Full Disc & AR2752 | Nov 18th 2019
26 replies to this topic
#1 MalVeauX
MalVeauX
  • Loc: Florida
Posted 18 November 2019 - 12:02 PM
Heya,
It's been raining for days and total cloud cover all through this week, but today it was cleared up for a while. Seeing was poor this morning. But I was able to get a little time on AR2752 which is still persistent. I looked at the photosphere and didn't notice any appreciable sunspot, but the activity in the chromosphere was still nice with a little mottling and a nice filament. If this persists as it approaches the limb, it could be interesting seeing it as a prominence over the active region.
Colored:
B&W:
Earth Scale:
Very best,
Edited by MalVeauX, 18 November 2019 - 12:07 PM.
  • paulsky, PhotonJohn, R Botero and 13 others like this
#2 rigel123
rigel123
  • Loc: SW Ohio
Posted 18 November 2019 - 12:24 PM
Great shot of AR2752!  Hope it lasts until it hits the limb!
  • MalVeauX likes this
#3 Mike G.
Mike G.
  • Loc: Oberlin, Ohio
Posted 18 November 2019 - 12:28 PM
I wasn't catching any proms yesterday, now I can see they were pretty faint and with the cloud cover I had, seems reasonable.  plus, it was about 38-40 degrees and I wasn't picking up a lot of detail due to that as well.  thanks for posting what was going on!
#4 MAURITS
MAURITS
  • Loc: Belgium
Posted 18 November 2019 - 02:09 PM
Excellent Marty.
#5 RickV
RickV
  • Loc: Ottawa, ON, Canada
Posted 18 November 2019 - 03:38 PM
Hey Marty - nice images... but... where did those purple fringes come from?
Best,
Rick
#6 MalVeauX
MalVeauX
  • Loc: Florida
Posted 18 November 2019 - 09:07 PM
I later grabbed some data for a time lapse animation at 120mm aperture to handle the day time seeing late day which is poor compared to the morning.
https://www.astrobin...vpna8h/0/?real=
Also some comparison data for resolution differences:
120mm aperture resolution:
52mm aperture resolution:
Star party!
Very best,
Edited by MalVeauX, 18 November 2019 - 09:32 PM.
  • R Botero and AstroDan2015 like this
#7 AstroDan2015
AstroDan2015
  • Loc: Racine, Wisconsin
Posted 18 November 2019 - 09:34 PM
Marty, You must be using an expensive set-up to achieve such fine resolution and contrast?
#8 MalVeauX
MalVeauX
  • Loc: Florida
Posted 18 November 2019 - 09:39 PM
No sir, the reality is that the seeing is the most critical part of it all. One can induce contrast in post-processing. Otherwise, high contrast from the HA filter's properties can be a thing, but even inexpensive stuff can get there. Resolution however, regardless of what instruments used, is totally at the mercy of the quality of the atmospheric seeing. I find that in my area, early morning's are my only chance for higher resolution moments and even then I don't always get to the limits of my 8 inch scope, usually not at those limits ever, probably more like a 6 inch scope in reality just based on seeing quality not being top notch. My all-day-seeing quality can handle a 120mm aperture though, at any time of day, in HA at least, so that's my "seeing ceiling" so to speak, or safe go-to for imaging during the day when seeing isn't good enough for larger. I don't have a SolarScintillationMonoitor (SSM) yet, which would help a lot with triggering sessions based on seeing, maybe one day. But I'm fairly cheap so it may be a while!
Fine resolution starts to really show up in that 102~127mm range, even 80mm~90mm shows virtually everything quite nicely. So an inexpensive achromatic refractor and an HA filter of your choice, such as a Quark Chromosphere, gets you there affordably. But again seeing matters the most when it comes to resolution, so imaging during the day when seeing is the worst, or if local seeing is not good to begin with, etc, are all factors that can determine how big you might want to go to chase resolution. Honestly if I had to drop everything and have a single solar scope, it would be a double-stack 90mm~100mm, such as a Solarmax 90 III (which costs more than my setup!).
See above post for resolution examples with associated apertures.
Very best,
Edited by MalVeauX, 19 November 2019 - 08:38 AM.
  • Mike G. likes this
#9 wargrafix
wargrafix
  • Loc: Trinidad
Posted 19 November 2019 - 12:01 AM
Good job!!!
#10 dragracingdan
dragracingdan
Posted 19 November 2019 - 04:14 AM
Great images! How do you get the earth scale accurately?
Best,
Dan
#11 tholan
tholan
Posted 19 November 2019 - 07:04 AM
Great job Marty. Where did you get the reflective material that you use on your scope and camera?
#12 MalVeauX
MalVeauX
  • Loc: Florida
Posted 19 November 2019 - 07:44 AM
You can calculate it, but I just take a limb shot and scale an Earth image to the limb, then reduce it by 109x. I do that with each imaging train on each scope so that I can reference back to it for simplicity after I do it once.
