Solar animations over the past few months
6 replies to this topic
#1 Scruffy-the-janitor
Scruffy-the-janitor
  • Loc: Tennesse
Posted 03 December 2019 - 09:40 AM
Finally figured out how I can post my solar animations because the file sizes are so laughably large. These are just a few random ones from the past few months or so. Most usually last about 1-2hrs, with 15 seconds of video taken about every 2 minutes, stacking the best 10% of frames. Still figuring out an editing technique I 100% like.
All gear was the:
Lunt LS80THa B18000. Single stacked
ASI178MM
CG4, aftermarket guiding
Sharpcapture, Autostakket!3, IMPPG and GIMP
Please click on the images and be patient as each file is fairly large, (even after I downsized them)
Mercury Transit
get.jpg?insecure
Aug 19th Proms, Earth for scale
get.jpg?insecure
Nov 16 Prom and hint of an active region
get.jpg?insecure
Aug 18 Proms
get.jpg?insecure
  • johncandy, rigel123, hopskipson and 4 others like this
#2 descott12
descott12
    Vendor - Solar Live View
  • Loc: Charlotte, NC
Posted 03 December 2019 - 09:54 AM
Those are incredible. Whatever process you are using it is definitely working!  I can't imagine how much work that is to put those all together.
#3 rigel123
rigel123
  • Loc: SW Ohio
Posted 03 December 2019 - 12:47 PM
These are great Scruffy, I think your editing technique is fine, the areas that you can focus on to really clean these up would be a tilt adapter or flats to help with the Newton rings and flats or a really clean imaging window over the sensor to help with the dust bunnies.  Things out of your control such as passing clouds which I think is the cause of some of the "flashing" in a couple of your animations are something we all have difficulties trying to negate with processing.
#4 BeltofOrion
BeltofOrion
  • Loc: Newfoundland, Canada
Posted 03 December 2019 - 05:10 PM
They look great! Think I only saw one dust bunny ... in that last one.
#5 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 03 December 2019 - 07:57 PM
Really nice animations waytogo.gif !  Are you using Gimp to put the animations together?
#6 Scruffy-the-janitor
Scruffy-the-janitor
  • Loc: Tennesse
Posted 04 December 2019 - 12:07 PM
I use IMPPG and to align and edit, the GIMP to add color. Typically I dont use GIMP to make gifs simply because the file size are huge (full resolution is usually 80-100mb). So I usually just add the individual frames into the stock video editor on windows. But in this instance I did use GIMP to make gifs because astrobin doesnt accept mp4 files.
Edited by Scruffy-the-janitor, 04 December 2019 - 12:08 PM.
#7 sunnyday
sunnyday
  • Loc: behind you.
Posted 04 December 2019 - 12:18 PM
pro stuff
well done sir
