of the bands is due to overlapping electronic and vibrational energy levels (see inset showing the assignments; taken from https://iopscience.i...1086/310336/pdf).
A comparison of VX And with another SA-100 carbon star spectrum of Z Psc (C-N5 C24) shows the absence of these MS-bands and demonstrates that carbon stars can, indeed, be classified using a low resolution setup.
SiC2 bands are possibly generated in cooler material high above in the photosphere. Real cool chemistry in cool stars!
Edited by mwr, 17 November 2019 - 06:29 AM.
  • ssmith, PirateMike, Organic Astrochemist and 1 other like this
#2 John Tucker
John Tucker
Posted 17 November 2019 - 08:43 AM
That is one funky chemical structure to be sure.  At one time there was some controversy as to whether the all-carbon analog was capable of existence, or would spontaneously rearrange to a non-cyclic form.  Dunno if it ever got resolved, but putting a triple bond (prefers to be linear) in a 3 membered ring is quite a "stretch".
   https://pubs.acs.org...021/ja00529a057
  • mwr likes this
#3 mwr
mwr
  • Loc: Germany
Posted 17 November 2019 - 08:50 AM
VT photometry using a Canon 450 Da and the green channel (see Kloppenborg et al. JAAVSO 40 (2012) 815) with Tycho 2 VT data yielded a magnitude of 8.5 for VX And (UTC 20:40 2019-11-16):
#4 Organic Astrochemist
Posted 17 November 2019 - 04:04 PM
Great job!
I guess the relative intensities of the lines are also important.
My ALPY spectrum of WZ Cas has many small absorbances but the relative intensities didn’t match at all.
I understand there is an inverse correlation of MS strength with temperature. Why doesn’t WZ show MS bands?
#5 mwr
mwr
  • Loc: Germany
Posted 18 November 2019 - 02:24 PM
Typically, the SiC2 bands are either invisible or quite strong. Plots of densities of the SiC2 molecule against temperature show a steep rise to a narrow maximum followed by a steep descent. It is suspected that these bands will appear in the spectrum of any carbon star lying within the rather narrow range of effective temperature and having a sufficient excess of carbon in the atmosphere:
http://articles.adsa...000421.000.html
However, there might be more recent research on this topic which I'm not aware of.
Also tagged with one or more of these keywords: beginner, dslr
