Going slightly local.....with M33
6 replies to this topic
#1 pyrasanth
pyrasanth
Posted 20 November 2019 - 02:27 PM
I pointed the RASA 11" with the QHY168C at M33 and using an Old IDAS LP1 filter I took 438 30 second subs- I went for 500 but cloud & fog spoilt a few of the frames.
The IDAS filter does a good job but leaves a green cast which is easily removed- its quite a nice filter.
Conditions were average however the sheer number of subs overcame most of the difficulties.
The telescope was unguided for the entire duration and considering a half moon I'm pleased with the result. However I do wish I could be given a nice clear night with no moon!
As always let me know what you think. The stars have had no post processing so pretty much what I get is seen.
I hope you get better skies than mine!
Best wishes
Mark
Edited by pyrasanth, 20 November 2019 - 02:29 PM.
  • elmiko and ChrisWhite like this
#2 Astroman007
Astroman007
  • Loc: Northern Ontario, Canada
Posted 20 November 2019 - 03:13 PM
#3 hobbyknipser
hobbyknipser
  • Loc: Germany Orange Zone
Posted 20 November 2019 - 03:50 PM
Hi, Mark,
Maybe, you could stretch a little bit more and the core could be a little bit lighter...
Some weeks ago I tried M33 with 644x30 sec, but only a f/4 System and a DSLR...and 1000 frames would have been better for stretching or sharpening.smile.gif
greetings
Andreas
#4 pyrasanth
pyrasanth
Posted 20 November 2019 - 04:16 PM
Hi, Mark,
greetings
Andreas
Good observation.
I think the 30 second exposures on the RASA are a bit too long. I'm going to try 1000 15 second exposures at next opportunity as stretching showed a sheen of background noise which looked a bit like net curtain being pulled over the image. However the core observation is valid so I will see what I can do next time round. I have a collimation issue to sort as well on the RASA- which I'm arranging for Celestron to fix.
#5 44maurer
44maurer
  • Loc: Los Angeles, CA
Posted 20 November 2019 - 04:41 PM
Good observation.
I just got mine back a few weeks ago from being collimated...what a difference! I tried doing myself, spent a lot of time, even spent for an expensive collimator. According to Celestron, it was only off a little, but night and day results in my images.
you can stretch that a lot, I just downloaded and made a few changes from the photo editor on my iPad.
Edited by 44maurer, 20 November 2019 - 04:48 PM.
  • elmiko and pyrasanth like this
#6 pyrasanth
pyrasanth
Posted 20 November 2019 - 05:53 PM
I'm intrigued by your collimation observation- do you have CCD inspector to post the result after the collimation?- If not can you post a before and after collimation picture. My RASA is only a little bit out according to CCD inspector but it puts nearly half of the frame out of focus. One side is very sharp and the other half has little donuts so not good.
Thanks for the stretch. I think I may have a flat issue showing up as I get a halo around bright objects in the middle of the field- telescopes are so much fun-lol
#7 44maurer
44maurer
Posted 20 November 2019 - 08:51 PM
I. Should have a before and after shot I can post, I do not have CCD inspector. I’ll try to post later tonight.
