AT 102ED + ES82 30mm or a SW 100ED
refractor
51 replies to this topic
#26 The Luckster
The Luckster
  • Loc: Los Angeles, CA
Posted 27 November 2019 - 11:44 AM
Congratulations! You have made a terrific purchase and I suspect you will appreciate your SW 100ED every bit as much as I do mine. Some folks have commented on the focuser, I will say it is perfectly serviceable and only needs a bit of adjustment. Here are two sites that will clue you in on adjusting and "supercharging" your focuser:
https://teleskop-aus...g_justieren.pdf
https://www.astronom...rayford-focuser
These are not difficult operations, do what you think you need to if you think your focuser needs tweaking. Have fun!
Clear Skies,
Thank you, Brian.  I'm not afraid of getting inside that focuser for a tune-up...so thanks for the links.
CS
Jason
#27 Jon Isaacs
Posted 27 November 2019 - 01:05 PM
It'll be fine;  It's all in the balancing.
And thanks! I'm glad I chose this (modified) option.  Also, I'm sure the SW's focuser will be just fine for me to begin with.
CS
jason
You will be mounting this on a TW-1?
 If so, based on my experience with a shorter but heavier 4 inch, the problem is not balance, it's a lack of rigidity which leads to vibration, wobble and overly long settling times, it may never settle..With a scope easily capable of over 200x, a solid mount is important.
The Focusers are quite decent and with a bit of adjustment will handle heavy eyepieces like the 31 mm Nagler.
  • BKBrown, The Luckster and nicoledoula like this
#28 Jon Isaacs
Posted 27 November 2019 - 01:14 PM
CS
Jason
Jason:
The first link describes the adjustment of the preload for the Synta two speed. That should be all that's necessary.
The second link describes making sure the draw tube flat is flat. That was in issue early on with the single speeds when they came out in 2003 but I have not found that to be an issue with the two speeds.
These can be very smooth and yet capable Focusers. They're far better than the oldvrack and pinion Focusers you mentioned earlier.
#29 The Luckster
The Luckster
Posted 27 November 2019 - 03:30 PM
Yes, and I'm not worried.  Yes, the SW 100 f/9 is long, but it also weighs the same as my ST120; accessories, rings, etc.  Longer tube, different center of gravity, balance.  I have no issues with the ST120 on the Twilight 1.  Yes, the 120 is shorter, but the SAME weight.  Balance.  Heck, I can get the ST 120 with all accessories to work on my Twilight Nano!!!
I also have anti-vibration suppression pads which I use all of the time, and these help enormously with all of my setups.
I am not worried at all.  Besides, If there is a mount issue with the SW 100, I'll just get a more robust Alt-Az mount.  I dislike EQ...
However, thank you ALL for your concerns and warnings and EXPERIENCE, this is great information that perhaps will serve OTHERS in their quest for knowledge regarding the aforementioned telescopes, mounts and accessories.
CS
jason
Edited by The Luckster, 27 November 2019 - 03:36 PM.
#30 punk35
punk35
  • Loc: Adrian Michigan
Posted 28 November 2019 - 12:43 PM
Everyone’s definition of “ acceptable stability” is different. As an example, Jond is happy with 100 and 120ED’s on a CG4. My 4” refractors are perfect for my SVP, but when I put a 120/8.3 achro on it, it was to wiggly for me personally. If you’re happy with your current scopes on the mounts you have now, I’m sure you’ll be good with the ED100 on it also.
  • Steve Cox, The Luckster and Jond105 like this
#31 The Luckster
The Luckster
Posted 01 December 2019 - 11:32 AM
The SW 100 arrived last night, but it's rainy out here and will be for some days to come.
I was lucky enough to sneak it in the house, and secretly break down and store the shipping box...wink.gif
Funny thing is, "I WILL GET CAUGHT", always do...
Anyway, I look forward to first light and will report back with my initial amateur impressions.
CS--not here
jason
  • punk35, BKBrown, brentknight and 2 others like this
#32 The Luckster
The Luckster
Posted 03 December 2019 - 03:11 PM
Un-boxing, initial impressions and some weight testing.
First light is still off here, but I finally got to explore and examine my new SW 100ED f/9.
All components in the carry case were properly sealed, save for one lose item: The focuser lock screw.  8x50 finder, nicer than anticipated.  I was not going to use the finder, but I think I'll try it out, at least.  2" diagonal seems nice-enough, and has compression rings for both 2" and 1.25".  I'll try it out.  Opitical tube is free of blemishes, and free of internal debris chunks.  There is some small fuzzies within the tube, typical in my opinion (and a lot less than in my other scopes...).  Glass surfaces seem to free of issue, all looks very good.  I'll give the oculars a spin or two, just to see.  However, the SW 5mm I assume is directly related to my BST 5mm Starguider...Still, a nice ocular.  Tube and rings all seemed well, and as a unit as a whole, very nice and very new.  Not a return.
