Rejecting bleeding stars: Deepskystacker vs. PixInsight
8 replies to this topic
#1 justusliebig
justusliebig
Posted 17 November 2019 - 02:05 PM
Dear all,
i haven't been looking around here, but that is just because I have been mostly happy with my AP game and I didn't have to troubleshoot for some time. However, now that Orion is up, I am actually suffering from too bright stars. I get column errors and my idea was to average them out by rotating the camera. This is the my starting point:
But rotating did only add more of those nasty defects. I used Windsorized sigma clipping in PI (left) and kappa-sigma in DSS (right).
The version from DSS looks way better. I played with the rejection values in PI but to now avail. What does DSS do different?! Thanks
#2 Moreflying
Moreflying
  • Loc: So. Cal
Posted 17 November 2019 - 03:32 PM
I'm not sure I have an answer to that but I notice something else in your image with Windsorized sigma clipping in PI that I had. If you look at some of your brighter stars (low in the image) look at how they are eroded away missing pixels on the left sides. Do you see it? I had the exact same problem and could never figure it out. Here I see it with someone else's image. The PI gurus need to look into that IMO.
#3 james7ca
james7ca
  • Loc: San Diego, CA
Posted 17 November 2019 - 06:21 PM
In PI you may have to apply the Large-Scale Pixel Rejection.
#4 pfile
pfile
Posted 17 November 2019 - 06:37 PM
also the difference i think is that PI has 3 as the default # of sigmas to reject on the high side, but DSS has 2 sigmas as default. if you cranked PI down to 2 on the high slider you might see comparable results.
PI 1.8.8 has a new rejection algorithm called ESD - "Generalized Extreme Studentized Deviate Test" - god knows what that really means - but it might be worth a try here. it's supposed to be better at identifying outlying pixels. but the tooltip does say it needs 25-50 subs to really work best.
also i agree with james that the LS rejection could help.
rob
#5 justusliebig
justusliebig
Posted 17 November 2019 - 06:38 PM
Thanks for the hint, no difference with various permutations/combinations
#6 james7ca
james7ca
Posted 17 November 2019 - 08:00 PM
How many subs are you stacking? Windsorized sigma clipping works best when you have a relatively large number of subs (greater than 15?). Percentile Clipping should work better if you have a smaller number of subs.
#7 justusliebig
justusliebig
Posted 17 November 2019 - 08:04 PM
30+ from 3 different sessions/rotations :/ Lowering the sigma helped at the expense of a lot signal, yet still not as good what DSS produces
#8 hoxca
hoxca
Posted 13 December 2019 - 07:53 PM
Spurious data versus outlier depends on what is important to you.
Lines is not common on deep sky, so i m sure that a prefilter can do a better job than a simple rejection if this artifact is a consistent outlier in all your subs.
The remaining question is now: how can we remove lines upfront of the image integration process using image from a different session ?
#9 hoxca
hoxca
Posted 13 December 2019 - 08:05 PM
rob
Hello @pfile here is one pointer to understand Grubb testing of studentized data.
https://www.youtube....h?v=ncqbegn1V6U
  • pfile likes this
