PHD "cyclical" Dec errors
11 replies to this topic
#1 snoraste
snoraste
Posted 09 December 2019 - 08:41 PM
I've been using my NEQ6 with PHD2, and a couple of nights ago I see a graph that clearly shows a short-frequency, cyclical dec error. I have recently re-lubed the Dec axes, and (attempted) to fine tune it again as per astro-baby. Anyone had similar experience?
#2 snoraste
snoraste
Posted 09 December 2019 - 08:51 PM
jpeg:
#3 Gipht
Gipht
  • Loc: Prescott Valley, AZ.
Posted 09 December 2019 - 10:32 PM
My graph looks somewhat like this when there are strong variable winds.  I have an 8" reflector, so it reacts to gusts.
#4 whwang
whwang
Posted 10 December 2019 - 01:20 AM
In addition to winds like what Gipht mentioned, another possibility is excessively large Dec backlash.
#5 mxpwr
mxpwr
  • Loc: Sweden
Posted 10 December 2019 - 01:40 AM
Peak to peak of more than -1.5" to 1.5" seems quite excessive.
#6 dayglow
dayglow
Posted 10 December 2019 - 02:58 AM
The graph has the look of backlash to me also.
Have you tried running the PHD2 Guiding Assistant tool ?  It tests for and reports DEC backlash.
-- David F.
#7 snoraste
snoraste
Posted 10 December 2019 - 07:25 AM
I did run the guiding assistant. the backlash was about 780ms which I then accounted for in PHD. It was not a particularly windy day, so I don't think it's the wind (I was using my SV105T which is fairly compact) and I checked all the cables to make sure there are no snags. It seems more like gear slippage, no? I did try to tighten up the contact between the Dec motor and the gear. Maybe that? The thing is that the error is happening in far less than a full cycle of the Dec motor/gears. Feels like there's something loose.
#8 ELDavis
ELDavis
  • Loc: Ft Myers, Fl and Keystone, Co
Posted 10 December 2019 - 08:48 AM
I would think if this was from wind you would see similar large excursions in RA. Perhaps your Dec clutch isn't fully tightened, or your balance is off.
#9 fmeschia
fmeschia
  • Loc: Mountain View, CA
Posted 10 December 2019 - 04:15 PM
The graph shows a definite time correlation between RA and Dec drifts. To me, this point to a general mount “disturbance”, which could be due to wind or cable drag.
Francesco
#10 snoraste
snoraste
Posted 10 December 2019 - 04:36 PM
I did notice the correlation also, especially on my longer guide time. But the disturbances in RA is far less than DEC, so something disturbing DEC more than RA? I will double check the snags.
#11 guyroch
guyroch
    Vendor (BackyardEOS)
  • Loc: Under the clouds!
Posted 10 December 2019 - 05:34 PM
If you in guide in RA only as a test, does it show disturbances in RA still?  If not the disturbances are introduced by the DEC axis...might give you a place to start looking.
Good luck.
Guylain
#12 snoraste
snoraste
Posted 11 December 2019 - 08:46 PM
good point -  I'll test it when I get some clear skies