Next, testing the "dreaded" focuser.  (Now keep in mind where I come from in regards to all of the telescopes I have or had...)
Smooth, all of the way in and all of the way out; smooth.  No tightening, no grinding nor any looseness.  Wow, the focusing tube does not "wiggle" like all of my other refractor focuser tubes.  This SW focuser unit is not loose, very snug but does not bind...all of the way in and out.  So far, this is the BEST focuser I all ever used at this point.
Okay, time to add some ocular and diagonal weight, along with some dangerous angles (indoors and over a lot of pillows...).  I started off big: Orion 2" Twist-lock with ES82 30mm 2" ocular.  There is no need to go long with my results; rock-solid with no looseness, grinding, coming lose, slippage and at very disturbing angles and focus lengths.  I even shook the rig.  Simply put; I could not coax any form of issue with the SW focuser while bearing a hefty load at all.  It's as if the tube, focuser, diagonal and ocular were one solid unit.  I have never experienced that sensation before with any of my rigs I have used.  Now, I am not too thrilled with the two inch focuser set screws with NO compression ring, but It ain't a deal breaker for me, and the set screws did lock down a weighty load... As of this point, I see no reason whatsoever to disassemble the focuser for a tune-up.  It is perfect for me as it is!
So, in my opinion the SW focuser is of excellent quality and definitely the best I have used to date.  The entire package is of very good quality, fit and finish very good as well.
All of this goodness for $626 USD new, glad I chose this option.
Thank you all for your wisdom, knowledge and experience.
CS
jason
Edited by The Luckster, 03 December 2019 - 03:16 PM.
  • punk35, eros312, BKBrown and 3 others like this
#33 Tyson M
Tyson M
  • Loc: Alberta, Canada
Posted 03 December 2019 - 03:18 PM
CS
jason
The last two synta focusers I had could handle a 31N and 2" diagonal with no issues.
I think preowned you take your chances because of people hanging heavy camera gear off them but new, the dual speed focusers are very good right from the start.
  • The Luckster likes this
#34 Jond105
Jond105
  • Loc: Detroit
Posted 03 December 2019 - 03:25 PM
http://www.scopestuff.com/ss_fas2.htm
just going to leave this right here for you. I agree, I wish at the price point they gave us compression ring visual back, but scope stuff does have us covered if need be. Or the more expensive Baader, but this one is just as good.
So glad you’re liking the scope and everything arrived tip top shape for you. My brand new 120ED couldn’t do what yours is doing(focuser) when it came to fine focus on the ES82 30mm. Congrats on everything. In fact, when me and Wade(Punk35) compared our focusers on my 1st 100ED and his 102ED, he may remember the stiffness and slight grind in mine.
  • punk35 and The Luckster like this
#35 Agatha
Agatha
  • Loc: Wisconsin
Posted 03 December 2019 - 03:56 PM
Yes to the ScopeStuff adapter mentined above by Jond105.   I'm sure there are many people who have changed the stock one out for the SS version.  It is very nice.
#36 punk35
punk35
Posted 03 December 2019 - 04:48 PM
Sounds like your focuser is just fine.
I agree about the SS adapter. When I had my Celestron C4R I swapped out the original R&P focuser for an ED80 single speed crayford. It was very smooth and strong AFTER I filed the bottom of the draw tube flat with my wet stone. The only other thing it needed was the mentioned adapter, which I never bought. I wish I had, so it wouldn’t look like a beaver tried to eat my diagonal.
I’ll be very interested to hear your comparison when you get it of the AT focuser vrs the SW.
Congrats and I’ll be looking forward to all your reports.
#37 Wildetelescope
Wildetelescope
  • Loc: Maryland
Posted 03 December 2019 - 05:40 PM
Thank you all...it is done.  Decision made, order placed.
Thank you, Gene, for your PM.
I purchased the following:
Sky Watcher EvoStar 100ED f/9
ES82 30mm 2"
I'll need to add another Alt-Az tripod in the future, I'll just get another Twilight 1 (the AT version this time).
Thank you all, again...reports to follow soon.
