Replacing finder scope for illuminated
6 replies to this topic
#1 wheelers4life
wheelers4life
  • Loc: Baird TX
Posted 02 December 2019 - 10:03 PM
Today I received my Orion CT 80 refreactor. I received my illuminated eyepiece. I forgot to order my dovetail bar. So I ordered it today. What do you think about this scope for an illuminated finder scope, It is not plastic like I heard other people say about this scope. It does not feel very well made though. I might even try to image with it just to see how it does for some of the larger dso that I cannot fit in my scope. I was wondering If I should send this back and just purchase a illuminated finder scope or just use this one.  This will go on top of my edge hd 8 with my CGEMII mount.
#2 speedster
speedster
  • Loc: Abilene, Texas
Posted 02 December 2019 - 11:07 PM
I don't have an answer but I'm 20 miles west of you.  I thought it might be nice to get a list of people in our area in case we ever want to do something.
#3 wheelers4life
wheelers4life
  • Loc: Baird TX
Posted 03 December 2019 - 01:22 AM
Sounds good
#4 SloMoe
SloMoe
  • Loc: Washington State
Posted 03 December 2019 - 08:19 AM
Do you have it in a set of alignment rings to mount it in?
Won't need a redicel eyepiece if you can't adjust it's aim,
Dove tailed piggy back? Yes, it will have the versatility of selected eyepieces and a wider fov than your edge.
Not a bad scope for low mag wide field views,
I was going to use a similar scope as a finder for my dob, but the weight of it got past my limit so I re-purposed it as a terrestrial spotting scope.
Higher magnification will bring on the CA factor, but below 50X should be ok.
I use this online calculator for my eyepiece selecting,
http://www.csgnetwor...m/telefov.html
A 20mm 82° will give you a magnification level of 20X and a TOFV OF 4.1°
So like a TV Pan 19 would be great in it for your needs.
Edited by SloMoe, 03 December 2019 - 08:29 AM.
#5 wheelers4life
wheelers4life
  • Loc: Baird TX
Posted 03 December 2019 - 08:47 AM
Yes I have the rings. Just waiting on the dove tail bar. Awsome sounds good
#6 Jon Isaacs
Posted 03 December 2019 - 09:06 AM
There are no 20mm 1.25 inch 82 degree eyepieces.  The maximum possible field of view with this scope is slightly less than 4.0 degrees unless one goes with a 2 inch focuser. The 19mm Panoptic provides a 3.05 degree TFoV.
I'm not sure why the OP wants an 80mm finder on a GOTO scope?
It's the focuser that's plastic, the ST-80 weighs about 3 pounds, the CT 80 about 2 pounds.
#7 wheelers4life
wheelers4life
  • Loc: Baird TX
Posted 03 December 2019 - 11:24 PM
I'm using it as a finder to help alignment. I cannot see the cross hairs. So I went this way for an illuminated scope
