Ioptron AZMP hand controller battery
11 replies to this topic
#1 AstroRick46
AstroRick46
Posted 19 November 2019 - 06:26 PM
On many of the postings about this mount, people have noted that initial alignment issues can be a result of a low battery in the hand controller. As I was having some alignment issues, I thought I would try this simple fix first. The handbook and the forum posts all indicated that the replacement was a 3V CR 1220, which was hard to find, but I managed to find one. Imagine my surprise when I took off the back of the controller and found the battery was a much larger 2032. OK, I happen to have one of those, but I’m not sure how to remove the old battery. if you look very carefully at the photo you will see two tiny prongs on the  + side of the battery to hold it in place. On the opposite side the plastic base has tiny ridges which also grasp the battery. Trying to gently lift the battery out on the plastic end and slide it out merely caused the entire innards of the controller to begin to lift from the shell. Before I totally destroy this thing, has anyone else tried to change the new 2032 size battery, and if so how did you do it?0BF92186-FD7E-4628-BCA4-D3C193A6A3F4.jpeg
#2 biz
biz
    Vendor
  • Loc: New Zealand
Posted 19 November 2019 - 06:37 PM
On many of the postings about this mount, people have noted that initial alignment issues can be a result of a low battery in the hand controller. As I was having some alignment issues, I thought I would try this simple fix first. The handbook and the forum posts all indicated that the replacement was a 3V CR 1220, which was hard to find, but I managed to find one. Imagine my surprise when I took off the back of the controller and found the battery was a much larger 2032. OK, I happen to have one of those, but I’m not sure how to remove the old battery. if you look very carefully at the photo you will see two tiny prongs on the  + side of the battery to hold it in place. On the opposite side the plastic base has tiny ridges which also grasp the battery. Trying to gently lift the battery out on the plastic end and slide it out merely caused the entire innards of the controller to begin to lift from the shell. Before I totally destroy this thing, has anyone else tried to change the new 2032 size battery, and if so how did you do it?attachicon.gif 0BF92186-FD7E-4628-BCA4-D3C193A6A3F4.jpeg
To remove those types of batteries I use a wooden toothpick and just slide it under The battery and between the holder at the side where the clips are . Try that and see how you get on.. it should just pop out.
cheers
Graham
#3 AstroRick46
AstroRick46
Posted 19 November 2019 - 07:10 PM
Thanks, Graham
Just to make sure I understand you correctly, I insert the toothpick under the battery under the + sign side of the battery. Have I got that right. Thanks
Rick
#4 biz
biz
    Vendor
  • Loc: New Zealand
Posted 19 November 2019 - 08:56 PM
Thanks, Graham
Rick
Rick,
As long as it goes between the underside of the battery and the holder it should flick up . Probably best to try and insert it by the clips . I just push it in gently and it flicks free.
cheers
Graham
#5 AstroRick46
AstroRick46
Posted 20 November 2019 - 09:37 PM
Update: Ioptron got back to me. Yes, they changed the battery size which is now a CR2032, which in my neighborhood is much easier to find than the CR1220. However, unlike most devices which use this battery, taking it out is a little more difficult task. You can’t just pop it out because it is firmly gripped at both ends. Per Ioptron you must grasp the battery in the middle and push it toward the two little clips, which are spring loaded. That releases the other end which pops out because the underside contacts are also spring loaded. But be advised the clip springs are pretty strong on my handset and I was afraid I was going to break something. The good news is installing the new battery is a snap. Now I may be the only person on the planet who has never experienced this kind of setup, but just in case I’m not, I thought other owners of this mount and handset might like to know.k
Rick
  • Xeroid likes this
#6 Brule
Brule
  • Loc: St. Louis, MO
Posted 21 November 2019 - 11:51 AM
Thanks for the update on this Rick. I've had some issues with alignment on my AZMP (also tracking issues). I'm still waiting on iOptron to get back to me, but have considered trying this to see if it helps with alignment. Before I order a new battery, have you noticed if this ended up solving your initial problem?
#7 RandallK
RandallK
  • Loc: Nanaimo, B. C. Canada
Posted 21 November 2019 - 12:04 PM
Thanks for the heads-up Rick. Changed my mind now about ordering 20 or so of the CR2012's off Amazon!. I still have a bunch of 2032's. Don't want to pop the cover yet when I don't have to. I suppose all the screws are housed in plastic bosses rather than machined brass. Easy to strip when putting back in to secure the cover.(?)  Incidentally, what is the actual model number of your hand controller. I just got my CEM40 last May...perhaps mine is different..it is a Go2Nova 8407 hand controller.
Edited by RandallK, 21 November 2019 - 12:09 PM.
#8 AstroRick46
AstroRick46
Posted 21 November 2019 - 04:19 PM
I got my AZMP in October, so the battery change must have come before that. My controller is the Go2Nova 8407+. There was a sticker on the back of the controller that said 8407+. I found no reference in the manual nor on Ioptron’s website to indicate what the “plus” was for. Perhaps that was for the change in battery size. I haven’t had a chance to give it a test spin but I will let everyone know what happens. And yes, everything but the screws are made of plastic or nylon. I tried to be very careful when reinserting the screws and I think (hope?) I got it right. I don’t know if the Go2Nova 8407’s are all the same, but it seems logical that they might be. Regardless, if you’re thinking of replacing the battery ( especially if you controller is a “+”) I would see what’s inside before I bought a bunch of replacements. Good luck
Rick
  • Seaquel47 likes this
#9 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 16 December 2019 - 11:05 PM
I had to replace my CR1220 after my ZEQ25 mount stopped saving the GPS data and I had to input the date, time and local coords every time I powered on the scope. So, now that it works fine, I will always have a space 1220 battery with me in the field. Just in case.
#10 gilbert80
gilbert80
  • Loc: Tonawanda, NY
Posted 05 July 2020 - 03:27 PM
My 8407 + battery died, it was the 3VCR 1220, which I cannot find locally. I have
not replaced it yet.
I lost the first two lines on my display after a winter with it in my unheated garage.
Does anyone know if this is due to the battery?  I cleaned the contacts of the  "strip"
and reinstalled them, still no battery yet.   Has anyone lost any lines on their led display?
Any tips?  Please!  Should I try a CR2032 Battery?   Thanks in advance
#11 ArneN
ArneN
  • Loc: Norway
Posted 05 July 2020 - 03:55 PM
I used a piece of tape to remove the battery.
Arne
#12 biz
biz
    Vendor
  • Loc: New Zealand
Posted 05 July 2020 - 10:03 PM
Only if it fits . The coding numbers of the battery will tell you that,,, first 2 digits of the  CR 1220 means diameter of 12mm.
The one you mention CR 2032  means diameter of 20mm... this will not fit into the 12mm battery holder.
Probably should also mention that the last 2 digits means the thickness ie 20 means 2.0mm....32 is 3.2mm.
cheers
Graham
Edited by biz, 05 July 2020 - 10:24 PM.