CS
jason
There is something special about a 4 inch f9 scope.  As close to a do it all scope as I have.  You will be pleased!
jmd
#38 BKBrown
BKBrown
  • Loc: Under dark skies in central Virginia, USA
Posted 03 December 2019 - 11:51 PM
Congratulations Jason, sounds like you got a really good one waytogo.gif  Can't wait to hear your first light impressions, I suspect my earlier endorsement will be vindicated smile.png
Clear Skies,
#39 gene 4181
gene 4181
  • Loc: n.e. ohio
Posted 04 December 2019 - 08:06 PM
    Luckster , enjoy the scope  . Sure couldn't   beat that price  ,    IF I didn't  already have  the AT 102  ,   smile.gif
#40 punk35
punk35
Posted 04 December 2019 - 08:17 PM
Even though I have an At102ED, I still want an ED100. I think to myself “ my C4R on steroids ( fpl53).
#41 The Luckster
The Luckster
Posted 05 December 2019 - 10:13 PM
This focuser adapter will be my next equipment purchase, but for now I can use the SW diagonal (if it's up to the task, my Orion Twisty blew me away with it's transparency).  Not worried about Beaver gnaw marks on the SW.
CS
jason
#42 The Luckster
The Luckster
Posted 05 December 2019 - 10:18 PM
Clear Skies,
Though apples and oranges, I should borrow back my old Meade 102 f/5.9 acro and compare the two.  But that would mean less time with the new SW 100.
CS
jason
#43 Jond105
Jond105
  • Loc: Detroit
Posted 05 December 2019 - 10:19 PM
CS
jason
I love my Orion 2” as well
#44 The Luckster
The Luckster
Posted 10 December 2019 - 10:24 PM
Ordered...thank you!
CS
jason
  • Agatha and Jond105 like this
#45 The Luckster
The Luckster
Posted 13 December 2019 - 09:38 PM
Just an update; nothing to report at this time regarding first-light.  I'm caught between cloudy skies and word load.  This is my heavy time of year at work, so working long hours.
When first-light happens, I'll definitely post back.
CS
jason
#46 The Luckster
The Luckster
Posted 16 December 2019 - 12:53 PM
I had first light with the SW100 last night, even though seeing conditions were Poor+, I spent an hour with Orion.  Best viewing of M42 I have ever had, even with Poor seeing, and the views got a lot better when I added the O-III filter.  The nebula was large, grand and sweeping in the ES82 30mm.  With the 30 mounted, I could distinctly resolve the Trapezium's four main components.
All I can say is that I'm impressed with the visual quality of this refractor at it's price-point.  Pin-point stars, great transmission with M42 in my opinion and color seemed good from what little I could tell.  The focuser was just pure heaven last night, seriously.  Even with the ES 30 Keg mounted, butter-smooth focus in both course and fine.  And, focus held without using the lock screw, regardless on angle.  The 8x50 finder I like, nice sharp pin-point stars across the field, but the mount housing is problematic: I really had to "contort" the finder in the housing just to center the cross-hair on target.  I can only assume that the stamping/casting of the finder bracket is off...
As suggested, I upgraded the stock focus adapter on the SW100 to a ScopeStuff Compression focus adapter...very happy with that!
All in all, this is a fantastic tool with a lot of nice bells-n-whistles at a great price-point ($626 when I bought), I am thoroughly satisfied.
MG 4013 LR LR
CS
jason
  • punk35, eros312, Agatha and 4 others like this
#47 aa6ww
aa6ww
  • Loc: Sacramento, Calif.
Posted 19 December 2019 - 03:22 PM
 F/9 is nice when your pushing the optics for double star splitting, giving you that extra focal length you sometimes need to crank up the magnification to split the tight doubles.
...Ralph
#48 drd715
drd715
  • Loc: Fort Lauderdale
Posted 19 December 2019 - 04:33 PM
...Ralph
Or F-11
Sent from my SM-N950U using Tapatalk
  • gene 4181 likes this
#49 BillP
BillP
  • Loc: Spotsylvania, VA
Posted 19 December 2019 - 05:15 PM
These f/9 doublets are IMO the best visual color-free refractor values out there.  100s have a lot more punch than 80s IME.  I just go one of these type scopes and absolutely loving it, especially how light they are and how fast they acclimate.  Posts 25-26 gives some observing details - https://www.cloudyni...blet/?p=9821511
  • The Luckster and 25585 like this
#50 ltj
ltj
  • Loc: Southeastern Pa.
Posted 13 January 2020 - 09:08 PM
There's another SW 100ED here waiting for first light too! Seems like the weather gods decided to make it rain or be cloudy here until next year...
Very impressed with the scope so far, but need to get it out!
Jeff
  • The Luckster and Jond105 like this
Also tagged with one or more of these keywords: refractor
