Celestron Evolution WiFi, Sky Safari 6, and MS Surface Pro 4
Celestron
2 replies to this topic
#1 AZWahoo
AZWahoo
  • Loc: Tucson, AZ
Posted 11 December 2019 - 11:42 PM
Here's the problem as I see it:
SS6 on my phone works great, connects to the Celestron Wifi ok - but the size of the screen is ... cramped.
I can get SS6 running on the emulator on my Surface tablet running Win 10. However, the emulator only "sees" a wifi network that seems to be some kind of converter/bridge to the existing internet connection. There is no way, through the emulator, to see and connect directly to the Celestron Wifi.
Is there a way - on the emulator end or on the PC end - to make the Android OS "see" and connect to the Celestron Wifi directly?
Edited by AZWahoo, 11 December 2019 - 11:43 PM.
#2 StarCurious
StarCurious
  • Loc: York Region, Ontario
Posted 13 December 2019 - 03:48 AM
I don't have your set up, so I don't know if the following works.
As an experiment, I would run SS6 on Android phone, along with Teamviewer.  On Windows 10, run Teamviewer to connect over the same WiFi to the Android phone display.  Essentially, this may give you a magnified version of the Android phone display on your Surface tablet.
#3 AZWahoo
AZWahoo
  • Loc: Tucson, AZ
Posted 13 December 2019 - 06:29 PM
Good idea! I tried it. Even in portrait mode, the image on the tablet was only about ~ 25% bigger than the phone.
It seems that there ARE ways to do what I want with an emulator - all beyond my level of technical ability.
I picked up a cheap Android tablet on clearance, to be used as a dedicated telescope tablet. Problem solved.
  • outofsight likes this
Also tagged with one or more of these keywords: Celestron
