Is there a 5-6" Mak or SCT with push-to capabilities?
24 replies to this topic
#1 15°North
15°North
  • Loc: Goa, West Coast of India (usually)
Posted 30 November 2019 - 01:26 PM
2 min on google didn't show anything, but maybe my search query is off.
#2 Jim Davis
Jim Davis
  • Loc: Lewisberry, PA
Posted 30 November 2019 - 01:34 PM
How about this one: Meade LX70 - https://www.meade.co...tov-6-inch.html
#3 SeattleScott
SeattleScott
Negative. Of course you can always purchase them separately. AYO Mount for around $900 with encoders, purchase OTA separately, then buy the computer. It will be a lot cheaper to get a GoTo model.
Edited by SeattleScott, 30 November 2019 - 01:37 PM.
  • havasman likes this
#4 SeattleScott
SeattleScott
Posted 30 November 2019 - 01:35 PM
That is fully manual. He is looking for push to, like Intelliscope.
  • 15°North likes this
#5 Eddgie
Eddgie
Posted 30 November 2019 - 02:38 PM
I assume that you mean mounted on a simple Alt-az mount without any kind of electronics.
This one comes on many different mount options, three of which are "push to."
https://explorescien...-mc1271900maz01
And this one is the 6" version:
https://explorescien...-mc1521900maz01
There are many 127 and 152mm MCTs on the market, and adding the Alt-az mount of your choice is easy to do, but if you are looking for a package, options are rather limited.
Edited by Eddgie, 30 November 2019 - 02:45 PM.
#6 vtornado
vtornado
  • Loc: Northern Illinois
Posted 30 November 2019 - 02:47 PM
Hi you can mount your scope on a vixen porta  II,
Then check out post #58 here.
https://www.cloudyni... circles porta
Shows making your own degree circle, and you can use a digital angle meter to get elevation.
#7 dr.who
dr.who
Posted 30 November 2019 - 02:52 PM
There is a Skywatcher AZ-GTi package with a 127mm/5” Mak for $625 USD.
#8 15°North
15°North
Posted 30 November 2019 - 09:30 PM
Where should I hunt for this package?
#9 15°North
15°North
Posted 30 November 2019 - 09:33 PM
I guess I assumed the meaning of 'push to' was universally understood. Seems I was wrong. I want a computerized system that will guide me to the targets, but not with motorized drives. I provide the pushing, but a computer tells me where to go, like the Intelliscope series, but in a Mak or SCT.
#10 dr.who
dr.who
Posted 30 November 2019 - 11:23 PM
A google search of “Skywatcher AZ-GTi 127mm” will get you what you need
#11 dr.who
dr.who
Posted 30 November 2019 - 11:28 PM
This actually becomes more expensive.
You need:
1. A Mak or SCT
2. A mount that can be fitted with encoders for a DSC
3. A DSC like the Nexus DSC
4. An encoder kit for the mount
Astro Devices, maker of the Nexus DSC, has encoder kits for several manual alt/az mounts that run about $250 USD. This is the best option I have found for push to. As is the Nexus DSC. But together they will cost more than the Skywatcher 127mm Mak package and doesn’t include the scope or mount..,
#12 SeattleScott
SeattleScott
Isn’t the AZ-GTI motorized/GoTo?
Push to is very popular with giant Dobs where motors would be heavy and cost prohibitive. The same technology is easily adapted to an alt az mount, and the high end mounts are designed for this. So what you are asking is routinely done, but you are talking expensive mounts and expensive push to systems, because none of this stuff is mass produced like an Intelliscope.
Scott
Edited by SeattleScott, 30 November 2019 - 11:30 PM.
#13 15°North
15°North
Posted 01 December 2019 - 05:07 AM
Is a 6" pushing it for the same mount?
#14 gfamily
gfamily
  • Loc: North Cheshire, UK
Posted 01 December 2019 - 05:45 AM
Scott
AZ GTi is motorised/GOTO, but it also has encoders, so that when you loosen the clutches and move it manually it doesn't lose alignment, and has the advantage of allowing tracking after a manual move.
This is unusual in lower priced mounts.
Thus the OP could use it semi-manually.
  • SeattleScott likes this
#15 dr.who
dr.who
Posted 01 December 2019 - 07:08 AM
If it is a Mak or SCT, no. People put a Takahashi FC100 refractor on it with zero problems. A 6” Mak or SCT will be fine as long as it is not a Comet Hunter or equally large Mak. The standard Skywatcher 6” Mak should be OK and the Celestron 6” SCT is as well.
