Byte3 vs cold weather
5 replies to this topic
#1 astro_1
astro_1
  • Loc: USA, Nebraska
Posted 12 December 2019 - 09:28 AM
Looking for thoughts.
I am trying to use a Byte3 mini PC at the telescope to remote in from my laptop via a travel router. The Byte3 was outside about 15 minutes in 23 degree temps while I setup. Once setup I powered on from a diehard jumpstart battery. But after about a minute it would just shut off.
I brought the Byte3 and battery inside for say 20 minutes and tried again. It powered up fine and I could remote in.
Anyone else have difficulties with PC systems not powering on in the cold? any workable suggestions?
I have a PrimaLuce Eagle 2 but have not actually used it.( wanted to work out my setup procedures first)
Jeff
#2 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 12 December 2019 - 09:49 AM
Sure its not the battery disliking the cold?
Also, jumpstart batteries arent good for running equipment for a length of time, so maybe it really wasnt happy?
#3 astro_1
astro_1
Posted 12 December 2019 - 10:09 AM
True, something to check, although the mount was running fine off the same battery. Guess I could try running the Byte3 off AC in the cold just to see.
  • happylimpet likes this
#4 alstarjoey
alstarjoey
  • Loc: Peoria, IL
Posted 12 December 2019 - 12:43 PM
What is the low temperature rating of the Byte3
#5 astro_1
astro_1
Posted 12 December 2019 - 04:43 PM
Been trying to find the operating temp but no luck.
#6 Raginar
Raginar
  • Loc: Pensacola, FL
Posted 13 December 2019 - 10:31 AM
It's the power.  Computers don't really care about the cold.  There isn't anything in them that changes; if anything it should run better.
Your mount probably has a higher tolerance for voltage differences than the computer does.  Get a better battery.
  • astro_1 likes this