It's just reflectix,  you can get it at Home Depot / Lowes / etc. It's a heat barrier, some use it for insulating, but I use it simply to keep heat currents/plumes from rising into my scope(s) from the pier, mount head, etc, that gets really hot when exposed to direct sunlight and allows the heat to rise which can ruin local seeing quality in the tube itself. So I cover most surfaces and put a barrier around the OTA so that heat goes around it instead of right through it.
Very best,
  • dragracingdan likes this
#13 rigel123
rigel123
  • Loc: SW Ohio
Posted 19 November 2019 - 08:06 AM
Great comparison on the difference in resolution!
#14 PhotonJohn
PhotonJohn
  • Loc: Viera Florida
Posted 19 November 2019 - 08:35 AM
Marty, I have watched your tutorial many times. Are you still using AutoStakkert, Registax and PS as in your video? Thanks for the beautiful images.
#15 MalVeauX
MalVeauX
  • Loc: Florida
Posted 19 November 2019 - 08:41 AM
Hi John,
No sir, I really need to re-do that, I don't do a lot of that anymore. I use Autostakkert!3 and IMPPG primarily. The rest is solely in Photoshop and even then, its mostly just clean up, shadow lifting, or gradient removal, and dodge/burning, stuff that can be done in other software likely. I also do not do two exposures anymore, I do just one exposure to handle both the surface & prominences and process from there. I don't use Registax at all now. I need to re-do the guide to better explain my work flow these days, I try to slim it down to speed things up and simplify. I'm using a different camera too, as my IMX174 sensor had issues when over-exposing (weird lines would show up), lately I'm using an ASI290MM to again simplify things, speed things up, less stuff in the imaging train to account for, etc.
Very best,
Edited by MalVeauX, 19 November 2019 - 08:42 AM.
#16 PhotonJohn
PhotonJohn
Posted 19 November 2019 - 09:26 AM
Hi John,
Very best,
Thanks Marty,
For right now I will stick with my current set up, a Lunt double stacked LS-60THAD/B12C and ASI174mm. Your work flow is amazing with the amount of images you post. It takes me all day to produce one image. I have AutoStakkert!3, PS and will download IMPPG. I am lucky to live in central Florida for the good seeing.
Thanks again for responding,
                                        John
Edited by PhotonJohn, 19 November 2019 - 09:29 AM.
#17 descott12
descott12
    Vendor - Solar Live View
  • Loc: Charlotte, NC
Posted 19 November 2019 - 12:46 PM
Star party!
Very best,
The difference in aperture is pretty amazing. Thanks for posting. Of course that only leads to me spending more money... so maybe Is shouldn't have looked!
#18 descott12
descott12
Posted 19 November 2019 - 12:52 PM
Hey Marty,
For your close-ups with the 52 mm aperture, are you using a Barlow of any type or is that straight into your quark?
#19 MalVeauX
MalVeauX
  • Loc: Florida
Posted 19 November 2019 - 01:03 PM
Hey Marty,
Hey Dave,
Not using a barlow this go around.
Very best,
Edited by MalVeauX, 19 November 2019 - 01:41 PM.
#20 rigel123
rigel123
  • Loc: SW Ohio
Posted 19 November 2019 - 02:55 PM
Hey Dave,
Very best,
So your FOV is due to the long f/ratio because of your extensions?
#21 MalVeauX
MalVeauX
  • Loc: Florida
Posted 19 November 2019 - 04:26 PM
Small sensor, ASI290MM :)
Very best,
#22 rigel123
rigel123
  • Loc: SW Ohio
Posted 19 November 2019 - 05:40 PM
Very best,
That has about the same specs as my Skyris236M and I need a 2X telenegative to get a similar FOV with my Lunt 60mm, so I would have to think that your extensions do the same as my telenegative, or am I totally thinking this wrong?  Without a 2X telenegative I get over half the sun in my FOV on my Skyris with the 60mm Lunt.  Oops, or that is a really tight crop.
Edited by rigel123, 19 November 2019 - 05:42 PM.
#23 MalVeauX
MalVeauX
  • Loc: Florida
Posted 19 November 2019 - 05:49 PM
I'm using a 600mm focal length and 2,000mm focal length for the above, with the 290MM sensor. The full disc was a mosaic of 6 panels with lots of overlap.
Very best,
#24 tholan
tholan
Posted 20 November 2019 - 07:20 AM
Thanks for the info Marty. I'll pick some up.
#25 MalVeauX
MalVeauX
  • Loc: Florida
Posted 20 November 2019 - 12:07 PM
Sadly it seems AR2752 is eroding rapidly... barely anything left, just remnants of some plage.
Very best,
