Remote Telescope
1 reply to this topic
#1 Toodle
Toodle
Posted 21 November 2019 - 01:34 PM
Hi all,
I've just dusted off my ~40 year old wedge mounted C8 (and a fortune of old oculars), which I've used only sporadically for the past 30 years. My plan is to set it up in a modified tool shed in our backyard with visibility of a patch of sky overhead, and observe from the comfort of my den. (It's getting cold here in Apex, NC, and, at the age of 80, my blood is a little thin.) I've checked out the telescope optics, and hooked up an old SPC900NC camera to it, with a ~75 ft USB active cable running to an old PC. So far so good! I would like to get a better camera, and I'm thinking about the QHY5111 CMOS 178C camera, which I would like to hook up to my circa 2012 MacBookAir which only has a USB2 port. Will this work?
As you can see, I'm a novice at this, and would appreciate any help you might provide.
PS. I've got some other old stuff, e.g., a Lumicon Sky Vector and a Jim's Mobil Mototrak II, which I can add later.
Terry
#2 Ken Sturrock
Ken Sturrock
    Cardinal Ximenez (No one expects the Spanish Inquisition)
  • Loc: Denver, CO
Posted 21 November 2019 - 01:47 PM
Welcome back, Terry.
As this is the Beginners' Forum (which focuses on the really simple fundamentals of astronomy):
There are several routes that you can probably go with a camera. If your interest is real time observing with a camera then I'd suggest that you start a thread up in the Electronic Assisted Astronomy (EAA) Forum. If you are more interested in using longer duration exposures in order to create images for aesthetic enjoyment or science, then I'd suggest that you head on over to the Beginning & Intermediate Imaging (B&II) Forum. Finally, if you are more interested in the nuts & bolts of building an observatory, the site also has a forum for observatory builders.
Best of luck.
