GS Server Testers
15 replies to this topic
#1 Rmorgan
Rmorgan
  • Loc: Oxford Florida
Posted 29 November 2019 - 09:01 AM
Hi, I'm looking for testers of GS Server, my open source ascom driver for synta mounts.  If interested please visit https://github.com/rmorgan001/GSServer
--Rob
  • Paul Garais and pshea1128 like this
#2 SDTopensied
SDTopensied
  • Loc: Atlanta
Posted 30 January 2020 - 03:44 PM
Kudos to you Rob!  I really like this, by the way.  Very nicely done UI and works well.
A viable alternative to EQMod.
-Steve
#3 Rmorgan
Rmorgan
Posted 30 January 2020 - 04:27 PM
-Steve
Thanks Steve!  If you plan on using GS Server please join us on https://groups.io/g/GSS
--Rob
#4 Paul Garais
Paul Garais
  • Loc: Sendenhorst, Germany
Posted 16 July 2020 - 03:16 AM
This came to my attention due to a search for EQMOD alternatives that support features like auto-home and so forth. For me personally it is important to have an option for EQMOD since it won't work forever without updates and some issues are there.
So a few questions:
– Is this just a low-priority hobby project or do you plan to work on it years ahead?
– Does it have an AutoPEC feature or something similiar?
– Does it support multiple connections at a time, like connection from PHD and imaging software at the same time?
Sorry if some of these questions are stupid or have obvious answers. Just want to be sure ;)
—Paul
#5 Rmorgan
Rmorgan
Posted 16 July 2020 - 05:07 AM
Hi Paul,
I don't get paid so it's a hobby but have been working on it for a few years now and will continue. I have another person helping so that helps.
Currently it supports mounts that support PPEC, but there are new guiding techniques which helps.  I have an old Atlas EQ-G and guiding alone does the trick.
yup, works with everything out there, that I know about.
--Rob
  • Paul Garais likes this
#6 Paul Garais
Paul Garais
Posted 16 July 2020 - 05:32 AM
Hi Paul,
--Rob
Great! Thank you for your fast response. As soon as summer is over and the night comes back to my place, I will give it a try with an EQ6-R and EQ8-R!
#7 sn2006gy
sn2006gy
    Vendor - Rockchuck Summit Observatory
  • Loc: Austin, TX
Posted 03 October 2020 - 10:21 AM
Curious if anyone is using Gsserver?
I tried it briefly but seemed like i got stuck in calibration hell with PHD2 over correcting more than it would with eqmod.  Since i'm going full remote, the idea of having a visual representation of telescope model (as well as a camera from my pc mounted below) would really be nice.
Just curious if people have had much luck running with this and what steps they may have took to tweak it all.
#8 Paul Garais
Paul Garais
Posted 03 October 2020 - 10:37 AM
Fought other issues while prepared for a streak of clear nights. Did not want to risk to loose them. Just installed it and tried out briefly the general functions. No more than a dry run so far. But it worked. Still have to test guiding, meridian flip etc..
  • sn2006gy likes this
#9 streambox
streambox
  • Loc: Borrego Springs, CA
Posted 01 January 2021 - 09:59 PM
Is it possible to use GS Server with IP connection to the mount ( AZ GTI in my case).
I see only COM port in settings?
Thank you!
#10 Rmorgan
Rmorgan
Posted 01 January 2021 - 10:30 PM
AZ mode isn't available yet in GS Server.
#11 streambox
streambox
Posted 01 January 2021 - 10:33 PM
Thanks for reply, it is actually in EQ mode, but I can only use IP connectivity
#12 Rmorgan
Rmorgan
Posted 01 January 2021 - 10:37 PM
no direct IP but you may be able to use a virtual port.
https://stargazerslo...34-eqmod-azgti/
#13 CyberianIce
CyberianIce
  • Loc: 45°40'N 18°59'E
Posted 18 June 2021 - 11:07 AM
I used it for a while with my CG5 belt+astrorq build. It always complined about limits, but I seen no option to set limits, neither I use them.
#14 pshea1128
pshea1128
Posted 04 July 2021 - 09:37 AM
--Rob
Hi Rob,
Are you still looking for testers?  I just started using GS Server this week with my Atlas II EQ-G mount (aka Skywatcher EQ6-R Pro).  So far, so good.  I need to go through the documentation a little closer for some of the finer points, but it works well in SharpCap, PHD2, and Starry Night Pro.
  • Rmorgan likes this
#15 Rmorgan
Rmorgan
Posted 08 July 2021 - 02:44 PM
Testers are now located on https://gss.groups.io/
#16 EmeraldHills
EmeraldHills
  • Loc: Louisville, Kentucky
Posted 08 July 2021 - 05:37 PM
It's all I use -- since January. 100% success. Never a single failure for me.