#16 gfamily
gfamily
Posted 01 December 2019 - 08:02 AM
As dr.who says, it should be OK - it has a nominal payload of 5kg.
#17 gfamily
gfamily
Posted 01 December 2019 - 09:19 AM
A word of warning though - SkyWatcher also sell a mount called the AZ GTe - and this doesn't have the encoders.
I've seen it bundled with a short refractor which looks initially like a great bargain, but I think the absence of the encoders is a significant downgrade in its capabilties
#18 Eddgie
Eddgie
Posted 01 December 2019 - 09:28 AM
What you want then is a system with digital setting circles and that is something that I have not seen sold as a complete package with either a 5" or 6" MCT.
Maybe there is one out there, but if that is what you really have to have, then I think it is more likely that you would have to build up a mount and that can be quite expensive.
If you really don't want motors though, that is a tight box and if you are willing to accept motors, then why not get Go2?
Perhaps you could get something like the Orion 6" Intelliscope table top reflector and put your own OTA on it. I an not recommending that you do that, but that would be maybe a cheaper way to do it than build up a system using a good Alt-az mount, encoders, and DSCs.
Anyway, so sorry, but I don't know of an offering that has this combo.
Edited by Eddgie, 01 December 2019 - 09:32 AM.
  • austin.grant and Hesiod like this
#19 austin.grant
austin.grant
  • Loc: Albuquerque, New Mexico
Posted 01 December 2019 - 09:37 AM
+1
I was literally typing that you could get the 6" intelliscope and swap OTA's when Eddgie's reply popped up. Same caveat: It's not what I would do, but if you are adamant on Push-To without motors, this would work.
Oh, and as far as I know, the AZ GTI mentioned above won't function like Push-To. It's not going to have arrows telling you where to push the OTA to get to an object.
Edited by austin.grant, 01 December 2019 - 09:37 AM.
#20 austin.grant
austin.grant
Posted 01 December 2019 - 09:39 AM
Perhaps this would be something you could utilize to roll your own solution:
https://astro-gadget...x-orion-skyline
#21 Hesiod
Hesiod
Posted 01 December 2019 - 01:35 PM
You could simply purchase the Intelliscope 6" and stick with it (the 6" f/5 reflector provides more flexibility and will be much more comfortable to use).
Several mounts could be fitted with "digital setting circles" systems to become "push-to", but those systems are not exactly cheap (you need the computer, the encoders, and obviously the mount).
Also take note that the Skywatcher Mak6" is noticeably larger and heavier than the 5" model (in fact is more or less as big as the C8), and will not work on mounts as light as the Porta (which is the cheapest alt/az which could be fitted easily with "push to" systems); to tell the truth, I would suggest to stay away from the Porta even in the case you will opt for the 5" as the mount is rather marginal for it
#22 aeajr
aeajr
  • Loc: Long Island, New York, USA
Posted 01 December 2019 - 06:41 PM
The closest you can come to this is to buy the Mak or SCT on a good AltAz mount.
Get the SkEye app.
https://play.google.....skeye&hl=en_US
Review of SkEye
http://lavadip.com/skeye/
Virtual DSC
A unique feature of SkEye is that you can strap your phone to a telescope (or a pair of binoculars) to get a PUSHTO guide, without additional equipment! You only need to follow a simple alignment procedure. Find out more about it in the Documentation section.
http://lavadip.com/s...umentation.html
#23 15°North
15°North
Posted 01 December 2019 - 11:26 PM
Get the SkEye app.
Review of SkEye
Virtual DSC
I don't suppose there's an iOS variant of this? I dunno maybe I could buy a $100 android phone for this..
#24 aeajr
aeajr
Posted 01 December 2019 - 11:30 PM
Check with the author.
#25 luxo II
luxo II
  • Loc: Sydney, Australia
Posted 02 December 2019 - 11:16 PM
Larger version here with iPhone and SkySafari:
https://www.cloudyni...s-ii-skysafari/
For a 6” you could use a smaller mount with encoders, that’s up to you. The AYO Swiss come to mind, or the Rowan Astro AZ100 (overkill). The Hercules is a possible candidate but you’ll have to speak to Astro Devices to find a solution for the encoders.
Edited by luxo II, 02 December 2019 - 11:25 PM.
