Cold Weather - Green Laser Pointer - Insulation Fix
15 replies to this topic
#1 Sky_LO
Sky_LO
  • Loc: Oregon USA
Posted 20 November 2019 - 04:03 PM
Hello !
I know there are a lot of threads about Green Laser Pointers.
Many mention how they tend to fail, or work poorly in cold weather.
I had mine out at about 32 degrees (F) and it just sort of pathetically flickered.
Then the light bulb came on and I came up with a possible fix.
I wondered if insulation could help.
Thought I would start a new thread about a fix - rather than trying to insert this
into many several GLP threads.
I took a few pieces of scrap pipe insulation that I had laying around, and cut
two  1 1/2 inch pieces and used them to insulate the rear battery area of the laser.
I used two pieces - to go onto either side of the mount.
The laser was slightly fatter than the pipe this was intended to insulate, so
I had to cut the insulation lengthwise, and splice another piece into the gap.
Closed with metal ducting tape.
So far so good.
I was able to get an hour session in last night in mid 30 degree temps,
and at the end of the session the laser was still working well.
I don't know how low of a temperature this fix will work for, but the insulation fix
was very helpful to keep my laser going for my initial alignments.
Maybe give it a go and see if it helps you also?
-Lauren
Edited by Sky_LO, 20 November 2019 - 04:05 PM.
  • Jim Waters, okiestarman56, Xeroid and 3 others like this
#2 Astroman007
Astroman007
  • Loc: Northern Ontario, Canada
Posted 20 November 2019 - 05:46 PM
That sure as hell wouldn't work up here, LOL.
You were at about 0*C, which is warm here at this time of year. If GLPs are having trouble at 0*C, then I fear I'll never have much success with them (well, half the year anyway).
  • Sky_LO likes this
#3 msl615
msl615
  • Loc: Fairbanks, Alaska
Posted 20 November 2019 - 05:49 PM
I have read about similar solutions before, and yours looks really good. My nights of it being +30F outside are long gone in Alaska now in winter, just like our friend from Northern Ontario above. ...  so the GLPs are all stored inside the house. I still have not come up with a good solution for cold GLP (down to -20F), and really don't want to have to wire up the scope with a dewheater just for the GLP. Hand warmer packs might work, too.   But right now, I work only with cold modified Rigels and Telerads.
Edited by msl615, 20 November 2019 - 05:50 PM.
#4 Sky_LO
Sky_LO
  • Loc: Oregon USA
Posted 20 November 2019 - 06:25 PM
OK OK Canada and Alaska observers.....
yes, I am glad my 32 degrees is my cold nights....not my WARM ones !!
  • Astroman007 likes this
#5 Exciton
Exciton
Posted 20 November 2019 - 06:41 PM
Seems to me that the laser will likely work fine in the cold temps, it is the batteries that cannot hack it.  Not that long ago I was into high altitude ballooning (at atlitudes of 100,000 ft+) where cold temperatures were also a problem for running electronics.  The solution was to use batteries rated for cold temps.  Energizer makes AA, AAA, and 9V ultimate lithium batteries that operate fine down to -40F/-40C.  Try those in the laser pointer and see if it doesn't do a better job of operating in the cold (you want the "ultimate lithiums" not "advanced lithiums").
The packaging can be seen on their website https://www.energize...thium-batteries
Data for the technically inclined can be found at https://data.energiz...om/pdfs/l92.pdf
Exciton
  • Astroman007 and Sky_LO like this
#6 clearwaterdave
clearwaterdave
  • Loc: Western Maine
Posted 20 November 2019 - 07:33 PM
I use pinty rifle lasers and the cheap batteries that they come with and they work down to at least 0*f.,so better batteries may help some lasers.,but some of the cheap ebay lasers don't work no matter the batteries.,the one that came with my Z8 doesn't work below 30* no matter what.,lol.,
Edited by clearwaterdave, 20 November 2019 - 07:35 PM.
  • brentknight likes this
#7 msl615
msl615
Posted 20 November 2019 - 09:37 PM
It is not the power, but rather the electronics and crystals that take an IR signal and boost it to green...that method is temp sensitive. Z bolt has a coldweather GLP that creates the green signal directly, without having to boost it....however they rate it down only to 14F...though there are rumors of them working OK @ 0F.
#8 NorthernlatAK
NorthernlatAK
Posted 20 November 2019 - 10:05 PM
Our local wildlife refuge needs someone to give sky tours and I seem to be the only one qualified that might have time. A laser pointer would be necessary to do this properly so will probably order one. Temps are definitely a problem when stars are visible here, so I will try some insulation. 32° seems pretty balmy here at times except this year it's the norm and warmer. We haven't had a single transparent clear evening here since last winter. I don't even think we've reached single digits yet...
Sure would be nice if there was a true cold weather laser out there for us. Or almost anything electronic for that matter.
