Primer for DSO
2 replies to this topic
#1 Old Don
Old Don
Posted 05 December 2019 - 05:55 PM
Would any experienced Questar DSO observers contribute basic information for a  primer on DSO use with a Questar.
Subject selection
Best season
Eyepiece selection
Filter selection
Finder use
Atlas selection
Reference material
Personal tips, etc.
Thanks, Don Yost
  • Astroman007 likes this
#2 Loren Gibson
Loren Gibson
  • Loc: Northern Florida, USA
Posted 06 December 2019 - 12:57 PM
In the big scheme of things, there's not much special to say about hunting DSOs with a Questar 3.5".
Subject selection: Anything suitable for a 3.5" Mak (c. 3" refractor, in terms of light gathering). If you include double stars in the category of DSOs, the exceptionally fine optical quality means that you can jack up the magnification to see if you can detect challenging double stars. Also, there have been a couple of threads in this forum about viewing carbon stars (which can be done with any other scope, of course).
Best season: No different than for any other scope
Eyepiece selection: Use the same guidance as for other scopes. Some DSOs need low power (e.g., the 24 mm Brandon) due to low surface brightness, but others (some planetary nebulae, globular clusters) can benefit from a higher power, such as the 16 mm Brandon, maybe even with the barlow.
Filter selection: I don't use any for DSO, so I cannot comment on this.
Finder use: Here is where Questar is unique. Some people don't like the Q's finder and either use setting circles (requiring a bit more care and effort during setup) or mount another finder device, such as a red dot finder. If you are comfortable with the Q's finder, it takes practice getting used to the huge field of view (e.g., 12 degrees with the 24 mm Brandon eyepiece), getting pointed in the correct general direction and identifying the stars in the view, and the lack of crosshairs. It presents a reversed field of view; it's not like a right-angle correct image finder.
Atlas selection: Pick your favorite.
Reference material: Use whatever you want.
Personal tips: The Questar, with its compact fork-mounted form, is most comfortable for the observer with objects that aren't high in declination. Nonetheless, I view M81 and M82, at nearly 70 degrees north declination. I use a Tristand. I'm not sure how well one could do this with the Questar on a table. A possible workaround for easier access to the more difficult parts of the sky would be to use the Questar in alt-azimuth configuration on a tripod. You lose the use of R.A./Dec. setting circles and the automatic tracking.
Maybe I haven't said much that helps answer your question. In any case, I definitely enjoy looking at deep sky objects through my Questar.
Loren
#3 Gregory Gross
Gregory Gross
  • Loc: Pacific Northwest
Posted 06 December 2019 - 02:20 PM
I have a few recommendations:
My primary sky atlas is the tried-and-true Sky and Telescope's Pocket Sky Atlas. See also the jumbo version of this atlas. Even with my 10" Dob under dark skies, I feel like I will never need a more detailed atlas than this. Use your setting circles in conjunction with the R.A. and declination coordinates in this atlas.
As far as suggestions for objects to target are concerned, you may consider getting a copy of the first two volumes of the Night Sky Observer’s Guide by George Robert Kepple and Glen Sanner. Far and away the best work of its kind. No question about it. What sets this work apart from others is the way that the authors provide separate observations of various objects according to the aperture (3-6" scopes, 8-10" scopes, etc.).
I'd encourage anyone to support the publisher and order directly from them.
