Zeiss Standard Bar mounting options
18 replies to this topic
#1 HCR32
HCR32
  • Loc: Melbourne Australia
Posted 04 December 2019 - 06:09 PM
Hi
Anyone have any clue or suggestion on how to mount a Zeiss scope with a standard Zeiss bar onto a non zeiss Mount via an adapter so tube rings are not an option.
Edited by HCR32, 04 December 2019 - 10:57 PM.
#2 Piggyback
Piggyback
  • Loc: Germany
Posted 05 December 2019 - 09:33 AM
We would need more details on the mount you want the Telementor on for your adaption.
#3 Terra Nova
Terra Nova
  • Loc: Middle Earth
Posted 05 December 2019 - 11:28 AM
I think the OP means a mount accepting a standard Vixen dovetail rail. Since the Telementor has a mounting rail of slightly different cross-section than the Vixen rail, and since it is flush-mounted to the tube, it won’t fit on typical Vixen and Vixen-clone mounts (the ones that use the thumb-screw that pushes the bar directly into the jaw).
I wonder if this type of clamping jaw will work? (I’ll check it out later with my Telementor and let you know.)
#4 Terra Nova
Terra Nova
  • Loc: Middle Earth
Posted 05 December 2019 - 12:49 PM
I just tried it and it doesn’t work. While it works great with the Vixen bar, it falls short of about 1/16 of an inch in securely locking in the slightly narrower Zeiss mounting bar.
Edited by Terra Nova, 05 December 2019 - 12:50 PM.
#5 HCR32
HCR32
Posted 05 December 2019 - 01:26 PM
Thanks I wonder if the Baader/AP clamp would work. Seems like it should.
#6 HCR32
HCR32
Posted 05 December 2019 - 01:38 PM
Can you replace those screws with longer ones so that they could reach the smaller size rail. Or is that vixen clamp solid and not possible to dismantle?
#7 stevep
stevep
  • Loc: UK, Weather sucks
Posted 05 December 2019 - 02:35 PM
If it's a Vixen mount/saddle, Astrojensen wrote a thread some years ago, ''Vixen and Zeiss dovetails'' he changed the bolt on the saddle for a longer version and said it worked fine,
Steve
#8 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 05 December 2019 - 04:06 PM
AP adopted the Zeiss dovetail standard, so AP clamps fit Zeiss dovetails.
Clear skies!
Thomas, Denmark
#9 Astrojensen
Astrojensen
Posted 05 December 2019 - 04:09 PM
Steve
Yes. It's not perfect, but it works. There's no safety, though, so if the bolt loosens, the scope could drop.
Clear skies!
Thomas, Denmark
  • Terra Nova likes this
#10 Terra Nova
Terra Nova
  • Loc: Middle Earth
Posted 05 December 2019 - 04:10 PM
They could be changed out without a great deal of trouble.
#11 Steve Haverl
Steve Haverl
Posted 05 December 2019 - 04:33 PM
How about adding a piece of 1/8“ th by 1/2” wide strip of aluminum bar stock to the rail face opposite the clamp.....? Or add it to the fixed (non traveling) side of the clamp.
#12 HCR32
HCR32
Posted 05 December 2019 - 05:27 PM
Clear skies!
Thomas, Denmark
So this would work if purchased and bolted on to a universal dovetail?
https://www.teleskop...mschrauben.html
Edited by HCR32, 05 December 2019 - 05:28 PM.
#13 Piggyback
Piggyback
  • Loc: Germany
Posted 06 December 2019 - 01:37 AM
From what the description says it might work. Like the two bolt fasteners. Solid looking.
#14 shaesavage
shaesavage
  • Loc: Saskatchewan, Canada
Posted 06 December 2019 - 07:33 PM
I posted this a little while ago https://www.cloudyni...for-telementor/
This might meet your needs.
  • Mike E. likes this
#15 HCR32
HCR32
Posted 06 December 2019 - 08:30 PM
So those longer M5s are long enough to thread back into the OTA I’m guessing, which secured it all down nice and tight.
  • Piggyback likes this
#16 shaesavage
shaesavage
Posted 07 December 2019 - 07:33 AM
Yes, the longer M5s thread into the OTA which secures both dovetails.
#17 Mike E.
Mike E.
  • Loc: Moonstone Observatory
Posted 08 December 2019 - 06:24 AM
I would suggest using stainless steel M5 screws, as rust will develop on ordinary steel ones. You can soak the stainless screws in a solution of black oxide & water to blacken the threads which may extend into the tube.
#18 Terra Nova
Terra Nova
  • Loc: Middle Earth
Posted 08 December 2019 - 09:56 AM
That would do it. I would also shim the rail floor of the clamping jaw. As it is, the Zeiss rail doesn’t bottom out in it.
#19 HCR32
HCR32
Posted 16 December 2019 - 02:25 AM
My solution thanks guys for the suggestions. With my original question and your suggestions I’ve slapped this together with minimal effort.