#9 Sky_LO
Sky_LO
  • Loc: Oregon USA
Posted 21 November 2019 - 12:11 AM
Yes my laser is the inexpensive generic ebay variety.
All I can say is it was being really " iffy " in anything under 40 degrees.
In prior useage.   (its a piece of junk)
But the insulation seems to be helping.
Used Scope with laser -again- tonite - High 30's
Laser very strong - no issues - with the pipe insulation on it.
-Lauren
  • clearwaterdave likes this
#10 Andynator
Andynator
  • Loc: West Central Ohio, USA
Posted 21 November 2019 - 10:45 PM
Rubber-band a disposable hand-warmer to it.
  • Greyhaven and Myk Rian like this
#11 Sky_LO
Sky_LO
  • Loc: Oregon USA
Posted 22 November 2019 - 04:04 AM
Yep, the disposable hand warmer rubber banded is probably the best approach.
'Low temp' rated batteries is also worth a try.
The insulation approach seems like it should work.....It seems helpful.... but only for a short time.
and not if its close to freezing.   My laser fizzled again.  we had lower temps tonight - about 28 degrees.
The insulation kept it going just long enough for an alignment.
Any other ideas?
Any other insulation approaches?
Thanks all for your ideas and input.
I may have to use a red dot finder in the cold rather than the laser.
-Lauren
#12 Myk Rian
Myk Rian
  • Loc: Hartland, Michigan
Posted 22 November 2019 - 07:32 AM
This.
#13 clearwaterdave
clearwaterdave
Posted 22 November 2019 - 05:01 PM
I tried the handwarmer and could not get it to cover the laser enough.,even with a few of them.,trying to get around the holder made it more trouble than it was worth.,
  The pinty lasers are only $25.,the remote switches have failed on me but the lasers have all worked fine.,I have them on 5 scopes and they stay at outside temps 24/7,.cheers.,
#14 rnabholz
rnabholz
  • Loc: Iowa
Posted 22 November 2019 - 05:36 PM
Here is my solution
https://www.cloudyni...y/?fromsearch=1
  • Sky_LO likes this
#15 Sky_LO
Sky_LO
  • Loc: Oregon USA
Posted 23 November 2019 - 05:01 PM
Right, a hand warmer plus insulation.
I like it, I like it, I just might wanna try it.... !
-Lauren
  • rnabholz likes this
#16 Sky_LO
Sky_LO
  • Loc: Oregon USA
Posted 28 January 2020 - 05:08 PM
Ok so I did further testing...…and I have a new fix to report.
I had indicated the insulation helps...…This is not necessarily true.  It will be hit or miss.
Point of clarification:  I have two telescopes, with two GLP's
Both are cheapo GLP's from ebay.
I put insulation on both.
One of them works pretty well in the cold with insulation.
The same insulation on the second one does nothing, and it is horrible in the cold (flickers)
Here are other things I tried
1) Tried a chemical hand warmer - created a plastic "sheath" to hold it in place from a water bottle.
     result = did not work.   The plastic cover did not allow the hand warmer to get the air needed for the chemical reaction
                  the hand warmer did not heat and the idea was a fail.
2) Tried a chemical hand warmer - with a "chicken wire" cover to hold it in place.  The idea being that the chicken wire would allow
     airflow to the hand warmer to maintain the chemical reaction.
     result = did not work.   There was still too much contact between the laser and the chemical hand warmer to restrict air.
                 The chemical hand warmer again did not heat properly and the idea failed, laser still just barely flickering.
3) Tried to rubber band a chemical hand warmer to the laser.
     result - did not work.   I think my laser pointer holder interfered too much with the hand warmer and I could not get the     hand warrmer in a decent position with just rubber bands.    I could not get the hand warmer heat to transfer the heat  to the laser this way.
I found a new inexpensive fix / solution that I believe will work.   I probably won't know with certainty until next winter, as our 30 degree (and lower) temperatures are gone and we are moving into overnight lows in the 40's.
I found a battery powered "foot warmer" for under $20 on amazon.
It is on a cardboard like material.    I rolled the cardboard around the laser, heat side in, and then taped it with electrical tape.
I upgraded the battery pack from two aa batteries (in series wiring for 3 v) to two 3.7v  18650 batteries (wired in parallel) for slightly higher power, plus I have extra 18650 batteries and a charger for them.
The heat gun registered the laser at 111 degrees.  In my house at about 70, this is a 41 degree increase.
Looks like this method will be effective to keep those cheapie GLP's working in the cold.
I mounted the battery holder to the scope with silcon glue (goop)  Now if I will be observing in cold temps, I can just pop in
batteries for the laser warmer.
Photos :    1) How the foot warmer comes out of package    2) Temp gun test     3) On the Scope
Edited by Sky_LO, 28 January 2020 - 05:15 PM.
